HT: Has anyone ever moved from high sensitivity speakers BACK to low sensitivity? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 675 Old 06-02-2012, 06:45 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Originally Posted by tesseract67 View Post
With all the comparisons being made in this thread, I'd like to point out that those fared well against the GedLee Abbey and Nathan, music and movies. Comparison done by someone who owns all three, and kept all three.
Wait.....did you just say the $395 SHO-10 compared well against the $3,000 GedLee for music?
AcuDefTechGuy is offline
post #182 of 675 Old 06-02-2012, 08:35 AM
tesseract67's Avatar
ADTG, I can't post links or pictures, someone runs to the mods when I do. I'll PM the info with your permission.
"Women and cats will do as they please, and men and dogs should relax and get used to the idea." -Robert A. Heinlein
tesseract67 is offline
post #183 of 675 Old 06-02-2012, 09:27 AM
Bill Fitzmaurice's Avatar
Liked: 5687
No surprise there. By the look of it they use an Eminence pro-sound woofer, probably the Delta 10, and when you limit the low frequency corner to 80Hz as they do you can get a very good result for very little cash.
Bill Fitzmaurice is offline
post #184 of 675 Old 06-02-2012, 09:40 AM
Quoted: 175 Post(s)
Liked: 262
Please do. I'd appreciate it.
post #185 of 675 Old 06-02-2012, 03:40 PM
Zen Traveler's Avatar
Quoted: 584 Post(s)
Liked: 597
Originally Posted by omegaslast View Post
See, now we're getting somewhere.. you sit 7 feet away and probably havent listened to a real high sensitivity compression driver design (as pointed out above, klipsch RF series doesnt really count, maybe the RF7 counts... maybe).
Did we ever find out if the Klipsch RF-7 counts?
Zen Traveler is online now
post #186 of 675 Old 06-03-2012, 05:52 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Toole is partial to speakers flat far off axis, which precludes constant directivity designs from his theories. Much has changed since then. For instance, I don't believe this was taken into consideration. It's a game changer.
http://www.pispeakers.com/Pi_Speakers_Info.pdf
thank you for the Pi white paper link. a lot of good info for a newb like me.
their arguments against symmetrical horns seems very convincing. I am curious where CHT's current 90x90 horn falls in this respect.
zheka is offline
post #187 of 675 Old 06-04-2012, 07:00 PM
It is just a design choice that Parham has made. The GedLee oblate spheroids are 90 degree waveguides, I believe. Here is Geddes' white paper.
http://gedlee.com/downloads/directivity.pdf
post #188 of 675 Old 06-04-2012, 07:34 PM - Thread Starter
omegaslast's Avatar
Depends on the efficiency of the 8" woofers
omegaslast is offline
post #189 of 675 Old 06-04-2012, 08:27 PM
Rick Craig's Avatar
Quoted: 82 Post(s)
Liked: 78
I have had many good lower sensitivity speakers but tend to prefer CBT arrays because I can get both excellent sound quality and high output plus large dynamic capability. My earlier experience with straight (conventional arrays) always had me going back to arrays because of the lack of compression. CBT's sacrifice some of the output of a straight array but offer better vertical coverage which surpasses anything else in arrays or conventional designs (a big advantage for theaters with tiered seating).
Selah Audio
Thinking Inside the Box...
Rick Craig is offline
post #190 of 675 Old 06-07-2012, 03:05 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
you are absolutely right, all of his speakers use 90 degree waveguides.
zheka is offline
post #191 of 675 Old 06-07-2012, 04:34 PM
Liked: 5687
The woofer also has a uniform radiation pattern, so Earl's thought is why have the HF and LF sections different? In truth it doesn't matter that much on the vertical plane, whereas having similar horizontal dispersion at the crossover frequency is. You can get that result with both HF section types.
post #192 of 675 Old 06-07-2012, 06:36 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
So is thetre any validity to Pi's narrow front lobe in symmetrical horns reasoning?
zheka is offline
post #193 of 675 Old 06-07-2012, 07:26 PM
Louis Bartay's Avatar
Quoted: 305 Post(s)
Liked: 713
Originally Posted by psgcdn View Post
I'll keep my 104 dB Klipschorns, thanks. They do music very well.
Ditto on my 1979 Klipsch Cornwalls(real wood cabinets) we purchased new. 102bd 1watt/1 meter. The Heritage Series Klipsch sound a lot
different from the newer towers they sell now.
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #194 of 675 Old 06-07-2012, 08:35 PM
Liked: 5687
Maybe, I lost interest by the end of page 1. Brevity is not only the soul of wit, it also keeps your audience awake.
post #195 of 675 Old 06-08-2012, 03:05 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
here is the relevant page
700
there is also a video on their site about it.
http://www.pispeakers.com/misc/Vertical_Nulls.wmv
zheka is offline
post #196 of 675 Old 06-08-2012, 03:21 PM
Liked: 5687
here is the relevant page...there is also a video on their site about it.
IMO much ado about not so much. Wayne and Earl both stand foursquare behind the type of horn that they sell, surprise surprise. Should they both show up here to debate their positions it would go on for days, if not weeks. rolleyes.gif
post #197 of 675 Old 06-08-2012, 07:04 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
in my situation, and I suspect this is fairly typical, vertical directivity is not that important because my speakers are on-axis in vertical plane.
this maybe a valid consideration for side surrounds however
zheka is offline
post #198 of 675 Old 06-08-2012, 07:43 PM
Liked: 5687
There are lies, there are damnable lies, and there are statistics. In this case substitute 'charts' for 'statistics'. The lobing shown on that chart is at a certain unspecified distance. What it doesn't show is vertical polar response at a typical listening distance, where said lobes would probably have disappeared. As with statistics charts can be configured to reinforce a particular point of view.
post #199 of 675 Old 06-08-2012, 07:49 PM
AJinFLA's Avatar
Liked: 24
So you don't hear all the floor and ceiling reflections (axes) and the total radiated power summation doesn't change the total tone, timbre, etc. perception at your ears?
