Amp for 700 Watt speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 05-18-2012, 10:26 AM - Thread Starter
jsheil's Avatar
I'm thinking about buying a pair of 700 watt speakers. What kind of amp would be necessary for these speakers? 350?
jsheil is offline
post #2 of 25 Old 05-18-2012, 10:33 AM
Mike Garrett's Avatar
Quoted: 5562 Post(s)
Liked: 3542
What speakers are you considering? What is your listening distance and what level do you usually set the master volume control?
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 25 Old 05-18-2012, 10:41 AM
mystik610's Avatar
What kind of speakers are you running?
The wattage rating of the speakers matter less than you think. Impedence (Ohms) is more important
mystik610 is offline
post #4 of 25 Old 05-18-2012, 11:36 AM - Thread Starter
jsheil's Avatar
I don't know the impedence. All I know is the wattage.
My listening distance is not far. Just living room distance. The master volume depends, I always have it on different levels. But I want these decently loud so I can drown the living room if I want.
they look boss too
jsheil is offline
post #5 of 25 Old 05-18-2012, 11:42 AM
Ysay's Avatar
they look boss too
Can you provide the make and model of the speakers?
Ysay is offline
post #6 of 25 Old 05-18-2012, 11:47 AM - Thread Starter
jsheil's Avatar
SBPG 212, but they're custom built.
jsheil is offline
post #7 of 25 Old 05-18-2012, 11:47 AM - Thread Starter
jsheil's Avatar
jsheil is offline
post #8 of 25 Old 05-18-2012, 12:01 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Get 2 of the $300 Crown XLS1000 & bridge them to make 700watts 8ohm/ 1100watts 4ohm.
http://www.crownaudio.com/amp_htm/xls_drivecore.htm
AcuDefTechGuy is offline
post #9 of 25 Old 05-18-2012, 12:06 PM - Thread Starter
jsheil's Avatar
Can I underpower the speakers if I buy an amp with low wattage?
jsheil is offline
post #10 of 25 Old 05-18-2012, 12:12 PM
stockmonkey2000's Avatar
As far as I can see there is no information on these speakers anywhere other than the listing you linked to. The key questions are is the 750 watts peak power? What is the sensitivity of the speakers? How loud do you want to play them? Do you like the way they sound? Does the person who custom built these know what he is doing?
Without knowing what kind of components these have it would be hard to tell what we are looking at here. I would be cautious before spending $500 on these and make sure you know what you are getting. They do remind me of the rip off "white van" speakers.
stockmonkey2000 is offline
post #11 of 25 Old 05-18-2012, 12:50 PM
GlassWolf's Avatar
you could get much better speakers used for $500 to be honest.
worry more about the quality of the amplifier as opposed to the power rating it offers. Same goes for speakers.
In regards to underpowering a speaker, there really is no such thing. You need enough power to reach the volumes you desire with enough headroom to handle transient demands, To determine that amount of power, you need to know the details of the speakers you plan to use, like their impedance, sensitivity, and so forth, along with the listening environment variables like the room dimensions, seating distance, sound treatment, carpet or hard floors, ceiling height, and so on. A lot of variables go into that sort of thing.
the power handling spec of a speaker simply tells you how much heat the coils can handle without physical damage. The number has nothing at all to do with the amount of power required to reach full excursion (Xmax of Xmech) or how much power is required to reach peak output, or the level you desire in your situation.
the power ratings of an amplifier are nearly as useless for a number of reasons, one of which is that the power rating, as it's measured, is not a power rating you can attain with a music source while driving speakers. Another reason is because typical listening levels use only a small fraction of the power nearly any amp is able to deliver.
-GlassWolf
My Home Cinema
GlassWolf is offline
post #12 of 25 Old 05-19-2012, 07:35 AM - Thread Starter
jsheil's Avatar
I'm planning to go listen to the speakers on Tuesday. In the mean time can anyone tell me the best way to purchase an amp that will match these speakers without knowing anything about them? Whats a safe amp? I'm really just worried about breaking the speakers.
As you can probably tell, I know very little about audio, so apologies for the stupid questions. Can I hook up any old amp to these speakers? If the Ohm rating on the speakers and the amp don't match up will my amp explode? They have an amp in the store that they say they hooked up and it worked, should I buy an amp with specs like their amp? If I'm not interested in getting the maximum volume out of these speakers (because they are probably too loud anyway) what's a safe bet in hooking them up to a receiver?
Thanks!!
jsheil is offline
post #13 of 25 Old 05-19-2012, 07:58 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The power rating of a speaker is the maximum power you can apply without damaging the speaker. Any amplifier rated for 500 watts per channel OR LESS is OK.
The power rating has nothing to do with the power required to drive the speaker. That is determined by the sensitivity rating of the speaker, in db per watt.
For example, if a speaker is rated for 88db/watt, then 100 watts will give you a sound level of 108db, 200 watts will give you 111 db etc.
You question is like asking what kind of car you need for some tires rated for 130 MPH; the answer would be...any car that will not go over 130.
commsysman is offline
post #14 of 25 Old 05-19-2012, 08:06 AM
coytee's Avatar
Quoted: 158 Post(s)
Liked: 285
You're getting some good comments.
Your question (unknown to you perhaps) is a bit non-sensical. I don't mean that to be rude. Here's an example.
My speakers are rated at 1200 watts max. How big of an amp do I need....?
Well, my speakers are very efficient horn speakers and will go to 109 db at 1 watt of input.
