changing speaker tonal qualities - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-29-2012, 11:18 PM - Thread Starter
lite2's Avatar
Read some where that if a speaker sounded bright that Audyssey xt could get rid of the brightness. Is this true? If so, would it also change other sonic qualities of the speaker?
lite2 is offline
post #2 of 3 Old 04-30-2012, 03:12 AM
NuSoardGraphite's Avatar
Quoted: 326 Post(s)
Liked: 298
Its true to a degree. Any equalization system can adjust the tonal qualities of a speaker and thats exactly what auddessey is...a complex software based EQ system.
From what i understand from reading the Auddessey website, Auddessey is designed to tame the brightness inherent in a lot of speakers out there while also boosting bass frequencies to adequate levels. Its supposed to even out the treble to bass ratio. Doesnt always work as advertised though, but it can get pretty close. Your best bet is to purchase the speakers that get the closest to the tonal qualities you like without equalization, then use auddessey to fine tune it based on your space.
Auddessey has a couple of different settings that treat the treble/bass ratio differently, so you arent stuck with just one setting. The standard "Auddessey" setting tames the treble while boosting bass somewhat. "Auddessey Flat" is supposed to simulate a flatter response which probably means less treble cutting and maybe less bass boosting, but this will depend on the combination of your speakers and the room they are sitting in.
On my system (Denon AVR 1912) in my room, i have found Auddessey Flat somewhat better for music, while the standard Auddessey setting was better for movies.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #3 of 3 Old 04-30-2012, 07:15 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
It depends on what you mean by bright and what is causing it.
If your speaker is a cheap speaker with poor-quality tweeters, there is not much to be done about the harsh quality of the treble.
On the other hand, some amplifier/speaker combinations have excessive output in the treble due to the speaker having a high impedance in the treble frequency range. Audessy and other compensation programs can adjust the speaker output in that f range to compensate somewhat.
commsysman is offline
Reply Speakers
