Computer to Outside speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-30-2012, 08:17 PM - Thread Starter
camikazi's Avatar
was going to purchase http://www.crutchfield.com/p_107ATR4...um4-Black.html two set want to hook them up to a computer any suggestions?
camikazi is offline
post #2 of 17 Old 04-30-2012, 08:19 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
You need a power source: an amplifier or receiver.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #3 of 17 Old 05-01-2012, 06:22 PM
camikazi2k's Avatar
any suggestions crutchfiled recommended
Yamaha R-S700 Stereo Home Theater Receiver
camikazi2k is offline
post #4 of 17 Old 05-01-2012, 06:25 PM
gregzoll's Avatar
Liked: 33
Two words "Wireless Speakers". Nothing further to say.
gregzoll is offline
post #5 of 17 Old 05-01-2012, 07:03 PM
camikazi2k's Avatar
dont you need power for the wireless
post #6 of 17 Old 05-01-2012, 07:27 PM
gregzoll's Avatar
Liked: 33
Depends on what you mean by power. Power as in batteries, or a outlet to plug them into, yes you do need that. Otherwise, no wires between them and the device sending the audio to them. That is why they are called "Wireless speakers" (stated slow enough for you to understand).
Wireless has nothing to do with how you power them, it is how you get the audio to them. In other words, works on the same concept as a cordless phone. You know, those things that we used to use before cellphones came along, but had a base they sat on to recharge the battery.
gregzoll is offline
post #7 of 17 Old 05-01-2012, 07:32 PM
camikazi2k's Avatar
I understand that, reason cant go with wireless. we installing them in a gas station so cant change battery ever. prefer wire
post #8 of 17 Old 05-01-2012, 07:40 PM
gregzoll's Avatar
Liked: 33
Again, you do not use batteries with wireless speakers. If using in a gas station, yes wired will work, but you will need a amplifier with possibly a pre-amp for piping the audio into. If this is for customers, keep in mind that the ruling authorities state that you will have to pay a licensing fee to use that in your place of business, if using something like cd's or tapes. That is why you see most places using something like Sirius/XM for business, or local radio stations.
As for your problem, you would need an electrician to run the wires for the speakers, since it is a business and licensed to operate by the authorities in not only your state, but your county or city/village.
gregzoll is offline
post #9 of 17 Old 05-01-2012, 08:06 PM
Nethawk's Avatar
Liked: 119
Maybe someone less condescending and more knowledgeable will come along to help.
The speakers you chose are fine, you're now back to cel4145's feedback, you need a receiver to wire them to.
Nethawk is offline
post #10 of 17 Old 05-02-2012, 05:09 AM
gregzoll's Avatar
Liked: 33
I am not be condescending, I am just laying it out on the table for the OP. If you think that what people post that you do not agree with is condescending, you may want to re-read it in the perspective of if you were the business owner, and some employee wanted to do this work, or if you were the owner, and just wanted to rig something up. Now, if you think what I just stated was condescending, sorry if you cannot take the opinions of others who can see what the OP is doing, and taking it in a reality perspective.
Going back to what I stated, since this is a commercial structure, they will need a licensed electrician to pull the wiring for the speakers, regardless of what type they go with.
gregzoll is offline
post #11 of 17 Old 05-02-2012, 05:24 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Wireless is a pretty good idea. I use some in my room and the wireless signal gets sent from my receiver to a base station which is plugged into an outlet and the wires are ran from there to the speakers. That might work for you and save you a lot of wire running.
joeydrunk is offline
post #12 of 17 Old 05-02-2012, 06:40 AM
SAM64's Avatar
Liked: 78
Yes you are, your level of knowledge is not stellar either.
SAM64 is offline
post #13 of 17 Old 05-02-2012, 07:13 AM
cel4145's Avatar
Liked: 3002
Do you have optical out on your computer? If so, you might want a receiver that has optical inputs, such as the Onkyo TX-8050. If you don't need optical inputs, the HK 3390 would work fine. Either would be a good cost savings over the Yamaha.
cel4145 is offline
post #14 of 17 Old 05-02-2012, 05:24 PM
camikazi2k's Avatar
Thank you no optical out was going from Mini to RCA cable to the receiver.
In regards to license concern, you are right these have to be installed by licensed electrician and they have to have some kind of special license for gas pump. thanks for the concern.
post #15 of 17 Old 05-02-2012, 05:45 PM
gregzoll's Avatar
Liked: 33
If all it is for, is out at the pumps, look at a 70volt mono speaker system, since you will not need stereo out there. If this is just for inside the store, you can go with a regular mono amp, but need the pre-amp for what ever source you input (ie Sirius/XM for business, FM radio station, etc.)
gregzoll is offline
post #16 of 17 Old 05-02-2012, 07:02 PM
camikazi2k's Avatar
any recommendations on mono system
post #17 of 17 Old 05-03-2012, 05:16 AM
gregzoll's Avatar
Liked: 33
Not really. There should be companies in your area that deal with this kind of stuff. Just don't buy the off the shelf stuff at Radioshack, since it is not the same grade of equipment they sold in the 70's.
gregzoll is offline
Reply Speakers
