CDP vs Sound Card - AVS Forum | Home Theater Discussions And Reviews
post #1 of 75 Old 04-29-2012, 10:34 AM - Thread Starter
peck1234's Avatar
Currently looking to invest in either CD Player or a Soundcard to push over some AUX cables to my AMP.
My absolute main concern is for quality of audio. I would love to use my computer and iTunes (all Apple Lossless) for ease of use with a soundcard. But in my experience CD players always sound better? But I also have never owned a HI-FI DAC like the http://www.newegg.com/Product/Produc...82E16829132014
So, CD Player Or SoundCard?
Speakers: EMP TEK E55Ti
AMP: Yamaha AX-497
peck1234 is offline
post #2 of 75 Old 04-29-2012, 01:05 PM
Jinjuku's Avatar
Quoted: 65 Post(s)
Liked: 148
I have a computer based audio streamer and EMU 1212M PCIe sound card.
There is no SQ compromise involved. Actually since everything is stored on a much better storage medium, a HD blows away a CD transport mechanism in the accuracy and tolerance department, I think a computer based solution with a good sound card (internal or external) is a MUCH better way of doing it.
What you linked to is PCI make sure whether you are using PCI or PCI Express.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #3 of 75 Old 04-29-2012, 07:05 PM - Thread Starter
peck1234's Avatar
Thanks I think I'm going to try both in this case.
I have a very basic Sony CD Player on order,
along with the Asus Xonar Essence ST
Once they arrive I will be comparing both in terms of sound quality and update this thread.
peck1234 is offline
post #4 of 75 Old 05-04-2012, 12:28 AM - Thread Starter
peck1234's Avatar
Just intalled the sound-card last night. I'll post my conclusions tommrow after I a/b the cd player vs sound card.
Tests will go
DVP-SR210P>Lossless CD >RCA>AX-497>EMP Tek E55ti $35 CD PLAYER
vs
Asus Sonar>Lossless Audio>RCA>AX-497>EMP Tek E55ti $200 Sound Card
peck1234 is offline
post #5 of 75 Old 05-04-2012, 04:55 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Why not try as well:
DVP-SR210P Lossless CD >digital>AX-497>EMP Tek E55ti
vs
Asus Sonar Lossless Audio>digital>AX-497>EMP Tek E55ti
I bought an inexpensive Diamond Xtreme Sound 7.1 with coax output. I output from FLAC in PCM format to my AVR and that allows bass management without redigitizing. Sounds the same as my Rotel CDP and much more convenient.
psgcdn is offline
post #6 of 75 Old 05-04-2012, 09:38 AM - Thread Starter
peck1234's Avatar
I would but the AX-497 does not offer a digital input. It's a HI-FI amp with analog in only.
peck1234 is offline
post #7 of 75 Old 05-04-2012, 09:45 AM
Jinjuku's Avatar
Quoted: 65 Post(s)
Liked: 148
Tests will go
vs
If you are playing physical CD's on the computer as well as the CDP then I think the highlighting of pricing is fair since no other metric like convenience is going to apply.
Jinjuku is offline
post #8 of 75 Old 05-04-2012, 10:13 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
He already said he was using itunes lossless (and not physically playing CDs on the computer)... Convenience doesn't have to factor in if all he is interested in is sound quality.
psgcdn is offline
post #9 of 75 Old 05-04-2012, 06:07 PM - Thread Starter
peck1234's Avatar
God that took long. After about 2 hours of A/B ing im come to the conclusion that the CD player does infact sound better.
Now, the Xonar does come EXTREMELY CLOSE, but the highs are just a tad recessed and lack the detail and overall dynamics that the cd player provides.
Also I really cant raise the volume with the Xonar as much as I can with the cd player being that the cymbals are VERY Present and seem to shadow over the mix. Maybe I'm just not used to all the detail? Mid highs are lacking tho.
Hrm, : ( now to decide which one to keep.
peck1234 is offline
post #10 of 75 Old 05-04-2012, 11:47 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
2 hours with a new soundcard is not giving it a fair shot.
