Near-Field Monitor Recommendations: Desktop 2.0 /2.1 for PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 55 Old 05-04-2012, 12:53 AM - Thread Starter
ota.dt.man's Avatar
I have reviewed the Speaker and 2-Channel Audio threads for this application. For others who may also be interested in this topic, the following list will hopefully be a time-saver:
  1. best "mini" active speakers for the money.. - Audiophile34
  2. Nearfield setup advice ( 1 2) - shaghi
  3. desktop speaker recommendations (for music)? ( 1 2) - Nethawk
  4. Computer Speaker 2.1 Suggestions? - Shadowdane
  5. Advice on a 2.1 Desktop Set-up - blackflagrms13
  6. $350 BEST Computer Speakers. What would you buy??? (Swan, Audioengine, M-Audio) ? ( 1 2) - Bizmord
  7. KRK RokitG2 5 - anismo
  8. 2.0 Speakers for a PC , PS3 - Anderosa
  9. A high-end set of 2.1 speakers for music listening ( 1 2 3 4) - JimWilson
  10. Desktop Setup ( 1 2) - matt_calgary
  11. Recommend pair of active speakers - void.crusader
  12. Active Speakers for Computer Setup ( 1 2) - Borky
I also consulted:
  1. PC Mag
  2. C|NET
  3. PC World
  4. Amazon's Top Rated in 2.1 Speakers
However, once you eliminate the models that are no longer available, have reliability issues per Amazon customer reviews, or noticeable coloration, that narrows the list a bit. Thus, I was thinking a small pair of active monitors would probably provide more accurate sound quality and a much larger selection of models.
Background:
I've always enjoyed music. I played in band for 7 years, mixed audio for high school plays, took music appreciation in college for elective credit, and mixed church audio for 14 years. We have a pair of Maggies and before that a pair of Dahlquists.
Based on our enjoyment of Maggies, I was very interested in PC Mag's review of the Monsoon speakers. Unfortunately, they're no longer available.
I used to sell A/V consumer electronics for several years. I sold the following speaker brands: B&W, Boston Acoustic, Bang & Olufsen, Canton, Dahlquist, DCM, Klipsch, Magnapan, Polk, and Yamaha.
We currently have a 1-yr old 17" laptop w/Realtek HD Audio that we use for all the typical household computing tasks as well as live streaming of video - mostly news and comedy. We'd also like to use it for music. However, most laptops (ours included) have very sub-optimal built-in speakers. We are not into video gaming.
Goals:
  1. Near-field
  2. Desktop (limited space - prefer active speakers instead of a desktop amp)
  3. Natural sound - no coloration
  4. Prefer that the critical voice range not be split between drivers that use dissimilar sound generation techniques (e.g., horn-loaded tweeter & direct-radiating woofer)
  5. Minimum diffraction
  6. Time / phase-aligned
  7. Very good transient response
  8. Non-resonant enclosure (e.g., not plastic like many PC speakers)
  9. No reliability issues (Life is too short.)
  10. 2.0 or 2.1
  11. Excellent value - B-stock or used is ok.
Size:
- Height - The laptop screen is 10" tall when tilted to the appropriate viewing angle.
- Width - Any narrow width active monitor will easily outperform the internal speakers. Larger woofers will obviously provide a deeper bass response. However, desktop real estate is limited and a sub-woofer could be added later if desired.
Since I've been out of the A/V business for many years I'd appreciate any recommendations. Thanks
Broadcast TV - a vital national public resource
Just say "no" to a never-ending subscription TV bill that increases faster than the rate of inflation.
ota.dt.man is offline
post #2 of 55 Old 05-04-2012, 01:37 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I love my Audioengine 2 speakers that I use with my main tabletop PC. You may want to read the review that Stereophile magazine did on them recently. I can recommend them highly.
I use an inexpensive subwoofer (Sony SAW2500) under the table with them.
commsysman is offline
post #3 of 55 Old 05-04-2012, 04:22 AM - Thread Starter
ota.dt.man's Avatar
commsysman,
Thanks for your recommendation. Yes, I understand Stereophille and C|NET both gave the Audioengine A2 a favorable review. How long have you owned your Audioengine A2s?
Per Amazon customer reviews, the majority are very satisfied. Has Audioengine solved the PS issue that was reported on August 24, 2008 by Jess Evans?
