Is this because of weak speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-28-2012, 11:50 AM - Thread Starter
P51
P51's Avatar
I bought a little TV for my desk and what I have been noticing is when watching an action movie, explosions or gun fire or anything that should be "in your face" isn't. In fact a lot of the time its actually weak and at a lower volume than normal talking.
Is this because it has weak (3w) speakers? Or is it because of a setting like: trusurround/truvolume?
P51 is offline
post #2 of 10 Old 04-28-2012, 12:05 PM
dunan's Avatar
Quoted: 62 Post(s)
'Little' and '3w' should be the first clues to the answer to your question. It would be unrealistic to expect 'in your face' anything from 3w tv speakers.
dunan is offline
post #3 of 10 Old 04-28-2012, 12:09 PM
CalgaryCowboy's Avatar
The built in speakers are not very good, like most tv speakers
My review comparisons of Energy RC-70s to Veritas V6.3 http://www.avsforum.com/avs-vb/showt...8#post21199418
CalgaryCowboy is offline
post #4 of 10 Old 04-28-2012, 12:23 PM - Thread Starter
P51
P51's Avatar
No, but it when voices are louder than explosions, it makes me wonder what exactly is the problem.
I agree, but even on my laptop (Which I assume has equal speakers), I can actually here an explosion.
P51 is offline
post #5 of 10 Old 04-28-2012, 12:30 PM
Dave1027's Avatar
Quoted: 12 Post(s)
Yeah. If your "little TV" has a variable audio output or headphone jack then you can make a drastic improvement by simply adding a powered speaker set like you'd normally hook to a PC.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
post #6 of 10 Old 04-28-2012, 12:47 PM
Matts's Avatar
If the voices are significantly louder then the rest of the background sound or effects then it's a good bet that your TV has some kind of dynamic volume engaged where it is making everything sound the same volume or close to the same volume, dialogue is always a little more pronounced when something like dynamic volume is engaged. Check your menu under sound/audio to see if you can disengage anykind of audio EQ or volume compression.
Matts is offline
post #7 of 10 Old 04-28-2012, 12:55 PM
dunan's Avatar
Quoted: 62 Post(s)
I don't think there is an actual problem, it's just that you have different speakers that excel at different frequencies for your laptop and tv. Like another poster said, try some headphones.
dunan is offline
post #8 of 10 Old 04-28-2012, 02:42 PM
Bill Fitzmaurice's Avatar
Liked: 4647
The bandwidth of voices is well handled by threes. The bandwidth of explosion's isn't. The TV may even employ high-pass filtering of the audio amp to protect the drivers from over excursion with low frequency content.
Bill Fitzmaurice is offline
post #9 of 10 Old 04-28-2012, 05:25 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Is this because it has weak ( 3w) speakers? Or is it because of a setting like: trusurround/truvolume?
It could be both of the above. Did you experiment with the TVs sound adjustments?
Purchase a powered pair of speakers, like the audioengine A5.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #10 of 10 Old 04-29-2012, 08:28 AM
chikoo's Avatar
Simply put, the tv speakers are designed with vocals/ mid range (forward sounding) bump
chikoo is offline
Reply Speakers
