7:1 Home Theater Surround Sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-25-2012, 08:03 PM - Thread Starter
dream77's Avatar
Hi All,
Our builder went ahead and installed all the 6 speakers on the ceiling and now is asking for around 400 bucks to change its position according to our needs.
Do you guys think its worth the money to change the location?
What is the best possible location in the ceiling itself?
If not then how do we make the best out of the the present pre wired location (ceiling)?
dream77 is offline
post #2 of 2 Old 04-25-2012, 09:09 PM
LouieIV's Avatar
Is this a new construction house? or is it an upgrade?
The reason I'm asking is $400 is nothing in the grand scheme of things in financing a whole house and I would strongly recommend having it done the way you want now. It will be much cheaper to fix it now then later.
Of course if this is an upgrade to an existing house then $400 is going to be a much larger percentage and you may need to think more about how much you want them moved.
If you can swing it budget wise at all I would recommend getting done the way you want or you will end up regretting later on. (If only I 'd spent that $400 )
LouieIV is offline
Reply Speakers