Thanks again
post #4 of 55 Old 05-04-2012, 08:07 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I have had mine about for one year now.
Originally Posted by ota.dt.man View Post
commsysman,
Thanks again
post #5 of 55 Old 05-04-2012, 09:03 AM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
There's no indication of a budget, so I'll just wing it with a few 2.0 powered monitors... Hope you're not busy for about a month.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #6 of 55 Old 05-04-2012, 09:10 AM
BobL's Avatar
Liked: 56
Why don't you look at some professional monitors like, Genelec, M-Audio, Yamaha, Focal, etc.
BobL is offline
post #7 of 55 Old 05-04-2012, 09:31 AM - Thread Starter
ota.dt.man's Avatar
Hi Jim,
Thanks for all your recommendations and the links. I'll review them. I know there's a much larger selection of quality-oriented active monitors than consumer PC speakers. However, I was hoping that my list of goals would narrow down list of choices.
Goals:
  1. Near-field
  10. 2.0 or 2.1
Budget: The best value - the greatest accuracy for the dollars invested and that will fit on a desktop. B-stock or used is ok
post #8 of 55 Old 05-04-2012, 09:38 AM - Thread Starter
ota.dt.man's Avatar
That's exactly what I had in mind:
Is there a particular model you might recommend that matches the list of goals?
post #9 of 55 Old 05-04-2012, 09:50 AM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2984
If you have a Guitar Center in your area, they'll have a few lines of pro monitors to listen to.
Meanwhile, if you do decide to consider passive speakers, Emotiva makes the mini-X a-100 for situations where full-sized integrated amp placement would be an issue.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #10 of 55 Old 05-04-2012, 10:20 AM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 601
Since you didn't state a budget I will tell you that the Focal Solo6 Be studio monitors are the best I have heard. Dynaudio is also excellent along with Adam.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #11 of 55 Old 05-04-2012, 12:01 PM
JimWilson's Avatar
Liked: 1560
It did actually. Except for item 9 -- which I have no way of determining -- and item 11 -- which is completely relative -- every option I provided fits the remainder of your criteria.
Unfortunately that's still too nebulous for anyone to really help. The definition of value is almost entirely subjective; "the best value" means different things to different people.
post #12 of 55 Old 05-04-2012, 12:27 PM
Venomous's Avatar
I recommend nearfield monitors with 8" drivers. Yamaha and Focal are very popular in this dept but be prepared to bust out your wallet. I found a ton of good info on recording forums when it came to monitors. You want something that has a flat response curve so any changes in the mix can be easily detected.
For regular 2.1 listening on my desktop, I've found the swan m10s to be nice speakers for moderate listening levels. I eventually moved to the swan m50s and have been very happy with them.
Venomous is offline
post #13 of 55 Old 05-04-2012, 12:51 PM
Nethawk's Avatar
Liked: 118
I was going to mention the Swans as well, they've been popping up used lately at reasonable prices. Audioengine was one I looked at, I thought them a bit bright for being this close to my ears but then I am probably overly sensitive to this.
When I started looking I asked a friend who is an archivist for a well-known band and he swears by Adam Audio - but then they have an unlimited budget and I don't. Another musician recommended Tannoy.
Nethawk is offline
post #14 of 55 Old 05-04-2012, 02:15 PM
Venomous's Avatar
You're going to get recommendations on what they listen to everyday. When you work with any particular brand of monitors, you learn their characteristics and you stick with them. Monitors are not cheap, but they will generally be a one time purchase depending on how serious you are.
Venomous is offline
post #15 of 55 Old 05-04-2012, 03:16 PM - Thread Starter
ota.dt.man's Avatar
Originally Posted by JimWilson View Post
... every option I provided fits the remainder of your criteria.
Thank you for your recommendations!
I've added pricing to your list from Google shopping. All prices are each for new units w/o shipping.
Since you say all these models meet the criteria and I'll won't be using them for critical mixing, I'll first consider the lower cost models ~$300 / pr. new.
post #16 of 55 Old 05-04-2012, 03:21 PM - Thread Starter
ota.dt.man's Avatar
Our nearest G.C. is 30 miles away. Thanks for the heads-up on the mini-X a-100.
post #17 of 55 Old 05-04-2012, 03:28 PM - Thread Starter
ota.dt.man's Avatar
Thanks Drew
Focal Solo6 - $1,195 @. I'm thinking much more cost-effective.
post #18 of 55 Old 05-04-2012, 03:40 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would give the airmotiv5 a hard look - at $449 a pair.
