Front Speaker help ~$400 pair - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-24-2012, 11:26 PM - Thread Starter
ccthomas's Avatar
I am planning on purchasing 2 front speakers for my onkyo 606 receiver. I have read alot of good things about Energy speakers and it seems like a pretty good option. The setup is 80% music and 20%movies. I want the setup to get decently loud with minimal distortion.
I was looking at buying: Either/or
2 Energy RC-10 for $300
2 Energy CF-70 for $436.98(newegg)
I have read nothing negative about the RC-10 but some people seem to say the CF-70 are harsh. It just hurts thinking for only 136$ more I could get a set of tower speakers that have a high retail value. What setup would yall recommend! Would yall get the CF-70 or are they crap? If there is a better set of speakers for around 400$ please let me know.
ccthomas is offline
post #2 of 13 Old 04-25-2012, 02:59 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You didn't mention a sub, so, for a 2 channel music setup, with higher output expected you dont really want to consider small monitors. I dont care for the cheap Energy's either. I know this isnt what you want to hear, but upping your budget just a hair to $500 gives you a really nice option. I don't know how Newegg has them priced so low, but the Martin Logan Motion 12 is available for way under retail. I would put that on the top of my list.
Jay1 is offline
post #3 of 13 Old 04-25-2012, 03:05 AM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 900
Lotta people like energy speakers, I've never heard them so I cant say. I own a pair of these Hsu HB-1s in rosenut. These are awesome speakers and have lots of great reviews and happy owners here. They play clean, clear, loud and deep. 1pr in rosenut + shipping=$400
http://www.hsuresearch.com/products/hb-1.html
ambesolman is offline
post #4 of 13 Old 04-25-2012, 08:37 AM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
Since your preference is 80% music I would advise against the CF-70. The highs can be harsh and fatiguing so after a little while you may not want to listen to them.
If it was mainly for home theater I'd say go for it!
go to your local Magnolia HT inside Best Buy. They carry the Energy CF speakers. Give them a listen and maybe they'll be okay for you. Not everybody hears things the same.
If you like Klipsch style horn tweeters these speakers may interest you.
http://www.amazon.com/Bic-Acoustech-...5365072&sr=8-9
Also Polk Monitor 70's
http://www.newegg.com/Product/Produc...82E16882290208
Afro GT
afrogt is online now
post #5 of 13 Old 04-25-2012, 08:56 AM
afrogt's Avatar
Liked: 757
This Jamo system may interest you also. 5.0 setup for $349-$399 depending on color.
http://www.vanns.com/shop/servlet/it..._c=site_search
They have a side mounted 8" woofer for increased bass.
If you don't need the other 3 speakers just store them or sell.
Afro GT
post #6 of 13 Old 04-25-2012, 12:04 PM - Thread Starter
ccthomas's Avatar
Thanks all for the feedback. The newegg deal that expires on the 26th deffinatly made me want to impulse buy but if yall think the tweeter is too harsh for a mostly 80% music setup that I will keep looking. What do think about powered PA speakers, is the sound quality reduced? Is there any other speakers yall would reccommend around the 400$price range?
ccthomas is offline
post #7 of 13 Old 04-25-2012, 12:06 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Does your receiver have pre outs for each channel? That's the only way you can run powered speakers.
Jay1 is offline
post #8 of 13 Old 04-25-2012, 12:14 PM
zieglj01's Avatar
Quoted: 940 Post(s)
Liked: 846
I would skip the Polk - something to look into, if you are willing
to give up the manufacturer warranty.
KEF Q300
http://www.ebay.com/itm/KEF-Q300BL-B...item43af2e84a9
Over budget and B-stock, with warranty here
http://www.accessories4less.com/make...rs-pair/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #9 of 13 Old 04-25-2012, 03:05 PM - Thread Starter
ccthomas's Avatar
I have a dj controller that has preouts for powered speakers. I would rather get non powered speakers, was just curious of the soundquality if I did go in that route. The powered speakers would be for parties. The people on this forum are extremely quick and helpful, I really appreciate it. Please keep the suggestions coming, I am reading reviews on all the speakers yall have suggested.
ccthomas is offline
post #10 of 13 Old 04-25-2012, 08:43 PM - Thread Starter
ccthomas's Avatar
I am leaning towards some bookshelf speakers so I can dj at house parties rather than having to bring expensive tower speakers(more likely to get damaged). The KEF Q300 seemed like a solid speaker but the one on ebay sold already. Please keep the recommendations coming.
ccthomas is offline
post #11 of 13 Old 04-25-2012, 09:12 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If this is for DJing parties you definitely need to skip the hifi monitors as they will easily fall apart in that setting. You need something like this
http://www.amazon.com/Mackie-C200-10...5409886&sr=1-1
Jay1 is offline
post #12 of 13 Old 04-25-2012, 10:40 PM - Thread Starter
ccthomas's Avatar
Why can't the speakers listed before take high volume outputs for a couple hrs at a time? Whats the point of good speakers if you cant turn them up loud? If you are right about these speakers not being able to handle it maybe I should rethink the speaker type.
ccthomas is offline
post #13 of 13 Old 04-27-2012, 08:46 AM
Veda's Avatar
Quoted: 124 Post(s)
Liked: 89
+1. KEF bookshelves for house parties. LOL
Veda is offline
Reply Speakers
