Bookshelf speakers sideways? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-04-2012, 11:30 AM - Thread Starter
seanthome's Avatar
Here is my HT setup: 15' x 25' x 7.5x living room. Denon 2112. Klipsch RB-61 & RC-62. 2 ceiling speakers for the rear. Hsu VTF-2 sub.
My question is what are the effects of placing my bookshelf Klipsch 61 speakers on their side instead of placing them vertically upright? I did notice a slightly different sound, but haven't decided if its better or worse. Could there be any possible structural damage possible by placing them this way?
seanthome is offline
post #2 of 3 Old 05-04-2012, 11:37 AM
Brad Horstkotte's Avatar
Liked: 68
I believe the Tractrix horns in those have 60 degree vertical and 90 degree horizontal dispersion pattern. Flipped on their sides of course that switches to 90 vertical, 60 horizontal. From the looks of the design, the horn is built into the baffle, so no way to rotate it 90 degrees. (someone correct me if wrong, just going by pictures).
No issue with structural damage.
Brad Horstkotte is offline
post #3 of 3 Old 05-04-2012, 11:47 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
You will not hurt them - however the sound is overall better,
standing up.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
Reply Speakers