AJinFLA is offline
post #200 of 675 Old 06-08-2012, 08:18 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Oops, bad choise of words. Sure vertical directivity is very important. I meant to say that off-axis vertical nulls is not an issue in my case.
zheka is offline
post #201 of 675 Old 06-08-2012, 08:20 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Good point
zheka is offline
post #202 of 675 Old 06-08-2012, 08:24 PM
AJinFLA's Avatar
Liked: 24
I would say "not as important" (as horz, which is why we have ears on side of head, not top/bottom smile.gif)....which is not the same as "not important".wink.gif
Point source guy or vertical line type?
cheers,
AJ
AJinFLA is offline
post #203 of 675 Old 06-09-2012, 01:45 AM
The 1812s?? Bipolar (asymmetric/variable) point sources. Dipole (asymmetric/variable) bass only.
And ya better start saving yer pennies.
That's a lot of pennies. Dug around a bit, looks like the 1812 Overture has evolved since the CapFest show.
The HE Monitor looks pretty interesting. Is this a high efficiency design?
post #204 of 675 Old 06-09-2012, 01:45 AM
Get some sturdy stands, and enjoy!
post #205 of 675 Old 06-09-2012, 01:51 AM
Or months, years! This thread would blow up.
post #206 of 675 Old 06-09-2012, 07:10 AM
AJinFLA's Avatar
Liked: 24
The 1812 will evolve further..and yes, not inexpensive. The HEMon is around 92db and was mainly a test bed for the HTMon, which is closer to a "production" item and will allow a horizontal (9" H) center.
The HET1 should be posted late this week and might be the optimal option from the lineup, if you need HE/high SPL capability for HT, etc. and can accommodate a vertical center
cheers,
AJ
AJinFLA is offline
post #207 of 675 Old 06-09-2012, 07:46 AM
Mike Garrett's Avatar
Quoted: 7060 Post(s)
Liked: 4768
Just to clarify for those that did not read the thread. The two High sensitivity speakers in the referenced thread were JTR T12's and Seaton Sound Catalysts. These two speakers are designed to be crossed to subs in the 60hz to 80hz range. They were run full range 2-channel, no subs and were compared with traditional 2-channel speakers.
Originally Posted by Nuance View Post
Incorrect. The Seaton Catlaysts had the bottoms "dropped out" and were tuned to 20hz. They had some serious low end capabilities. Also, the designer of the JTR's told me to not bother crossing them to subwoofers. All manufacturers that attended were aware we'd be running full range. I'm very appreciative that they attended, but lets not pretend we intentionally gave them an unfair advantage, because we didn't. Later that day we tried to connect the JTR's to the 2-channel preamp with subwoofers, and they were 12dB more sensitive than the GTG host's LMS5400 Ultra subwoofers. Since 2-channel preamps don't typically have level adjustments like receivers do, it made using the JTR's for a dedicated 2.2 channels setup completely impossible with those subwoofers and most traditional 2 or 2.1 channel music preamps. By the way, I intentionally left out which brands they were, as to not start a pi$$ing match. At least I can say you started it instead of me.
Since the topic of reference levels always seems to conincide with high-efficient/high-sensitive designs, here is what Floyd Toole says in his book regarding reference levels...He said (page 513, chapter 22):
"In rooms about 4000 cubic feet and under, well-designed conventional cone-dome loudspeakers should have no trouble achieving the required sound levels. In larger rooms, one must be more selective because some loudspeakers may exhibit distress or transducer failure. However, there are also some highly refined designs that can deliver substantial amounts of sound."
He then goes on to say:
"In very large rooms and in rooms where the customer feels a need for high sound levels much of the time, horn-loaded speakers are recommended."
Regarding reference levels he states this:
"With large woofers and compression-driver horns, the low distortion and an absence of power compression can lead to volume settings that put one's hearing at risk and it still does not sound loud." Toole also states that most people find reference levels "to be a bit loud - in both cinemas and their homes."
Anyway, it's just something to think about.
I am at a loss here, exactly what part of what I said is incorrect? I stated the two high sensitivity speakers that were used, correct. I stated that they are designed to be used with subs, correct. I stated that they were run full range, correct. I stated that they were compared to traditional 2 channel speakers, correct. I did not pass any judgement or make any comments. I left that for those that are interested or wanted the specifics, to read the thread. Yes the Seaton Cat, was set up using the DSP amp to provide a much lower f3, but that is not how that speaker was designed (optimized) to be run.
mjgarrett100@gmail.com
Mike Garrett is online now
post #208 of 675 Old 06-09-2012, 08:54 AM
Liked: 4768
It did. smile.gif There is an old thread on here from a few years ago where they went back and forth.
post #209 of 675 Old 06-09-2012, 08:54 AM
darkhorror's Avatar
You can't assume you hear the same as everyone else, what one person thinks is loud will be totally different from another person. So get what you like, but make sure you take a listen to a bunch of different speakers of different types. This will also change as your hearing changes.
darkhorror is offline
post #210 of 675 Old 06-09-2012, 10:46 AM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
cheers,
AJ
if you are asking about my personal preference, I have to admit that I lack experience to form an opinion in this regard.
SHO-10s are first CD speakers that I have in my listening room and they are not even broken in yet.
zheka is offline
Reply Speakers
