Help with HT setup for budget - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old 04-26-2012, 11:16 AM - Thread Starter
phollow's Avatar
I am getting my basement finished and planning to spend around 1500 for setup( receiver,subwoofer and speaker) ..which setup should i got with ? any suggestion would help as i have no clue.. room is probably 10'wide x 14' long. do i have to buy separate wire to do in wall wiring or do they come with system ? .only framing is done so far so still do wiring myself or tell electrician to do it for me.. I am planning to put them on wall. any help is appreciated. no clue about music systems. started reading avs recently
phollow is offline
post #2 of 4 Old 04-26-2012, 11:56 AM
cel4145's Avatar
Quoted: 270 Post(s)
Liked: 797
The Denon 1612 is a good entry level receiver for 5.1, the BIC F12 a good budget subwoofer for HT usage at its price. That would leave you over $1000 for your speakers.
HT: Energy RC-50, RC-LCR, Veritas VS Surrounds | Dual CHT SS 18.1s | Denon AVR-888 | modified Dayton SA1000 | Antimode 8033C
Desktop: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | HK 3390
Headphone & Portable HE-400 | K612 Pro | HP150 | DX50 | E12
cel4145 is offline
post #3 of 4 Old 04-26-2012, 12:33 PM
jjlee138's Avatar
Seconded, or maybe the OnkyoTX-NR509. Good choice on the Bic.
jjlee138 is offline
post #4 of 4 Old 04-26-2012, 03:21 PM
commsysman's Avatar
Quoted: 183 Post(s)
Liked: 269
If you want speakers on the wall, you may want to look at the JBL L820 and L810.
Use 14 gauge speaker wire with an outer sheath for in-wall wiring and terminate it at wallplates with screw terminals or jacks; see Monoprice #2820 for an example.
commsysman is offline
Reply Speakers