Are you using itunes on a PC? itunes is not the best of media players. Did you have your computer audio and media player set for bit-perfect playback? How is your operating system audio configured? Did you have the latest driver download for the soundcard. Did you try digital out as well as analog out?
If at first you found it extremely close... imagine what it could be like after a couple of months of fine-tuning.
kiwi2 is offline
post #11 of 75 Old 05-04-2012, 11:58 PM - Thread Starter
peck1234's Avatar
Bit perfect was enabled via foobar, all the latest drivers. (i am a Computer tech for a living). Everything is installed PERFECT. The cd is clearly better
peck1234 is offline
post #12 of 75 Old 05-05-2012, 04:14 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
What kind of format was the computer music in? 16/44 just like the cd? Was it a rip of the same cd in flac? I would be interested in hearing how the higher resolution songs sound in comparison to the cd versions. Ie 16/44 versus 24/192 or higher.
Martycool007 is offline
post #13 of 75 Old 05-05-2012, 06:41 AM
Mupi's Avatar
He is using apple loss less.
Mupi is offline
post #14 of 75 Old 05-05-2012, 08:55 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
If it was that close, I wouldn't sweat the difference and would just flip a coin.
Modern audio theory about DACs, different devices, and sound output indicate that the differences could be sonically transparent and your results were due to test bias. Unless you exactly level matched the two, even a variation of less than 1db could influence the results. And unless your A/B testing was blind, psychologically you could have been influenced to like one or the other. Here's an interesting blog post the discusses how we can be influenced to find one piece of equipment better than another when they are indeed transparent.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #15 of 75 Old 05-05-2012, 10:17 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I agree. If goinf through itunes is more convenient, then go with that.
I find I listen to more of my collection when it's so easily accessed. One track of this, one track of that. No getting out of the chair, turning on all the lights to find a particular CD, swapping it in...
psgcdn is offline
post #16 of 75 Old 05-05-2012, 01:38 PM
Veda's Avatar
Quoted: 125 Post(s)
Liked: 90
Is there anything better currently than the Xonar for similar pricing?
Veda is offline
post #17 of 75 Old 05-05-2012, 01:44 PM
cel4145's Avatar
Liked: 3002
I don't know if they are any better (I have the Xonar STX), but some of the HT Omega series and Creative Titanium are often talked about as very good.
cel4145 is offline
post #18 of 75 Old 05-05-2012, 01:51 PM
Venomous's Avatar
http://www.newegg.com/Product/Produc...ame=HT%20Omega
I've been using the ht Claro XT for many years. It's a very nice sound card because of the c-media chip. I'm moving to pci-e so I'll be replacing it with the pic-e version of it...
http://www.newegg.com/Product/Produc...82E16829271006
Venomous is offline
post #19 of 75 Old 05-06-2012, 01:16 AM
maxcooper's Avatar
Ignoring any technical audio considerations for a moment, my suggestion is to play the music from your computer. Having digital music at your fingertips gives you a ton of freedom that is not available with a CD player. I switched to Squeezebox digital players throughout my home several years ago, and I cannot imagine going back to swapping CDs in and out of a player. Being able to play anything in your collection at a moment's notice, play random mixes, create mixes based on a track, listen to internet radio and music services like Pandora, and scrobble your plays to last.fm to help find other music you might like is simply wonderful. And you can't do any of those things with a CD player.
As cel4145 suggests, a number of factors besides actual performance could have influenced your comparison. Go for the computer setup since it gives you the greatest flexibility to enjoy music, and would likely be indistinguishable from the CD player in a properly controlled test. Enjoying music is what this stuff is all about -- give yourself the best opportunity to enjoy!
-Max
maxcooper is offline
post #20 of 75 Old 05-06-2012, 02:26 AM
Veda's Avatar
Quoted: 125 Post(s)
Liked: 90
Check out QLS Audio QA350 or QA550 for the best of both worlds. I'm assuming it's digital input to the amp/dac right?
Veda is offline
post #21 of 75 Old 05-06-2012, 09:32 AM
russ_777's Avatar
If you believe Asus' specs on the card, it should out perform most any budget CD player. It has TI/Burr-Brown's most expensive DAC chip and reading Asus' description this card and the more expensive STx, they have design features to mitigate EMI, which is the biggest potential compromise you face with PC sound cards.
