budget home theatre vs pa speakers - AVS Forum
post #1 of 8 Old 05-02-2012, 10:05 AM - Thread Starter
jspsc123's Avatar
my primary use would be for music and videogames. i am wondering what would be better for a cheap living room set up. i have no experience with pa speakers other than hearing them at a club. i have a set of klipsch quintets and they are garbage. i just dont know if pa speakers would work
jspsc123 is offline
post #2 of 8 Old 05-02-2012, 10:36 AM
JimWilson's Avatar
Quoted: 44 Post(s)
Liked: 307
Generally PA speakers are designed for outright volume, with little thought given to detail and nuance. Could they be used? I don't see why not. I wouldn't myself though -- too unrefined for my tastes.
If you take yourself too seriously expect me to do the exact opposite
JimWilson is online now
post #3 of 8 Old 05-02-2012, 10:40 AM
Bill Fitzmaurice's Avatar
Liked: 1173
That's true of cheap PA speakers, not high quality units. But high quality PA speakers may be well above the OPs budget.
Bill Fitzmaurice is offline
post #4 of 8 Old 05-02-2012, 10:44 AM
zieglj01's Avatar
Quoted: 72 Post(s)
Liked: 368
Do you have a budget?
__________________________________________
Who and Where - is the Way, the Truth and the Life?
Speakers > MB Quart VS05, Boston VS260, Snell K7
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PA-R200, Pioneer VSX-30
zieglj01 is online now
post #5 of 8 Old 05-02-2012, 11:01 AM - Thread Starter
jspsc123's Avatar
i dont have a budget, but im not exactly looking. yesterday i went into guitarcenter for the first time and they had a room full of pa speakers. they were really cheap compared to home theatre speakers. eventually i am going to replace my quintets. i pretty much want to know how a 200 home theater speaker stacks up to a 200 pa speaker, and if a pa speaker in my living room would work. i know they are designed for different things but cheap is cheap. i paid 300 for my quintets and when i listen to music i play it through my tv
jspsc123 is offline
post #6 of 8 Old 05-02-2012, 01:38 PM
Liked: 1173
IME no PA speaker that goes for much less than $800 would be suitable, and even then only with a very good DSP. A $200 PA speaker is junk.
That's about right for a decent speaker...each.
post #7 of 8 Old 05-02-2012, 01:42 PM
zieglj01's Avatar
Quoted: 72 Post(s)
Liked: 368
i dont have a budget, but im not exactly looking. yesterday i went into guitarcenter for the first time and they had a room full of pa speakers. they were really cheap compared to home theatre speakers. eventually i am going to replace my quintets. i listen to music i play it through my tv
Cheap PA speakers give me a headache - the Klipsch Quintets give
me a headache.
post #8 of 8 Old 05-02-2012, 04:47 PM
coytee's Avatar
Liked: 121
I didn't notice a specific budget.
If the picture will post.... I bought these two BASS BINS (only) for $250. I did however, spend another $250 to have them delivered from Florida to Tennessee. So, I have $500 in them. Again, bass bins alone.
I have an active crossover so I'm already holding some of the parts...but, I've sat a Klipsch LaScala on top of these and they sound great. I've sat a Klipsch Heresy on top of them.... a true Heresy with some bark.
The main point is... if you have a bit of luck, you can find some big parts for a decent price and it can sound pretty damn good.
It might simply be better/cheaper to buy some used "......." (JBL's, Klipsch, other...) but if you want some serious punch, big toys like these will give it to you if you feed them the right diet.
Although the sound was KILLER, I'm not recommending the horn on top of this stack as the top horn alone is at/over $1,000 per horn. Just trying to give you some real world ideas of what someone has done.
This was done for an outdoor movie. YOu can see the screen on the ground. Today, I'm currently living/working in Florida and staying in an apartment. I've got these speakers in my 2nd bedroom and in a week, might pull the Jubilee's from active duty and try these in a stereo setup in my apartment living room.
Fun stuff.
coytee is offline
Reply Speakers
User Tag List
