speakers too close to the floor? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Nethawk
post #1 of 20 Old 05-23-2012, 10:24 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
as the title suggest can towers be too low? i want to rearranged my entertainment center and was toying with the idea of putting towers on the floor. now i now the tweeters wont be ear level but is that the only consideration, or how low is too low? thanks for any advice in advance.
manuetdeo is offline
post #2 of 20 Old 05-23-2012, 10:27 PM
Drew Eckhardt's Avatar
Yes.
You'll get an unnatural boost in the lower midrange that makes actors and singers sound like they have chest colds and assuming the speakers are horizontal will have other problems in the cross-over regions.
Lower than when they're standing normally.
Drew Eckhardt is offline
post #3 of 20 Old 05-23-2012, 10:37 PM
zieglj01's Avatar
Quoted: 1064 Post(s)
Liked: 965
In another thread you owned Polk Monitor 40 speakers - are you
talking about them?
__________________________________________
Who AM I
zieglj01 is online now
post #4 of 20 Old 05-24-2012, 07:59 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Towers are designed for floor placement. what are you using. If the tweeters are not at seated ear level, adjust the spikes or rig up something that tilts the speaker back a little.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #5 of 20 Old 05-24-2012, 08:16 AM
afrogt's Avatar
Quoted: 1115 Post(s)
Liked: 795
The fact that they are floostanding towers means they should be placed on the floor or a short base or spikes.
What speakers are you talking about?
Afro GT
afrogt is online now
post #6 of 20 Old 05-24-2012, 09:23 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
currently i have some monitor 40s but was looking at some def tech towers as fronts and in my new designed layout the tweeter of the polks would be about a ft below ear level and was looking to find out what kind of difference this makes, also this new layout would allow for a vertical center by virtue of stacking my components on either side of it
btw the bp8020st is what i was looking to get
post #7 of 20 Old 05-24-2012, 10:13 AM
donutfan's Avatar
Quoted: 18 Post(s)
By "on the floor", do you mean laying the speakers on their sides on the floor?
If so, that would definitely cause significant audible problems.
donutfan is offline
post #8 of 20 Old 05-24-2012, 02:09 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
no i meant keeping them vertical. i think i didnt ask my question right. i am in the process of transitioning from a all purpose media room to a tv/music only family room and turning my kids play room into a movie/game only room. my family room will only consist of tv, htpc, fios box, amp and the iffy 2.1-5.1 setup(which is where im stuck). with my current polks i could leave in fam room anf get new speakers for movie room or go diy for movie and use polks as surrounds and get floorstanding for fam and only have 2.1 there. either way im building an enterntaiment center and was concern about the effects of low tweeter placement mostly for music in fam room if i leave polks alone
post #9 of 20 Old 05-24-2012, 02:28 PM
afrogt's Avatar
Liked: 795
If you leave the Polks in the family room, why dont you just put them on stands to get the tweeter at ear level?
Afro GT
post #10 of 20 Old 05-24-2012, 02:48 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
are there any child proof stands? im not real familiar with stands only ones i've ever seen are those skinny bose ones and those would not work with a 15 month old. the polks are currently straped into back to the shelf they sit on, which may move to movie room to make way for prettier and shorter entertainment center
post #11 of 20 Old 05-24-2012, 03:47 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Get some these, completely custom dimensions
http://www.gwizpro.com/stands/prodde...?prod=SCStands
Keep the height short, like 12", and select the tilt back option.
Jay1 is offline
post #12 of 20 Old 05-24-2012, 04:12 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Jay1! now why didnt i think of that? i am going to really feel bad copying a veteran owned companies ideas but i can just build those not trying to be rude but i never thought about stands like that and they look so simple i dont know why it didnt occur to me to think of that before
post #13 of 20 Old 05-24-2012, 04:16 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
No worries, diy whenever you can
Jay1 is offline
post #14 of 20 Old 05-24-2012, 06:02 PM
Nethawk's Avatar
Liked: 119
I LOL'ed.
jasonsong likes this.
Nethawk is offline
post #15 of 20 Unread 04-04-2017, 10:56 AM
Quoted: 37 Post(s)
Liked: 6
Could this be fixed by adjusting the EQ to reduce the low frequencies and balance things out?
Gear: Sony KDL48W600B, Nvidia Shield TV (2nd Gen), Sony CMT-DC1, Kenwood BR-2001 Minidisc Micro System, Numark TT-1, Gemini XL-500 II, Behringer VMX300, JBL Pebbles
ungraphic is online now
post #16 of 20 Unread 04-04-2017, 11:20 AM
Bill Fitzmaurice's Avatar
Liked: 5065
Bill Fitzmaurice is online now
post #17 of 20 Unread 04-04-2017, 01:26 PM
Quoted: 37 Post(s)
Liked: 6
Originally Posted by Bill Fitzmaurice View Post
I thought it was good practice to post in existing threads before starting up another thread with the same content? It's not like my question was absurd... just looking for a work around for something that may potentially not have a solution such as simply moving the speakers up.
post #18 of 20 Unread 04-04-2017, 01:40 PM
bluewizard's Avatar
Quoted: 1746 Post(s)
Liked: 1043
If you are placing the speakers VERTICALLY, upright as they are designed to be placed, then remember that the sound from the Tweeter spreads out at about 0.27 x the Distance (0.27 = TAN 15° or ±7.5°). So, if you are 10 feet away, the cone of sound coming from the tweeter is 2.7 feet wide (which is ±1.35ft). As long as you are in that cone of sound, you are fine.
Tweeter are tested at ±15° off axis, and the sound while slightly diminished that is still considered acceptable. So, in this case, the cone of sound from the Tweeter is 0.58 x the Distance between the Tweeter and the listener. Again, it this case, that means the cone of sound has fanned out to 5.8 feet in diameter (±2.9ft) at a distance of 10 feet. (Tan 30° or ±15° = 0.577)
So, you don't really need to be perfectly in line with the Tweeter.
If the difference between the vertical height of the tweeter and the vertical height of your ear is less than (2.7ft/2) 1.35 feet you are fine.
Even if the difference is 2.9 feet you are still doing pretty good.
Though I'm curious, if you were not going to place your speakers vertically ON THE FLOOR, how and where would you place them??????
Steve/bluewizard
bluewizard is online now
post #19 of 20 Unread 04-04-2017, 02:15 PM
Liked: 5065
Sometimes the simple solution is the best one, and that's the case here. Tweeters work best when at ear level, and can be OK if the speaker is tilted up (or down, as the case may be) to put the tweeter on-axis with the LP. Goosing the HF EQ to try to compensate for poor placement is not a good idea.
post #20 of 20 Unread Today, 03:08 PM
bluewizard's Avatar
Liked: 1043
I'm not disagreeing with what you are saying, just modifying it a bit. As I illustrated in Post 18, if your ears are within 1 foot (horizontally or vertically) of the tweeter, there is pretty much no change. Though that is a based on an estimated 10 foot listening distance.
Tweeters at ear level is not always the best solution, though, in general your point is right. If we change the context to Toe-In, you can tune your speakers by using varying degrees of Toe-In. For brighter speakers, perhaps facing straight forward is better, for softer less bright speakers, perhaps pointing straight at you is better.
The same can result from the tweeters being higher or lower.
Could the Original Poster tell us SPECIFICALLY what is floorstanding speakers are (brand and model) or could he give us the measurement from the floor to the center of the tweeter so we have some context to respond in?
Again, I'm not saying you are wrong; I'm just saying that there is a ± factor in the Tweeter Head High guideline.
Steve/bluewizard
Reply Speakers