Try your test again, but this time do a double blind test and make sure the levels are matched. I'm skeptical you should hear any difference between the two on your system...again, if we believe the Asus specs.
russ_777 is offline
post #22 of 75 Old 05-06-2012, 10:00 AM
Veda's Avatar
Quoted: 125 Post(s)
Liked: 90
I have the Asus. Sounds great on its Asio driver and Foobar. The CD could be better because it sounds a few dB louder or have artificially extended highs...
Veda is offline
post #23 of 75 Old 05-06-2012, 10:08 AM
cel4145's Avatar
Liked: 3002
And this Stereophile review confirms the quality of the Xonar Essence cards. There's no reason to think that a CD player will sound better (more likely, at best, equivalent) other than if something very wacky is going on inside the PC introducing noise from the electronics (which is what the metal shield on the Xonar helps to protect from, as you point out). But the differences described by the OP don't seem to indicate that is what's happening.
cel4145 is offline
post #24 of 75 Old 05-06-2012, 12:19 PM
russ_777's Avatar
Thanks for the link, I was not aware of that review. Couple of things that stood out to me:
- JA measured a lower SNR than Asus speced...my skepticism of the 124 dB figure was warranted.
- Also note the difference in measured SNR between the ST and STx. Again, a pretty big difference and really only explainable by the host PC they were installed in.
In either case, the measured performance levels were easily good enough to compete with or beat any low to mid-market CD player.
Perhaps its possible the differences the OP heard were due to installing in a crappy PC. It's also possible the Asus was providing a more accurate sound, but he preferred a less accurate sound produced by the CD player.
russ_777 is offline
post #25 of 75 Old 05-06-2012, 12:33 PM - Thread Starter
peck1234's Avatar
Well, regardless im going to be looking for an external DAC to run an optical out to now.
Any Reccomendations?
peck1234 is offline
post #26 of 75 Old 05-06-2012, 12:51 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Shame your Yamaha AX-497 doesn't have optical in. A new AVR maybe..?
kiwi2 is offline
post #27 of 75 Old 05-06-2012, 01:10 PM
cel4145's Avatar
Liked: 3002
Right. And all distortion added by the Xonar to the signal is at such a low db level that is going to be masked by the S/N range for the recordings on any redbook CDs. It's more likely that the cheap CD player has something going on in the electronics path that is changing the sound (could be the analog stage), or that the CD was not ripped quite perfectly to the hard drive.
cel4145 is offline
post #28 of 75 Old 05-06-2012, 01:13 PM - Thread Starter
peck1234's Avatar
All the cd-r burned from my iTunes were in the apple lossless format sounded slightly better on the cd player.
All my rips are perfect.
peck1234 is offline
post #29 of 75 Old 05-06-2012, 02:44 PM
cel4145's Avatar
Liked: 3002
Then you might want to get a friend to help, make sure you have both units level matched exactly, and then do ABX double blind testing before investing in a more expensive DAC. All the review test data of the Xonar indicates it should sound as well--if not better--than an inexpensive CD player. So if you buy a more expensive DAC, you might be getting just more of the same of what the Xonar does. In other words, if an expensive DAC unit like the Xonar doesn't sound better to you, odds are an even more expensive won't either.
cel4145 is offline
post #30 of 75 Old 05-06-2012, 05:39 PM
Venomous's Avatar
Sound quality starts with the transports and ends at the speakers. What you need to be looking at is just going with balanced outputs to your amp. The easiest way to do this is using the asus stx or st depending on your internal pci connection and be done with it. Now don't take the following statement as a negative stab at you, but look at it as why you would need an external dac:
If you were more concerned with sound quality, your amp setup would be the first to go hooked to those speakers. If your analog inputs are below satisfactory inside your avr, not even a $100,000 dac is going to solve you sound quality issues.
Think about upgrading to a nicer avr with digital inputs. A sonar sound card or external dac could take care of this issue from there.
Venomous is offline
Reply Speakers
