What speakers excel at low volume? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 05-02-2012, 05:21 AM - Thread Starter
sfeldman721's Avatar
Looking for speakers that perform well at lower volumes (apartment living ).
Could be towers or bookshelf for a room 12 x 14 and may eventually be moved to a room that is 14 x 24. Looking for 5.1 setup and the total max speaker budget not including sub is around 3500 - 4000. Been looking at Paradigm Studio 60's or 20's and also the SE series, B&W CM5's or 8's, PSB Image or Imagine, and of course I haven't heard any of the internet only speaker brands. At least initially they will be powered by either an Onkyo TX-NR3009, Marantz SR7005, or Anthem MRX700. Also, just because I can't blast the speakers doesn't mean I don't want them to be capable of performing well at anti-social volumes as well. Thanks in advance for your suggestions.
sfeldman721 is offline
post #2 of 28 Old 05-02-2012, 06:10 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
I suggest to try planar speakers like Magnepans or even Martin Logan. Quads unfortunately are outside of your price range.
ap1 is offline
post #3 of 28 Old 05-02-2012, 07:33 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I recommend Salk SongTowers ($2K/pr), SongCenter ($800), SongSurround I ($900/pr) = $3700 + shipping.
http://www.salksound.com/songseries%20speakers.htm
Or try the 30-day risk-free return speakers from NHT.
NHT Four Towers ($2K/pr) + ThreeC ($500) + Absolute Zero ($400/pr) & free shipping both ways.
http://www.nhthifi.com/Tower-Speakers
Or
Absolute Towers ($1K/pr) + Absolute Center ($300) + Absolute Zero ($400/pr) = $1,700 (free shipping to you, and if you are not 100% happy, free return shipping back to NHT) :
http://www.nhthifi.com/Absolute-Towe...&category=3773
AcuDefTechGuy is offline
post #4 of 28 Old 05-02-2012, 07:49 AM
zieglj01's Avatar
Quoted: 1673 Post(s)
Liked: 1569
zieglj01 is online now
post #5 of 28 Old 05-02-2012, 09:01 AM
Hyfi's Avatar
Omega single driver speakers will sound nice at any volume and need as little as 5 wpc to drive them.
Rotel 1072 > VAC CLA 1 MKII > Counterpoint NPS-400 > Clearfield Continental Speakers via Synsergistic Research Cabling
Hyfi is offline
post #6 of 28 Old 05-02-2012, 11:17 AM - Thread Starter
Thanks for the replies. I should probably ask that if you reply could you please describe the sound characteristics of your recommendations because none of the speakers suggested so far are able to be demo'd by me. No Focal dealers near me although I've read they are VERY revealing of the original recordings, and even though NHT has the return policy I'm not likely to go through the hassle. The Salks seem like they may be too power hungry based on their specs (80W minimum recommended receiver amplification) and nominal 4 ohm impedance. Are your recommendations neutral, bright, warm, airy, etc. Also these will be for 65% HT / 35% Music. Thanks again for your help.
post #7 of 28 Old 05-02-2012, 11:32 AM
Nethawk's Avatar
Liked: 119
Or
Of similar characteristic to the Salk SongTowers you may wish to look at Philharmonic Audio. AcuDefTechGuy can confirm performance at low volume, but then again I can't imagine him listening at anything less than 90db with his impressive gear
Nethawk is offline
post #8 of 28 Old 05-02-2012, 11:43 AM
Quoted: 995 Post(s)
Liked: 522
Due respect, but everybody's answering the question entirely wrong.
The correct answer is: a speaker that has perceptually similar spectral balance at low volumes as a neutral speaker would at a recording's ideal volume level.
That leads to a search for speakers voiced along the lines of the old BBC/KEF LS3/5a, with hyped-up upper bass and polite treble.
The problem with such a speaker is that it does not sound good loud. Speakers like the LS3/5a get away with that by simply being unable to play loud.
There is, however, an alternative to such a speaker: loudness compensation in the electronics chain. There are at least two adaptive/DSP-based systems that do a good job at mimicking the spectral balance one perceived at louder levels: Dolby Volume (modeler, not leveler) and Audyssey DynamicEQ. All three of the AVR's you mention include one or the other (and of those, as an aside, I think the Anthem is superior, because I prefer ARC to Audyssey.)
