Speakers for Denon AVR 2112 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-21-2012, 08:49 AM - Thread Starter
Jencathen's Avatar
Hi! I'm looking to add speakers to my existing sound system.
Currently I have a Denon AVR 2112 receiver
BIC America F12 12-Inch 475-Watt
Bic America Dv64 6.5 Tower Speaker x 2
BIC America DV-62CLRS 6-Inch 2-Way Center Channel Speaker
I want to add suround speakers x 4.
The room is 20 x 27 with vaulted ceiling.
Budget <=$1000.00
Used to watch movies and listen to music.
Jencathen is offline
post #2 of 6 Old 05-21-2012, 09:52 AM
afrogt's Avatar
Quoted: 1096 Post(s)
Liked: 783
at $250 ea you would be spending way more for your surrounds speakers than for your front 3. That doesn't make much sense since the front 3 and sub are way more important.
Are these surround speakers supposed to be floorstanding towers, bookshelf speakers on stands, wall mounted, what?
Afro GT
afrogt is offline
post #3 of 6 Old 05-21-2012, 10:23 AM - Thread Starter
Jencathen's Avatar
When I bought the first few, I was on a very very strict budget as I had just bought the Receiver and a huge TV and purchased it before coming to this site and finding out that speakers were the most important part. So I just bought what I could afford at the time.
I don't have a preference to type i.e. floor standing, bookshelf or wall mounted. The location is good for any of them.
So would you recommend just buying some lower end and eventually upgrade the first 3?
post #4 of 6 Old 05-21-2012, 11:31 AM
zieglj01's Avatar
Quoted: 1014 Post(s)
Liked: 907
Get some more Bic for surrounds
http://www.parts-express.com/pe/show...ource=googleps
__________________________________________
Who AM I
zieglj01 is offline
post #5 of 6 Old 05-21-2012, 12:37 PM
afrogt's Avatar
Liked: 783
If you're happy with the way your current speakers sound, then get more BICs for surrounds...
I would get 4 more towers if you've got the room.
http://www.amazon.com/BIC-America-Ve...7628925&sr=8-1
Next choice would be 4 of the DV-62CLRS on stands
http://www.amazon.com/BIC-America-DV..._bxgy_e_text_b
3rd choice would be 2 pair of the DV-62 bookshelf speakers linked above.
Afro GT
afrogt is offline
post #6 of 6 Old 05-21-2012, 06:05 PM - Thread Starter
Jencathen's Avatar
Thanks guys!
Reply Speakers
