Speakers for Warehouse/Retail Space - 3000Sq Ft - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-22-2012, 08:13 AM - Thread Starter
Shad0w99's Avatar
Hi there,
I need some kind of way to have music in a warehouse/retail space - 3000Sq Ft. For music source, I was thinking Pandora commercial via my laptop. What kind of speakers would I need for this? or do I need more stuff like a receiver? Simple laptop + speakers not good enough for such space? I would like to keep costs as low as possible. Any help regarding this would be great.
Thank you
Shad0w99 is offline
post #2 of 4 Old 05-24-2012, 12:02 AM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
Actual exact budget?
Will this be used for just background music for shoppers or do you need it loud?
crazyrob425 is offline
post #3 of 4 Old 05-24-2012, 05:40 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
It sounds like you are going to need an integrated amplifier of some sort and a pair of speakers. The Sony SSB-3000 speakers are $70 or so and would probably be good enough for that.
You can probably find a used receiver or amplifier fairly cheap, since it doesn't have to have the latest features.
Originally Posted by Shad0w99 View Post
Hi there,
Thank you
commsysman is offline
post #4 of 4 Old 05-24-2012, 06:07 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
With the space of your size one set of speakers is not enough. The best solution is to use ceiling speakers placed every 10 feet all over that place. Than you will need few professional amps to drive them. Get the cheapest you can find, you do not need anything fancy for that purpose.
ap1 is offline
Reply Speakers
