is it worth it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-03-2012, 03:41 AM - Thread Starter
brycepower1's Avatar
my current set up is:
Technics sa-ax6:
crutchfield.com/p_133SFDX7/Technics-SA-AX7-SH-AC500-Receiver-decoder-combination-package.html (almost the exact same as the ax6)
5.0 energy classic speakers:
newegg.com/Product/Product.aspx?Item=N82E16882269004
and a cerwin vega sub in a Qlogic box:
sonicelectronix.com/item_269_Cerwin-Vega-HED-10DVC.html
my amp is designed to be 5.1, but it has 8 outputs for either bi amping or a secondary set of front speakers, so that being said, can i use it as a 7.1 setup or would their be no profit from that?
brycepower1 is offline
post #2 of 9 Old 05-03-2012, 03:51 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
It only runs 5.1, so no you cant add an amp and get 7.1.
You can get a 7.1 receiver for less then $200 these days, might be worth it considering the age of yours.
http://www.accessories4less.com/make...eceiver/1.html
Jay1 is offline
post #3 of 9 Old 05-03-2012, 08:28 AM - Thread Starter
the "B" channel is already powered, and "A" channel does not appear to loss any power when i plug another speaker in to it, it may not have the separation like a 7.1 but does have the same number of working channels
(not interested in buying a new receiver)
post #4 of 9 Old 05-03-2012, 09:11 AM
commsysman's Avatar
Quoted: 1006 Post(s)
Liked: 530
I would consider a pair of better front speakers first and stick with 5.1.
More channels doesn't change the fact that your front speakers are inadequate for decent overall sound.
A set of Polk Monitor 40 speakers would be a big improvement.
Technics sa-ax6:
commsysman is offline
post #5 of 9 Old 05-03-2012, 09:46 AM - Thread Starter
alright so ill stick with standard 5.1
some polk fronts would be nice especially the Polk Monitor 40 since their bi amped, but than i would need a new center and i just purchased these, so i probably wont be buying new fronts for awhile
post #6 of 9 Old 05-03-2012, 11:22 AM - Thread Starter
so it looks like polk audio is recommended for home audio than? how is jbl now days?
post #7 of 9 Old 05-03-2012, 11:31 AM
Nethawk's Avatar
Liked: 118
The Polk speakers mentioned are fine if on a tight budget, but I wouldn't go so far as to say that Polk Audio is recommended in general. It depends on $, room size, source content, listening volume, seating distance, etc.
Nethawk is offline
post #8 of 9 Old 05-03-2012, 11:34 AM
donutfan's Avatar
Quoted: 18 Post(s)
Not exactly - they are recommended by *some* people, not everyone (I don't like them myself, too bright).
Some of their stuff has become a bit too plasticky for my taste, but otherwise I still like them O.K.
I would stick to 5.1. Because simply adding another pair of fronts will NOT give you anything like what 7.1 offers and if anything will "smear" the front soundstage - not good.
donutfan is offline
post #9 of 9 Old 05-03-2012, 11:36 AM - Thread Starter
its a 20x20 enclosed room and i bought the entire system for about $250, when my sound proccesor arives i think i will be more than satisfied
so than who is top of the line? wharfedale?
Reply Speakers
