Convinced a friend against HTIB - Need budget speakers ($300) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-18-2012, 05:27 PM - Thread Starter
lou99's Avatar
Helping a friend out and steering him away from a HTIB. He started off with a $300 total budget. Now purchased a Onkyo 709 and has $300 for 5.1 setup.
This is for a small room - gaming/movies only.
Some budget systems he's looking at in the sub $300 range:
Boston Acoustics Horizon MCS100 5.1 - 219.99 (A4l)
Polk Audio RM705 5.1 - 249.99 (Amzn)
Klipsch HD 500 Compact 5.1 Home - 299.99 (Amzn)
I know it's well below the standards of most, but do any of you have input on the following 3, or any legit recommendations in the sub $300 price range?
The goal is to buy better speakers in the future and retain the receiver.
lou99 is offline
post #2 of 7 Old 05-18-2012, 05:54 PM
chashint's Avatar
Liked: 54
If you are near a Fry's they have Jamo s404 5 channel set for $200
Charlie
chashint is offline
post #3 of 7 Old 05-18-2012, 05:55 PM
zieglj01's Avatar
Quoted: 1422 Post(s)
Liked: 1261
After looking at your list - I chose this one >
$300 off with the promo code > Martin MLT-2
http://www.newegg.com/Product/Produc...82E16882981013
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Harman Kardon Ten > Boston VS240 -- Receiver > Integra 50.2
zieglj01 is offline
post #4 of 7 Old 05-18-2012, 06:08 PM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
Rather than buying a cheap 5.1 throw away system, I would suggest spending the $300 on a decent stereo pair, then add center channel, sub and surrounds later as the budget allows.
Vampidemic is offline
post #5 of 7 Old 05-18-2012, 06:20 PM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
Polk rm6750 is $199 at Newegg and is better than the rm705.
Or parts express 5.0 package.
http://www.parts-express.com/pe/show...Number=300-680
Plus Energy s10.3 from Newegg for $199. Great setup for $330!
Afro GT
afrogt is offline
post #6 of 7 Old 05-18-2012, 06:34 PM
smasher50's Avatar
Quoted: 372 Post(s)
Liked: 18187
fwiw,
2 pairs of pioneer sp-bs21 bookshelves on sale $50 apair at newegg (great deal)
set avr for "phantom center" for now
bic f-12 sub $188 amazon
save up for pioneer sp-c21 center $80 at parts express
newegg also has polk psw505 sub on sale for $199
seriously, 2 sets of the pioneer bookshelves and either sub for under $300 will give you way better ht sound than any htib. just my 2 cents
i'm so laid back,i'm laid out
smasher50 is offline
post #7 of 7 Old 05-18-2012, 08:54 PM - Thread Starter
lou99's Avatar
Thanks for the suggestions - Especially Parts-Express. I need to look into it further, but I also found Dayton HTP-3 5.1 Kit for 199. Includes a 12" powered woofer where everything else we looked at had a 8".
http://www.parts-express.com/pe/show...number=300-696
lou99 is offline
Reply Speakers