Suffice it to say that if you start juicing 25 watts through them you are not going to want to go much louder while in the same room. Would I therefore need a 1,200 watt amp? (no)
I know a guy who's got the same speakers who's running them with some 8 watt 300B amps, another guy who's runing them with some 2A3 PP amps (that might also be around 8 watts) and you have me at the other end of the spectrum who's biamping mine with a pair of Crown K2's (500 watts channel)
Is that overkill for residential use? Yes however, I have the gains on them turned to about 25% gain which kills all the hiss noise on these efficient horns and if I ever want to turn things up (while outside, for an outdoor movie or a party which we do) I have all the horsepower on tap that I need.
So as has been asked....you need to start at the other end of the spectrum and find out how sensative your speakers are. That might be of more help. Using the max rated input is a bit misleading. (IMHO)
coytee is offline
post #15 of 25 Old 05-19-2012, 08:31 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Those woofers are in a bandpass alignment.... I cant imagine those speakers sounding very good, they probably have a ton of 40hz bass though. Dont be fooled when you listen, you will have tons of treble and boom.
There are actual legit large speakers in your price range
http://www.overstock.com/Electronics...3/product.html
http://www.amazon.com/BIC-RTR-EV15-E.../dp/B003H3L76I
http://www.shopcerwinvega.com/detail/CER+XLS-28/XLS-28
http://www.shopcerwinvega.com/detail/CER+VE-12/VE-12
Jay1 is offline
post #16 of 25 Old 05-19-2012, 10:53 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Where are you going to go listen? What amp is the seller using? Why do you want these speakers?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #17 of 25 Old 05-21-2012, 05:47 PM - Thread Starter
jsheil's Avatar
Great responses thanks guys. I didn't realize how strange my question was.
Jay1, thanks for the suggestions, I was originally going to go vor the ve-12s, but I can't find ANYone who will ship to Canada. But I was looking at the BIC AMERICA RTR-EV15s, would they suit my needs (residential, all genres of music)?
coytee and commsysman, thanks for clearing everything up. I'm still a little (I know, I suck) confused, why would 88db/watt be 108db at 100 watts? Can you guys answer these:
88db/watt at 200 watts = x
50db/watt at 100 watts = y
espo77, Consignment store. No idea, they said 250 watt, whatever that means. Did I mention they look boss?
jsheil is offline
post #18 of 25 Old 05-21-2012, 06:47 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Wow, those are quite large. Reminds me of the Dominator speakers in Ruthless People.
http://www.youtube.com/watch?v=19CvEO3Riy0
Afro GT
afrogt is online now
post #19 of 25 Old 05-21-2012, 07:29 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I think based on what you're looking at, those speakers will satisfy. If you can get BIC's in Canada, the PL89's would be a better buy though.
Jay1 is offline
post #20 of 25 Old 05-22-2012, 06:25 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Thick Plexi Sheild over bottom Pairs.
How do the woofers move any air if they are covered by plexiglass?
psgcdn is offline
post #21 of 25 Old 05-22-2012, 08:12 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Bandpass alignment
Jay1 is offline
post #22 of 25 Old 05-22-2012, 08:27 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Interesting, thanks! Didn't know about that.
psgcdn is offline
post #23 of 25 Old 05-22-2012, 05:38 PM
coytee's Avatar
Quoted: 158 Post(s)
Liked: 285
I'm not an expert on this stuff by any means. If it copies/pastes well, I made a little spreadsheet. Middle column starts at 1 watt. The left column is an 88 db pair of speakers (at 1 watt) and on the right is a horn loaded pair of speakers that are 109 db at 1 watt.
Look at how much power you need for the left spekaer to hit 109 db's (about 128 watts). The horn speaker hits that at 1 watt.
Think about it a different way.... if you are driving a Honda Civic and trying to pull a full sized loaded trailer behind it.... it might do it. It might have some acceleration issues.
Take that same trailer, put it behind an old muscle car of the 70's and that car will not only be able to pull the trailer effortlessly (lower speaker distortion) BUT, it might also be able to out accelerate a normal car while at a stop light!!
Ask me how I know... I used to have a 1971 Olds 4-4-2 and had a trailer behind it after leaving college. I could easily keep up in traffic and if needed, easily pass people WHILE still pulling that trailer.
DB's Watts Horns
88 1 109
91 2 112
94 4 115
97 8 118
100 16 121
103 32 124
106 64 127
109 128 130
coytee is offline
post #24 of 25 Old 05-22-2012, 06:01 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Just realized I skipped over this...
It's not really 88 dB per Watt, but rather 88 dB at 1W input and measured 1 meter away.
At 100 Watts, it's one hundred times more power than 1 Watt, so a 20 dB increase (10 dB for each 10x power increase).
88 dB at 1W implies 111 dB at 200 Watts if there is no compression (still within the linear range of the speaker). (88 dB at 1W, + 20 dB for the 100x increase from 1W to 100W, + 3 dB for the 2x increase from 100W to 200W).
There's really no such thing, I would guess, as a 50 dB at 1 Watt sensitivity speaker. It's very very low.
psgcdn is offline
post #25 of 25 Old 02-01-2013, 11:54 AM
Allsold's Avatar
Hello everyone.
I know this is a slightly old topic, so sorry for bumping.
I just wanted to clear something up.
First: The link to the site is dead. The title got replaced, which changes the URL.
You may now view it here: http://www.allsold.ca/pair-of-custom-built-1070watt-speakers-51-tall-6149
Second, they aren't 700 Watts, we were wrong. We opened them up, and they are a total of 1070 Watts each, 8 ohm.
We took a couple more pictures of the back of the speakers to show everyone.
The Allsold.ca Team
Allsold is offline
Reply Speakers
