floorstanding speakers in the 1-2k range - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 151 Old 06-01-2012, 09:49 AM
Nethawk's Avatar
Liked: 119
Originally Posted by yveletnik View Post
after you find a speaker you like stop visiting audio forums and start listening to the music. take it from a person that's on 5th set of speakers in 7 months. actually getting ready to pull the plug on set #6
You really should have that problem looked into
Nethawk is offline
post #92 of 151 Old 06-01-2012, 10:06 AM - Thread Starter
lifeis11's Avatar
Originally Posted by John1400 View Post
I wonder what new members think when they come here and ask questions and look for advice and then they see all the s*** that follows?
Do they leave here more informed and content or more confused.
Simple questions turn into arguements and debates and then the graphs start coming in.
In the end, its kinda funny.
All I can say is TGIF!!
a little of both?
Paradigm Studio 100 Floorstanding Loudspeakers
REL R505 Subwoofer
Marantz PM8004 Integrated
Marantz SA8004 SACD
Rega P6 Turntable
Rega Exact 2 Cartridge
Cambridge Audio StreamMagic 6
Salamander Archetype 5.0 Equipment Rack
Chord ChameleonPlus, CobraPlus interconnect RCA
Legend Audio Bi-Wire...
lifeis11 is offline
post #93 of 151 Old 06-01-2012, 10:51 AM
AJinFLA's Avatar
Liked: 24
Originally Posted by AcuDefTechGuy View Post
Dynaudio is another "accurate" speaker company like KEF and Revel who believes in a great on-axis and off-axis and all the other measurements too.
I hope the smilie meant you were joking.
Maybe that's why we all need a few different systems for different music.
Shouldn't. One (pr) speaker should do it all...and not have other large objects affecting/impeding it's soundfield.
I'll use my KEF 201/2 for 5.1 movies, Phil3 for jazz/alternative, Orion for classical, Salon2 for pop/rock.
Now I need another set for Karaoke.
I know this would violate your speaker hoarding policy, but have you ever considered/tried any of the above in the family room to see if they are capable (acoustically) of filling the desired roll?
Btw, my speakers were suggested to lifeis11 earlier in the thread (thanks Saturn). I would suggest otherwise. Not because they won't "sound great" with rock, but I think there are better choices for him.
If lifeis11 is in the NY area, I would suggest a trip here to hear these instead.
My 2c.
cheers,
AJ
AJinFLA is offline
post #94 of 151 Old 06-01-2012, 10:56 AM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
My 2c.
cheers,
AJ
AJ,
you make just the one speaker? Is the coaxial mid/tweeter array the same one that Kef uses?
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
post #95 of 151 Old 06-01-2012, 11:16 AM
AJinFLA's Avatar
Liked: 24
Originally Posted by callas01 View Post
AJ,
No, two are needed for stereo.
I have a couple models (unfortunately not the female variety) I'm working on, none yet quite ready for prime time. Coming soon...
On the Monitor1, yes, KEF did a heck of a job developing those for me.
cheers,
AJ
AJinFLA is offline
post #96 of 151 Old 06-01-2012, 11:20 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Isn't Dynaudio accurate? I saw some of their measurements on Soundstage and they looked great.
Now here I was joking. Yes, 1 great pr speaker should be able to do it all.
Salon2 for karaoke?
I'm using the P362 in the family room for this role.
It works fine.
But let's face it.
It's time to stack the family room.
AcuDefTechGuy is offline
post #97 of 151 Old 06-01-2012, 11:21 AM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
I guess I stepped right into that one.
What would sorta make sense (hence strictly taboo on an audio site), is if folks sort of compiled a list and said, try to hear these yourself if you can. They have good basic measured parameters (no large amplitude deviations in say a 30 degree "listening window", no 0.5 ohm dips with crazy phase angles, no cardboard enclosures, bondo, etc, etc, etc.), I heard them and they "sounded great" to me in this room. Instead of - I like or own these things and so they are the greatest thing since slice bread because I like or own them. Or something to that effect. All while being slightly cognizant that the guy asking for two small narrow towers to appease the Mrs. doesn't want three Klipschorns across the front.
cheers,
AJ
+1!
Maybe KEF is not flat.
Maybe SongTowers are not flat.
Maybe they both are not flat....
Actually, none is perfectly flat, and those differences can be quite audible.
and from myself:
Best advice ever!
Saturn94 is offline
post #98 of 151 Old 06-01-2012, 01:34 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
for the most part yes they are. However with some of the anniversary units they built them to be a little more "fun" if you will, so you might see with the Special 25s and Sapphires that their FR have some elevated lower trebbles plots. I know with the Sapphires with the grills on, they measure pretty flat, but with them off, they have a rise. typically tho, when you see their measurements for the Contours, Excites, Focus, Evidence and Confidence lines they have pretty flat FR's.
post #99 of 151 Old 06-01-2012, 06:12 PM
AJinFLA's Avatar
Liked: 24
From a measurements standpoint, they fall into the (very crowded) "dome over cone on flat baffle" paradigm...and all that entails.
