Recommended power to drive Polk RTi-A7 (aka RTi-10) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-01-2012, 11:33 AM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
Someone locally has a set of mint Polk RTi-A7 floorstanding speakers. I am probably going to pick these up to replace my Monitor 60s.
Right now I run the Monitor 60s in bi-amp from an Onkyo TX-SR606 (90W RMS per channel @ 8ohms, 20-20000Hz). Will this be enough horsepower to sufficiently drive the RTi-A7s? The receiver is not true 90WPC in 5.1/7.1.
The M60 is 3x5.25" and 1x1.00", 90dB efficient. The A7 is 2x7.00", 1x6.50", 1x1.00", 89dB efficient.
Marantz AVR & monoblocks + MartinLogan Motion 3.1 setup
TheGSRGuy is offline
post #2 of 2 Old 06-01-2012, 04:02 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Are you crossing these to a sub at 80hz, or running them full range? The triple 7" woofers don't take over until 120hz if I recall correctly. There might be some moderate strain on the lower mid bass, but they arent a tough speaker unless used full range.
Jay1 is offline
Reply Speakers
Polk Audio Rti A7 Floorstanding Speaker Single Cherry , Polk Audio Rti A7 Floorstanding Speaker
