2 amps & 1 pair of speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-17-2012, 11:29 AM - Thread Starter
fuzzy02cls's Avatar
I have 1 set of main speakers. I want to run a higher power 2 channel amp for only stereo listening but at the same time I want the same set of speakers to run off my AV receiver for movies & TV use.
Anyway to do that without having to manually switch the speaker wires?
fuzzy02cls is offline
post #2 of 10 Old 05-18-2012, 01:18 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Niles audio makes devices that will do this. http://www.amazon.com/Niles-DPS-1-FG...ref=pd_cp_pc_0
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #3 of 10 Old 05-18-2012, 01:30 AM
keyboardcat's Avatar
fuzzy a best buy worker a few months ago told me that Niles is good quality. he liked it a lot.
keyboardcat is offline
post #4 of 10 Old 05-18-2012, 05:09 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
What receiver do you have?
ifor is offline
post #5 of 10 Old 05-18-2012, 07:15 AM
Audiojan's Avatar
Quoted: 18 Post(s)
Easiest way todo this would be to use the pre-out from the AVR to the amp in. Better sound (assumingly... since you want to use the stereo amp) for both movies and as a 2-ch music.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #6 of 10 Old 05-18-2012, 08:43 AM
SAM64's Avatar
Liked: 78
Not really, since that's not what the OP wants to do.
The easiest way would be to use a 4PDT switch to switch between both power amps.
SAM64 is offline
post #7 of 10 Old 05-18-2012, 05:19 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
That depends if the OP's '2 channel amp' is only a poweramp or an integrated 2ch amp or a pre-amp and poweramp combination.
I once had my system set up like this with a 2ch pre-amp and poweramp so the AVR could utilise the poweramp as well, but then still have a 2ch system independent of the AVR...
Attachment 247020
But if the OP has an integrated 2ch amp, then using the speaker wire A/B switch like posted earlier would be the way to do it.
kiwi2 is offline
post #8 of 10 Old 05-18-2012, 08:04 PM - Thread Starter
fuzzy02cls's Avatar
I have 1 set of mains. I want the 2 channel separate power amp which is a Crown Pro amp to only work for stereo. It will have a separate 4 channel mixer attached to the inputs. I will have a CD player, & Ipod, going through the mixer.
At the same time I want to use these speakers for my HT Yamaha receiver. Which will have my TV, cable & Blurray player thought that. Looks like the Niles DPS-1 may work. The Crown is 300/channel RMS
post #9 of 10 Old 05-19-2012, 07:17 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
What model/brand are your mains? What model is your receiver? What model is the Crown amp? What model/brand is the mixer? What model/brand are your other speakers?
BASIC INFO GOES A LONG WAY!!!!!
ifor is offline
post #10 of 10 Old 05-19-2012, 03:06 PM - Thread Starter
fuzzy02cls's Avatar
Why would you need all that? It's a basic question. 2 completely separate systems doing different things sharing 1 pair of speakers. I know some AV setups have zones & pre amp oust etc. But again these are independent systems. I do not want either to touch each other except for the same set of main speakers. I ordered the Niles. Should work for what I want.
Thanks for the suggestions.
Reply Speakers