They do have a 30 day return policy.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #19 of 55 Old 05-04-2012, 03:50 PM - Thread Starter
ota.dt.man's Avatar
Originally Posted by Venomous View Post
I recommend nearfield monitors with 8" drivers. Yamaha and Focal are very popular in this dept but be prepared to bust out your wallet. I'll pass.
I found a ton of good info on recording forums when it came to monitors. You want something that has a flat response curve so any changes in the mix can be easily detected. Agreed.
swan m10s - $125 active 2.1 set
swan m50s - $294 active 2.1 set
"regular 2.1 listening on my desktop" - sums it up well.
What would you suggest for a very transparent, lowest diffraction, phase-aligned active monitor?
post #20 of 55 Old 05-04-2012, 04:10 PM - Thread Starter
ota.dt.man's Avatar
Since the critical voice range is split between drivers that use dissimilar sound generation techniques, a high-frequency folded-ribbon transducer and a direct-radiating woofer, how do vocals sound through the crossover point?
post #21 of 55 Old 05-04-2012, 04:26 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Since the critical voice range is split between drivers that use dissimilar dissimilar sound generation techniques, a high-frequency folded-ribbon transducer and a direct-radiating woofer, how do vocals sound through the crossover point?
I have not listened to them - however, I do find this review of the
smaller speaker interesting.
http://news.cnet.com/8301-13645_3-57...sktop-speaker/
Who AM I
zieglj01 is offline
post #22 of 55 Old 05-04-2012, 10:11 PM
Venomous's Avatar
I'm far from an expert in this area. You have to decide on your max budget first.
Venomous is offline
post #23 of 55 Old 05-04-2012, 10:16 PM - Thread Starter
ota.dt.man's Avatar
Please see post #15.
post #24 of 55 Old 05-04-2012, 10:52 PM
Venomous's Avatar
Get the swan m50s. Unless you're a Home producer, you aren't going to need nearfields, let alone at the quality level a pro producer would. The swan m50s are amazing computer speakers that can be used as quality monitors for light production work.
Venomous is offline
post #25 of 55 Old 05-04-2012, 11:01 PM
JimWilson's Avatar
Liked: 1560
I've had the M20's -- the 2.1 setup just below the M50's -- for about 2 years now, and I think they're great.
post #26 of 55 Old 05-05-2012, 12:38 AM
DoinicDenson's Avatar
DoinicDenson is offline
post #27 of 55 Old 05-05-2012, 11:32 AM - Thread Starter
ota.dt.man's Avatar
Jim,
Since you included KRK ROKIT 5 ($300/pr) in your original list, how do you think they compare to the similar priced Swan 2.0 / 2.1 Multimedia desktop models?
post #28 of 55 Old 05-05-2012, 12:05 PM
JimWilson's Avatar
Liked: 1560
Unfortunately, I can't give you an assessment of how they compare because I've never heard the ROKIT's. The list I posted is from something I built a while back, when I was looking for a similar product. I don't have personal listening experience with them.
I actually wanted the Swans M50 myself, but 2 years ago they were not available in the US. The M20 was though, so I bought those instead. They lack a touch on the top end, and the bass doesn't extend quite as low as I'd like, but the detail and soundstage is amazing. I suspect the M50 solves both of those problems.
Swans in general makes some very detailed speakers. The few I've heard have impressed me. The M20 maintain their composure when played fairly loud too.
post #29 of 55 Old 05-05-2012, 12:27 PM
cel4145's Avatar
Liked: 2984
It might be worth the drive to your Guitar Center that is 30 miles away. I listened to all the powered monitors at my local GC, and preferred the Rockit 5s (check and see before the drive). Best Buy has Rockits, although they may not be hooked up so that you can compare them to other monitors the way that GC usually does.
I have not heard the Swans, so I can't comment on how they would sound in comparison.
post #30 of 55 Old 05-05-2012, 01:00 PM - Thread Starter
ota.dt.man's Avatar
Any comparisons on the following models?
Reply Speakers
