Need To Control Volume on Inside 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-24-2012, 08:58 PM - Thread Starter
chrismgan's Avatar
I presently have Bose accustimas system in my living room which consists of five double cubes and one subwoofer.These are connected to my (A Speaker) receiver. Also connected to the same receiver (B Speaker) are two pairs of outdoor speaker with each pair having their own volume control near the speakers. When I have a party and there are people both inside and outside-there's a problem. In order to have the outdoor speakers loud enough, the amp inside has to be turned up higher than normal. This ends up being too loud for the inside guests. Is there some kind of secondary controller that could lower the inside music without sacrificing the outdoor volume? I would like to play the same content from the same receiver. I'm trying not to buy another receiver, however if there is an inexpensive solution I'd love to hear it.
chrismgan is offline
post #2 of 19 Old 04-24-2012, 09:14 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Many choices out there from companies like Niles, Crutchfield, Parts Express...
Here is a Radio Shack...NXG-NX-SSVC6 6 zone speaker selector/with independent volume controllers.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 19 Old 04-24-2012, 10:22 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
What reciever do you have?
ifor is offline
post #4 of 19 Old 04-25-2012, 12:01 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
...it is also very possible that you could damage the receiver by creating a low impedance with four speakers hooked up to "speaker B".
Espo77 is offline
post #5 of 19 Old 04-25-2012, 02:11 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
I think he needs a zone 2 to have seperate volume for the outside and for the main surround system. This is why I asked which receiver the OP had.
Speaker B won't be able to give you the seperate volume you need. A receiver with a powered zone 2 will suffice but Espo77 is correct that if you do not connect everything correctly, you can be pushing the receiver too hard and this can cause the receiver to be possibly damaged.
ifor is offline
post #6 of 19 Old 04-25-2012, 05:03 AM - Thread Starter
chrismgan's Avatar
I have an older Onkyo TX-DS575 receiver. What do you mean by a "Zone 2" ? New receiver?
post #7 of 19 Old 04-25-2012, 05:42 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Your receiver does not have a Zone 2 function.
A new receiver (like the Pioneer VSX-1022 or similar) does have a zone 2.
The main zone or Zone 1 would be the surround system, the Zone 2 would be the other rooms in your house. You could have 2 different sources playing, with different volumes, in each of the different zones with a new receiver that is capable of this.
ifor is offline
post #8 of 19 Old 04-25-2012, 05:56 AM
1.21JiggaWatts's Avatar
70w 5.1? I'd recommend checking out some of the advancements in a/v receivers at your local retailer.
Multi-zones allow you to expand your audio to multiple locations throughout your home, I believe you can also listen to separate sources.
You can also clean up some cabling by connecting all your Hdmi sources to the new receivers. Check out some with audio return channel.
If you find a network a/v receiver, there is likely an iOS or android based app that you can control your receiver over your network.
1.21JiggaWatts is offline
post #9 of 19 Old 04-25-2012, 06:48 AM
Elihawk's Avatar
Quoted: 1026 Post(s)
Liked: 869
I have a two zone receiver that does NOT allow seperate volume controls...so choose your reciever carefully.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #10 of 19 Old 04-25-2012, 07:06 AM - Thread Starter
chrismgan's Avatar
Does anyone know of a two zone receiver (mid priced) that DOES allow separate volume control?
post #11 of 19 Old 04-25-2012, 07:56 AM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
Pretty much all zone 2 receivers have separate volume for main room and zone 2. Except apparently the one the other responder purchased.
Whats your real price range?
Afro GT
afrogt is online now
post #12 of 19 Old 04-25-2012, 09:04 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
What is mid-priced to you? Receivers range in price from $300 to $5000.
I already listed a low priced model for you.
ifor is offline
post #13 of 19 Old 04-25-2012, 09:05 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Which receiver do you have?
ifor is offline
post #14 of 19 Old 04-25-2012, 09:23 AM
Elihawk's Avatar
Liked: 869
Some sort of crappy older Pyle Pro receiver ...you almost have to use it in zone 2, as the cooling fan is so damn loud...
post #15 of 19 Old 04-25-2012, 12:28 PM - Thread Starter
chrismgan's Avatar
I've decided on a DENON AVR-1712. It came out to $275. Hope I did OK. Thanks for all the help.
post #16 of 19 Old 04-25-2012, 04:03 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Sounds good.
Make sure you read the *note* on page 45 on the manual.
ifor is offline
post #17 of 19 Old 04-25-2012, 04:16 PM - Thread Starter
chrismgan's Avatar
Sounds good.
They mentioned that to me when I spoke to them this AM. I'll have to use RCA plugs for zone 2. No problem that I can see. Do you see this being an issue?
post #18 of 19 Old 04-25-2012, 04:24 PM
afrogt's Avatar
Liked: 761
Not a problem at all if your source has analog RCA jacks.
Afro GT
post #19 of 19 Old 04-25-2012, 04:40 PM - Thread Starter
chrismgan's Avatar
That won't be a problem. Just a CD player and Popcorn Hour.
Reply Speakers