Something like the KEF Q-series, KEF R-Series or the Tannoy Revolution series would be where I'd look in the ~4k USD price range for 3 identical mains and two surrounds.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #9 of 28 Old 05-02-2012, 11:59 AM
zieglj01's Avatar
Liked: 1569
Thanks for the replies. I should probably ask that if you reply could you please describe the sound characteristics of your recommendations because none of the speakers suggested so far are able to be demo'd by me. Are your recommendations neutral, bright, warm, airy, etc. Also these will be for 65% HT / 35% Music. Thanks again for your help.
In general, I do not reccomend speakers that sound warm or bright
to me. I like speakers with good resolution, that image well and
have a good soundstage. Air to me - are speakers that have good
detail, definition and depth. I do not like speakers that hide things.
I can describe the sound - however when you listen, it may sound
different to you. Find the speakers that interest you the most, buy
a pair of bookshelves to audition, bookshelves are easier to send
back. If you decide to test Focal, buy the 705 - if you like the sound,
then send them back for the 800 series. Your decision and choice.
For someone spending 3,500 to 4,000 dollars - find a way to listen.
Do you remember this?
http://www.avsforum.com/avs-vb/showthread.php?t=1401622
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
post #10 of 28 Old 05-02-2012, 12:33 PM
DMark1's Avatar
Look for speakers that have a high sensitivity rating (above 90 dB). I have also found that ribbon tweeters and ribbon midrange drivers tend to be very sensitive even at low volumes.
I am biased of course, but I highly recommend any speaker in the Legacy Audio line. All are high sensitivity (over 93 dB) designs, and all utilize very sensitive and smooth sounding ribbon tweeters. Because of the high sensitivity ratings, they play very nice with tube or solid state gear. Models starting at the Signature SE and above also use ribbon midranges, too. Legacy has speakers available at many price points and sizes to fit a wide range of needs. They all sound excellent, and are great values.
I also agree with the comment above about using an AVR that has loudness compensation like Audyssey Dynamic EQ built in. That will surely help you hear a corrected frequency response at lower dB levels, for full, satisfying sound. You should read the Audyssey page I linked above for their comments on the technology.
Feel free to contact me if you have any questions.
Fine Music, Movies, Wine, and Friends - A Life Well Lived!
DMark1 is offline
post #11 of 28 Old 05-02-2012, 12:52 PM
Quoted: 175 Post(s)
Liked: 262
My daughter's room is right next to my HT room. So after 9PM on weeknights, I have to turn the volume to like -35.0 to -40.0 with certain songs. Yes, the Philharmonic speakers sound great even at much lower volumes.
post #12 of 28 Old 05-02-2012, 12:57 PM
Quoted: 175 Post(s)
Liked: 262
I can vouch for KEF as well. Detailed and accurate sound.
post #13 of 28 Old 05-02-2012, 01:29 PM
Nuance's Avatar
Quoted: 22 Post(s)
Liked: 79
They are not power hungry and are easy to drive. 80W is not power hungry by any means. As to their sonic signature, they are neutral, letting the quality of the recording dictate what you hear; that's how speakers are meant to be IMO. They have great off-asix response and power response and image very well.
How loud will you be listening for music and movies? I imagine you intend to cross to a subwoofer?
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #14 of 28 Old 05-02-2012, 01:29 PM
donutfan's Avatar
Quoted: 18 Post(s)
+1!!!
Purists tend to hate loudness comp systems, but for people who can't always turn up their system to the levels that were heard at the original recording session and/or where their own hearing system is "flat" i.e. hardly anyone, they can be very useful.
FYI: conventional loudness comps aren't perfect, because sometimes their upper & lower frequency boosts happen to coincide with a room's or speaker's own frequency response anomalies, causing some unwanted sonic isues. But overall I still like to have them available.
donutfan is offline
post #15 of 28 Old 05-02-2012, 01:30 PM
donutfan's Avatar
Quoted: 18 Post(s)
Question: does Audyssey etc set levels for just one volume setting i.e. "reference level" or does their compensation work at all volume settings?
donutfan is offline
post #16 of 28 Old 05-02-2012, 02:10 PM - Thread Starter
Yes I will be crossing to a sub.
post #17 of 28 Old 05-02-2012, 02:52 PM - Thread Starter
Or
What about the NHT Three Bookshelves instead of going with towers?
post #18 of 28 Old 05-02-2012, 03:04 PM
zieglj01's Avatar
Liked: 1569
You can do an in-room demo
NHT Classic Three from Stereophile
Measurements
The NHT Classic Three's voltage sensitivity was significantly lower both than average and than specified, at an estimated 83dB(B)/2.83V/m. However, its impedance was generally higher, dropping below 6 ohms only in the lower midrange and above the audioband (fig.1). The minimum value was 4 ohms between 120Hz and 170Hz, but there is also a combination of 5.5 ohms and –46° electrical phase angle at 94Hz that will demand a goodly amount of current from the partnering amplifier.