That's why measurements are a double edged sword. They are easily misinterpreted and very often misunderstood.
I'll pick an example from Soundstage: http://www.soundstagemagazine.com/me...confidence_c4/ Not too shabby eh? (btw, this is a near statement product IIRC)
Salon2 for karaoke?
It's going to have to go somewhere when you clear the other room for the 1812s. Out the door?
It works fine.
But let's face it.
Gotcha. I thought there was some perceived deficiency that was prompting looks at Hi-eff, etc. type designs.
Perhaps more related to the signal being fed the microphone?
cheers,
AJ
AJinFLA is offline
post #100 of 151 Old 06-01-2012, 08:39 PM
Quoted: 175 Post(s)
Liked: 262
What is wrong with that Dynaudio anyway?
Maybe.
Why you.........
post #101 of 151 Old 06-01-2012, 09:06 PM
AJinFLA's Avatar
Liked: 24
Based on the Soundstage measurements, not much right? You did say you saw excellent measures on Soundstage, was/is this one? (Don't worry, no hole filled with wooden spikes under these leaves).
cheers,
AJ
AJinFLA is offline
post #102 of 151 Old 06-01-2012, 09:33 PM
Nuance's Avatar
Quoted: 22 Post(s)
Liked: 79
Measurements are a great asset/tool guys, but isn't it all about how they sound in our rooms in the end? I'm playing devil's advocate here, because we all know I am a fan of measurements, but there's more to it than just that.
For what it's worth, when I heard the Dynaudio C4 Mark II's I enjoyed them quite a bit. I also enjoyed the Sapphires, though not nearly as much because they had midrange and lower treble bite.
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #103 of 151 Old 06-01-2012, 10:39 PM
kwarny's Avatar
cheers,
AJ
Are you referring to no vertical off-axis measurements or does it deal with the off-axis mismatch between tweeter and mid? Without the hole, I probably still rolled my ankle on the smallest twig.
The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge - Stephen Hawking
Kyle Bosso - SOB
kwarny is offline
post #104 of 151 Old 06-02-2012, 07:04 AM
Quoted: 175 Post(s)
Liked: 262
cheers,
AJ
Yes. Dynaudio C4. But I just saw the C1, and I change my mind about Dynaudio being very "accurate".
post #105 of 151 Old 06-02-2012, 08:15 AM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
I would never try to change someones mind, cause really I dont care enough to try, but it seems that Stereophiles John Atkinson feels differently
Like Nuance said, the sound of the speakers speak for themselves. However some might like the tipped up sound of the anniversary units or the more neutral sound of the standards.
to each their own.
post #106 of 151 Old 06-02-2012, 09:28 AM
AJinFLA's Avatar
Liked: 24
Yes. Dynaudio C4.
Fair enough. Looked pretty good.
Ok, how about something more like this speaker?
Would you also expect it to sound quite different depending on room, ok in a very large one, maybe a show or showroom type setting, then suddenly quite different at home in your room? Maybe have you thinking about taming your "room problems" with those band-aid/gauze things on the wall (to somehow cure just that flare while leaving everything else miraculously untouched) or maybe some cable lifters?
cheers,
AJ
AJinFLA is offline
post #107 of 151 Old 06-02-2012, 09:49 AM
Quoted: 175 Post(s)
Liked: 262
The C1 off-axis response does not look very smooth. Is that a 3kHz "bubble" or rise in energy that could be problematic?
post #108 of 151 Old 06-02-2012, 11:43 AM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
I guess I dont know what youre looking at.
when I look at these measurements, I get that its not a flat FR speaker, there are rises on both ends and a sharp dip in the middle.
http://www.stereophile.com/content/p...r-measurements
however I look at this one and it seems to have a much flatter, more accurate FR.
http://www.stereophile.com/content/d...r-measurements
Then I see this, and I think, wow, from a speaker that costs that much?
http://www.stereophile.com/content/b...r-measurements
post #109 of 151 Old 06-02-2012, 12:23 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
You also have to understand how Stereophile does it's measurements, especially on the bass end.
The way they measure and splice in the results creates a "hump" on the bass side. This is explained somewhere on their site.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #110 of 151 Old 06-02-2012, 02:29 PM
AJinFLA's Avatar
Liked: 24
That is his opinion of the data, quite often a diplomatic one irreconcilable with what is shown.
As do the measurements, since they are one in the same. The measurements being viewed are that of sound waves. At least that portion of the hearing process is being assessed.
to each their own.
Indeed to the latter part, but how exactly would one determine "neutrality"? What sort of neutrality? Measured? Perceptually?
