Stacked speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-16-2012, 05:59 PM - Thread Starter
Mntallman's Avatar
I am sure there are good reasons not to do this but darn my Pioneer FS51s stacked tweeter to tweeter do sound great to me. I remembered my stacked Advents from thirty years ago and knowing my AVR supports "bi-amping" On a lark I used my rear speakers to try it out. I xover at 50 to an eD A5-350.
I admit this set up isn't "family" friendly. Any ideas why this seems to work?
Mntallman is offline
post #2 of 9 Old 05-16-2012, 06:16 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
It adds 6db of capability over a single speaker, which lowers distortion when the volume is matched to a single speaker set up. The issue would be severe off axis comb filtering when your head isn't centered on tweeter level.
Jay1 is offline
post #3 of 9 Old 05-16-2012, 06:24 PM - Thread Starter
Mntallman's Avatar
Thanks Jay...I do sit (reclined :-)) centered between the tweeters. Could this effect be helpful given my seating position?
post #4 of 9 Old 05-16-2012, 06:54 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
If you like it that's all that matters, you won't truly know how the response is being affected at you position unless you measure it.
Jay1 is offline
post #5 of 9 Old 05-16-2012, 07:00 PM - Thread Starter
Mntallman's Avatar
One interesting thing to me is the set up now sounds better with a phantom center...imaging that good
post #6 of 9 Old 05-16-2012, 07:18 PM
astrallite's Avatar
Quoted: 33 Post(s)
Liked: 32
Output has increased but you are getting a narrower dispersion profile due to destructive interference.
astrallite is offline
post #7 of 9 Old 05-16-2012, 07:30 PM
Bill Fitzmaurice's Avatar
Liked: 5687
If you mean that the upper cab is inverted placed atop the other there's no reason not to do so, aside from eliminating the stereo image. Side by side, not a good idea.
Bill Fitzmaurice is offline
post #8 of 9 Old 05-16-2012, 07:51 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 248
How far apart do two speakers need to be to not have ill effect? If you have two monitors, can you use them spread apart instead of a center without ill effect? If not, what is the difference between that setup and a phantom center setup?
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #9 of 9 Old 05-16-2012, 07:59 PM
astrallite's Avatar
Quoted: 33 Post(s)
Liked: 32
Seems the many posters here feel that a phantom center is satisfactory for a relatively narrow seating position, but for a larger room with wider seating you need a point source center channel.
As far as distance between two speakers with downmixed audio, it depends on the dispersion characteristics of the speakers themselves. The double output of vocals is going to cause lobing somewhere, and locations where that occurs will shift as you move the speakers around.
Reply Speakers
