Wireless surrounds?? - AVS Forum | Home Theater Discussions And Reviews
Old 05-11-2012, 11:39 AM - Thread Starter
Roachforlife's Avatar
Quoted: 26 Post(s)
I have Monitor 30s now and just moved so considering a wireless solution. In general, do you all suggest staying away from wireless? I would consider them for surrounds and for rear possibly
Thanks all
Roachforlife is offline
Old 05-11-2012, 01:23 PM
afrogt's Avatar
Quoted: 1061 Post(s)
Liked: 763
Wired would definitely be preferred but if you have to go wireless do what you have to do.
Afro GT
afrogt is online now
Old 05-11-2012, 02:52 PM
mlknez's Avatar
Quoted: 208 Post(s)
Liked: 52
Thanks all
Dynaudio make excellent wireless bookshevles
mlknez is online now
Old 05-12-2012, 06:24 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
Yes, run wires if at all possible because current wireless solutions are of reduced quality and/or run the risk of interference with other devices, including those used by your neighbors. It may work fine, and does for some people, but you may have issues that are out of your control.
If you feel that you MUST use wireless, at least for your surrounds, then the following seems to be a high quality system:
http://www.amphony.com/products/wire...peaker-kit.htm
It probably won't work well if you or maybe even your neighbors use 5.8 GHz wireless phones, however. There are alternatives that may suit your circumstances better, and we can discuss those if you'd like, but I'd still recommend finding a way to use wires first.
Assuming that the OP is talking about Polk Audio Monitor 30s as opposed to Harbeth Monitor 30s, the Dynaudio Xeo may be a bit pricey.
Robert Cook is offline
Old 05-13-2012, 10:33 AM
Kal Rubinson's Avatar
Quoted: 684 Post(s)
Liked: 466
Thanks all
Here's one new option: http://www.gspr.com/atlantic/wa5030.html
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 05-13-2012, 11:22 AM
Mudslide's Avatar
Quoted: 74 Post(s)
Liked: 84
I recently had an opportunity to audition (A/B with a few other wired types) these from Aperion...
http://www.aperionaudio.com/product/...58,88,789.aspx
They surprised me with their ample bass and delightfully coherent (for the price!) presentation.
IMHO, they wouldn't be embarrassed by any wired speakers in their price class.
MARGARITAS,
they're not just for breakfast anymore.
Mudslide is offline
