HT: Has anyone ever moved from high sensitivity speakers BACK to low sensitivity? - Page 23 - AVS Forum | Home Theater Discussions And Reviews
post #661 of 675 Old 11-30-2012, 01:51 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
This is a CSD chart for DE250 compression driver used in Pi horn designs followed by the NRT dome tweeter and RAAL ribbon used in Ascend Sierra Tower.
RAAL obviously has the shortest decay time. DE250 and NRT seem comparable to me.
zheka is offline
post #662 of 675 Old 11-30-2012, 02:00 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
The 1/6th smoothing on the DE250 can throw things off significantly.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #663 of 675 Old 11-30-2012, 02:03 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 248
It's kind of hard to tell because the scale is so different. Am I correct that the DE250 is being measured with a range of 20db and 3ms while the other two are at 36db and 1ms?
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #664 of 675 Old 11-30-2012, 02:08 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Yeah...the 1ms vs 3ms scale is a pretty drastic difference.
-curtis
cschang is offline
post #665 of 675 Old 11-30-2012, 02:12 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
the time axes does not matter, it's in ms so you can see how long it takes for the signal to decay.
good catch about the dB scale though. I think it is 30dB vs 20dB floor.
so you are right, it is not easy to tell. the DE250 will look worse at -30dB level. the question is by how much.
zheka is offline
post #666 of 675 Old 11-30-2012, 02:25 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
the time axes does not matter, it's in ms so you can see how long it takes for the signal to decay..
In visual representation, it certainly does matter. Like I said, smoothing can make a big difference too.
-curtis
cschang is offline
post #667 of 675 Old 11-30-2012, 02:32 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
zheka, can you find a energy vs time curve for the DE250?
-curtis
cschang is offline
post #668 of 675 Old 11-30-2012, 02:46 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
I could not. we may have to ask BWalso, since he's done extensive testing of the DE250 and its clones
zheka is offline
post #669 of 675 Old 11-30-2012, 02:47 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
BW?
-curtis
cschang is offline
post #670 of 675 Old 11-30-2012, 02:49 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
I agree about smoothing. it's not clear what smoothing was applied on the Ascend charts, but if I had to guess it is probably less than 1/6 octave
zheka is offline
post #671 of 675 Old 11-30-2012, 02:51 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
zheka is offline
post #672 of 675 Old 11-30-2012, 02:58 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
No smoothing on the Ascend charts/measurements.
-curtis
cschang is offline
post #673 of 675 Old 11-30-2012, 03:29 PM
OldMovieNut's Avatar
This stands to reason. But if you were to measure spectral decay in room, you would probably find that 0.3 ms difference between the tweeter and the ribbon in Sierra Towers is insignificant compared to the influence of the room. So the explanation for the difference in sound may have to be found elsewhere.
But I maybe way wrong here. At least this is a measurable difference unlike the HOM explanation Geddes is pushing.
zheka,
Correlation is not causation, but it just seems to me that time domain performance is an area where direct radiators tend to outperform CDs and may explain what some people are hearing. Just how senstive the human ear is to these differences, I don't know. It would be an interesting study, to say the least. It would be difficult to control the other variables, though. Perhaps the best you could do is conduct controlled listening tests with a horn loaded speaker with an active crossover and use different CDs with different diaphragm materials. At least in this case the on and off axis responses could be kept as close as possible.
I must confess I am not a horn guy, but I am capable of being persuaded. For example, the Danley Synergy Horns intrigue me and I would really like to hear them. They are ugly suckers, though.
Cheers,
OldMovieNut
OldMovieNut is offline
post #674 of 675 Old 11-30-2012, 06:03 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Originally Posted by OldMovieNut View Post
zheka,
Cheers,
OldMovieNut
I appreciate your reply, OMN.
A good way to measure importance of spectral decay for HF drivers would be by using DSP to artificially extend it. I think it can easily be performed as a double blind test. The subjects would be asked to tell apart naked RAAL response for example vs one with the decay time doubled or even tripled.
zheka is offline
post #675 of 675 Old 11-30-2012, 07:11 PM
Mike Garrett's Avatar
Quoted: 6930 Post(s)
Liked: 4615
zheka,
Cheers,
OldMovieNut
mjgarrett100@gmail.com
Mike Garrett is offline
Reply Speakers