Especially given the fact that snapshots of the sound waves indicate otherwise? Why do you feel an acoustic source with such an excess power peak in an very audible area, would be somehow "neutral"?
cheers,
AJ
AJinFLA is offline
post #111 of 151 Old 06-02-2012, 02:52 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
I don't know of any speaker engineer, worth any salt, that would rely on measurements alone.
Correlating measurements to what they hear is a different story, and does not mean they are one in the same.
-curtis
cschang is offline
post #112 of 151 Old 06-02-2012, 03:01 PM
AJinFLA's Avatar
Liked: 24
I don't know of anyone who took logic and remembered it worth a salt, that would commit such Red Herring and Strawman fallacies.
Either that or read slower. Ask questions.
cheers,
AJ
AJinFLA is offline
post #113 of 151 Old 06-02-2012, 03:08 PM
oldschool46's Avatar
Quoted: 13 Post(s)
I finally finished my comparison, so you can ask any questions there:
http://forums.audioholics.com/forums/888112-post39.html
I have to agree with your comments regarding the song towers. I found them to be very electronic and edgy sounding. They also had a very unnatural echo to the soundfield. The song ( you and your friend) by dire straits really stuck out in a unnatural way. But I am sure it was because of the recording.
oldschool46 is offline
post #114 of 151 Old 06-02-2012, 03:11 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
cheers,
AJ
OK...
You posted this:
Measurements, in your sentence, are one in the same as what? How a speaker sounds...correct? And each "speak" for themselves...is that also correct? There is a correlation.
AJ...as a speaker engineer/designer, with your personal hearing, how do you determine if what you hear is correct or what you expect from your design?
-curtis
cschang is offline
post #115 of 151 Old 06-02-2012, 03:32 PM
AJinFLA's Avatar
Liked: 24
Measurements.
The only time I listen to a speaker after its been already designed (by measurements) and built, is (after measuring individually to see if there are any phase/components problems) right before packing them into their shipping boxes. Just to make sure there are no screws loose (in the speaker i.e.), leaks, etc.
Those are measurable too, but listening is a heck of a lot quicker and easier to do when it comes to rattles and squeaks.
Which would mean that a) You don't know me, b) I'm not worth a salt.
(Plus I'm not really an engineer, but I do play one on TV).
cheers,
AJ
AJinFLA is offline
post #116 of 151 Old 06-02-2012, 03:57 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Measurements.
What do your measurements need to match? The measurements on your site are limited.
After hearing the R300, I am interested in your speaker. How do they differ?
In reading your website, you state that you are regular attendee of classical and jazz performances at the USF school of music. What is the significance of that in your designs?
-curtis
cschang is offline
post #117 of 151 Old 06-02-2012, 03:59 PM
smasher50's Avatar
Quoted: 379 Post(s)
Liked: 19205
imo you can throw measurments and graphs out the window. until you put a pair of speakers in "your"size room with "your" tables "your" seating arangements and "your" other furnishings you could have the best measured speaker out there and if its not in an enviroment that suits it, its not going to sound the same as it did when it first measured. just my 2 cents
i'm so laid back,i'm laid out
smasher50 is offline
post #118 of 151 Old 06-02-2012, 04:21 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
How do you propose to shop for speakers?
You need to start somewhere.
-curtis
cschang is offline
post #119 of 151 Old 06-02-2012, 04:35 PM
AJinFLA's Avatar
Liked: 24
My targets for maximum smoothness in the polar field.
Indeed. Part laziness, part busy-ness(full time "real" job), part not wanting to confuse with it's double edged nature.
I would hazard to guess mine are possibly more potent in the bass, having a larger driver/being active, etc., but I really don't know that much about the R300.
It means that I enjoy listening to classical and jazz music.
Here's a question for you Curtis. I notice a lot of your posts involving me tend to focus on "me", rather than say, the measurements of certain Dynaudios and their lateral responses, sound power peaking, etc.
What rule of logic guides you in that direction? Would anything I said previously about, say, Ascend, consciously or subconsciously, dictate the compass?
Just curious.
cheers,
AJ
AJinFLA is offline
post #120 of 151 Old 06-02-2012, 04:48 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Just curious.
cheers,
AJ
Quite simple. You focus on measurements of said speakers. I think many of us would like to compare the measurements to your speakers, but there are no comparable measurements. So instead, all we have is the things you post and your behavior. My mention of limited measurements on your site alludes to that.
I am truly interested in your speakers, and would like to see some of that information. I understand the double-edged nature, but you analyze the measurements of other products, why not allow the same for yours?. While I may not like your online personality, I do like your objective approach, but I would also like to know if any subjectiveness comes into play, which is why I asked the question about your love of classical and jazz music, and how that comes into play with your designs.
-curtis
cschang is offline
Reply Speakers