Who AM I
post #19 of 28 Old 05-02-2012, 03:05 PM
Quoted: 995 Post(s)
Liked: 522
Both Dolby Volume and Audyssey DynamicEQ progressively change their target curves based on how far one's listening volume is from "reference," as calibrated in the initial setup. One can vary the amount of compensation by adjusting the "reference level offset."
They're both pretty sophisticated systems. I basically always listen with Dolby Volume's "modeler" component on. (The DV "leveler" component is entirely different. It's a compressor, basically their equivalent to Audyssey's Dynamic Volume. I've never touched it, except to make sure it was off...)
How reflective are your side walls? Three NHT Classic Threes up front would be hard to beat in a room with relatively absorptive side walls. But because they have such wide dispersion, I wouldn't use them in a room that had, say, one sidewall made of glass.
Classic Threes would make good surrounds, too.
Serious Audio Blog
DS-21 is offline
post #20 of 28 Old 05-02-2012, 04:01 PM
chikoo's Avatar
Definitive technology speakers such as the bookshelves would be great. Way under budget and very clear at low volumes.
chikoo is offline
post #21 of 28 Old 05-02-2012, 04:07 PM
mannoiaj's Avatar
High sensitivity speakers may be the way to go. Take a look at klipsch.
mannoiaj is offline
post #22 of 28 Old 05-02-2012, 04:15 PM - Thread Starter
Measurements
So you're saying to stay away from the Three's because of their low sensitivity?
post #23 of 28 Old 05-02-2012, 04:20 PM - Thread Starter
I don't know how reflective my side walls are. One of the side walls is 50% glass (the top half) with wood horizontal blinds covering them. The other side wall is drywall with one wood closet door closed and another door open (regular sized doorway you'd see in any apartment). The open door is at the end of the wall. Wouldn't room correction like Audyssey or ARC help with reflectiveness (is that even a word???)?
post #24 of 28 Old 05-02-2012, 04:55 PM
zieglj01's Avatar
Liked: 1569
You may feel the urge to turn it up. NHT has a 30 day return policy
with free shipping. If really interested in them - then test them out.
Who AM I
post #25 of 28 Old 05-02-2012, 05:06 PM
Quoted: 995 Post(s)
Liked: 522
Then Classic Threes are a bad idea. That's too reflective for them, and too unevenly reflective.
IMO, you should be looking at something with narrower and tighter pattern control, to minimize the influence of your side walls.
Perhaps three KEF Q900's, if you can fit one of those as your center channel. Or three of KEF's Q-series center channels across the front (never use a different speaker from the other two for left, right, or center) all horizontally oriented and perhaps above your TV.
No. It may even hurt. Room correction is great for fixing things like uneven boundary loading across the front three speakers. But it cannot fix power response errors. Only speakers better suited to the room can do that.
Serious Audio Blog
DS-21 is offline
post #26 of 28 Old 05-02-2012, 05:12 PM - Thread Starter
Just KEF Q900's or are there other recommendations you have as well? What about one of the Q series center channel speakers instead of a 3rd Q900? Also, just how does reflection affect the sound? Does it make bass boomy, treble too harsh?
post #27 of 28 Old 05-02-2012, 05:33 PM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
Can you explain this "One can vary the amount of compensation by adjusting the "reference level offset." , and how? Thanks.
Sepen is offline
post #28 of 28 Old 05-02-2012, 05:41 PM
Quoted: 995 Post(s)
Liked: 522
No other recs, given your conditions. Maybe three Tannoy DC8's, if they'll fit in your budget. I don't know how much they are, though. You can skimp on the surrounds if they're close.
Not if you care about sound quality.
There are two approaches to a front stage:
(1) three identical speakers, at the same height, in the same orientation.
(2) flawed and low-fidelity
Imaging, clarity/intelligibility, and spaciousness primarily.
Serious Audio Blog
DS-21 is offline
Reply Speakers
