Home theater setup under $2000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-13-2012, 11:03 AM - Thread Starter
Parshre's Avatar
Hello
I am about to build my home theater room and planning for a epson projector 6010. I need some help on audio. I need help and advise on what speakers and amps would be best around $2000 for a good quality home theater setup.
Any word of advise ?
Parshre is offline
post #2 of 11 Old 05-13-2012, 11:21 AM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
Could you provide some more information? Specifically, how large is the home theater space? Are you planning on 5.1, 7.1? Would you be willing to start with a good 2.1 or 3.1 setup and then expand as finances allow?
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 11 Old 05-13-2012, 11:24 AM
Macstatic's Avatar
If you can afford to, building it piece by piece will save you tons of money in the long run. Getting the AV receiver that has all the features you need (Air Play, HDMI, pass-through, or whatever else you will need or want) first so that you don't need to upgrade later.
When I mentioned putting it together piece by piece I was more saying that concerning speakers. If you find the type of sound you want, then the brand, you can then look for sales on speakers as well as possibly find some used treasures to add to your system. I pieced mine together over the course of a month and saved a TON of money. I ended up with a 7.1 system (receiver, wires, speakers, and sub) for $1200. If I had purchased them at regular prices at the time, the total would have been $2,750. The money you save on speakers you can use to get one (or more depending on the room size) really high quality subwoofer.
Of course you can go and buy them all new at a store all at the same time, it just depends on what the deals or availability of the speakers are.
First though I mentioned what kind of sound you like. Do you prefer brighter sound (like more in your face) or a more warm or flat sound? That will be important in deciding what speakers you will want. But remember no matter what advice you receive, the BEST way to pick speakers is by YOU hearing them for yourself. Speaker sound is pretty much 70% personal preference, and 30% speaker sound quality. I learned that the hard way by buying two complete lines of speaker before finding the third one which I mentioned above and absolutely love.
For those looking into getting Energy speakers, or upgrading their current Energy setup, here are some reviews I've written that may help:http://www.tempestaudio.blogspot.com  (haven't updated in a while, but include Energy Take Classic 5.1, RC-10, CF-70, and CC-10)
Macstatic is offline
post #4 of 11 Old 05-13-2012, 11:26 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
My first choice if I were doing that would be an Onkyo TX-NR709 receiver for $500 or so, and some nice KEF speakers and a good subwoofer.
A set of KEF iQ30 speakers for the front is $400, a set of of iQ10 speakers is $300, and the T101c center speaker is $300. (at the KEF Direct website).
That leaves you $500 for a Rythmic FV12 subwoofer.
That will be a VERY nice-sounding system for $2000; hard to get better for that price IMO.
Originally Posted by Parshre View Post
Hello
commsysman is offline
post #5 of 11 Old 05-13-2012, 05:58 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Denon 2312 for $463 (Includes S/H, Used, Very Good, Full Factory Warranty).
http://www.amazon.com/Denon-AVR2312C...6953282&sr=1-3
Rythmik FV12 for $565 (includes S/H).
NHT Absolute Zero @ $200 each x 5 = $1,000 (includes S/H).
http://www.amazon.com/NHT-N-AZB-Abso...6953518&sr=8-1
AcuDefTechGuy is offline
post #6 of 11 Old 05-13-2012, 06:16 PM
pokekevin's Avatar
Liked: 102
http://hsuresearch.com/products/hybrid15pkg.html
If you don't want to start with 3.1 and build from there I would get the Hybrid 15
pokekevin is offline
post #7 of 11 Old 05-13-2012, 08:22 PM - Thread Starter
Parshre's Avatar
I would like to set up 5.1 now instead of waiting.
Parshre is offline
post #8 of 11 Old 05-13-2012, 08:24 PM - Thread Starter
Parshre's Avatar
Hello
Thanks for the reply. For sound I liked CM8 and CM9 with Center CM2. However on retail these are very expensive. Any other speaker which can sound similar to these ? My main use is Movies.
Size of room is 16 feet x 16 feet
Parshre is offline
post #9 of 11 Old 05-13-2012, 10:23 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
+1
Not a bad plan actually. I'd probably go with a Denon 2112 or 2312 for the receiver however. The 2112 can be had for $398 or less right now.
post #10 of 11 Old 05-14-2012, 06:28 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
IMO, the recommended KEF speakers are better-sounding than the B & W speakers (and less money). You can also buy PSB speakers for about the same money that will sound better.
The B & W speakers tend to be very overpriced relative to the competition IMO.
Hello
post #11 of 11 Old 05-14-2012, 08:06 PM - Thread Starter
Parshre's Avatar
Thanks for the recommendation. What about the rear speakers ?
Parshre is offline
Reply Speakers
