Kef vs infinity - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 05-01-2012, 10:38 AM
ntrain96's Avatar
Originally Posted by Veda View Post
^ right, but it'll show areas where the Q300 is more or less compared to the iQ30 so i know what to expect.
Between these 2 speakers you would be hard pressed to tell any difference, regardless of room as long as they are set up in the same spot. Both are front port bass reflex designs with almost perfectly identical enclosure volume and displacement for the cone. When I had a chance to AB these speakers last year the only difference my ears could tell was that the Q300's upper midrange and treble wasn't as smooth and pink noise and sine sweeps would show subtle differences as well. A bit more choppy on the Q300. But with a good eq, both would sound literally identical. Bass extension was the same. Both speakers had solid extension down to just under 40hz in room.
ntrain96 is offline
post #32 of 32 Old 05-01-2012, 10:40 AM
ntrain96's Avatar
Originally Posted by postrokfan View Post
If you can purchase the KEFs with a 30-day guarantee you could try them out at home and decide. That's probably the best way to audition.
Best thing to do, to see if they are an upgrade to your ears.....agreed.
ntrain96 is offline
Reply Speakers
