Silk Dome Tweeters - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 06-04-2012, 12:41 PM - Thread Starter
LowTech1's Avatar
Quoted: 1136 Post(s)
Liked: 269
Which speaker companies use them?
LowTech1 is offline
post #2 of 20 Old 06-04-2012, 01:31 PM
pokekevin's Avatar
Liked: 102
I know Atlantic tech and Triad do
pokekevin is offline
post #3 of 20 Old 06-04-2012, 01:53 PM - Thread Starter
LowTech1's Avatar
Liked: 269
Silk dome tweeters just have a smoother sound I think. They use them a lot in car speakers..
LowTech1 is offline
post #4 of 20 Old 06-04-2012, 01:59 PM
pokekevin's Avatar
Liked: 102
Ok?
post #5 of 20 Old 06-04-2012, 02:09 PM - Thread Starter
LowTech1's Avatar
Liked: 269
I'm just wondering why they aren't used more in home applications..
LowTech1 is offline
post #6 of 20 Old 06-04-2012, 02:37 PM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
Some Polk speakers (Lsi) has silk dome tweeter, Dayton, EMP, and quite a few others. Isn't that one of the more common tweeter used?
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #7 of 20 Old 06-04-2012, 02:47 PM - Thread Starter
LowTech1's Avatar
Liked: 269
I thought most were aluminum tweeters. I have Martin logan Electromotion ESL's so it doesn't matter,but I was curious..
LowTech1 is offline
post #8 of 20 Old 06-04-2012, 03:19 PM
Nethawk's Avatar
Liked: 118
Well, whoda thunk it?
Vegetarian Speakers site has several manufacturers that include silk domes. Swan, Mordaunt Short, Wharfedale, Totem (some of my favorite manufacturers) all use silk in their products (but not exclusively).
Nethawk is offline
post #9 of 20 Old 06-04-2012, 03:45 PM - Thread Starter
LowTech1's Avatar
Liked: 269
LowTech1 is offline
post #10 of 20 Old 06-04-2012, 03:48 PM
65 Electra Glide's Avatar
Quoted: 78 Post(s)
Liked: 50
Virtually all ID speaker brands only offer silk for their dome tweeters. I can only think of one ID brand off the top of my head that even offers metal dome tweeters at all.
65 Electra Glide is offline
post #11 of 20 Old 06-04-2012, 04:15 PM - Thread Starter
LowTech1's Avatar
Liked: 269
How do you know that? I read most use aluminum..
LowTech1 is offline
post #12 of 20 Old 06-04-2012, 04:22 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 461
dynaudio uses silk dome tweeters.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
post #13 of 20 Old 06-04-2012, 04:28 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 461
Check this out.
http://www.goodsound.com/index.php?o...k-us&Itemid=77
like this article points out, I wouldnt worry about the material used, I would go with what sounds best to you. I have heard great and terrible speakers that use both types of materials.
post #14 of 20 Old 06-04-2012, 05:18 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Originally Posted by callas01 View Post
like this article points out, i wouldnt worry about the material used, i would go with what sounds best to you. I have heard great and terrible speakers that use both types of materials.
x2
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #15 of 20 Old 06-05-2012, 02:09 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Where did you read this? You can just go to each mfg site and check the specs.
jdcrox is offline
post #16 of 20 Old 06-05-2012, 02:19 AM
Browninggold's Avatar
Liked: 37
Aperion uses Silk dome. I owned 3 6Ts across the front. Now I own 3 Klipsch RF7IIs across the front. I personally like the horns of the Klipsch. I would recommend listening to both if you can. Aperion has free shipping both ways...try them risk free
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
post #17 of 20 Old 06-06-2012, 03:22 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
I've had several sets with aluminum and silk. I couldn't tell a difference. Polk, EMP Tek, Dayton... You'll find a lot of silk dome tweeters in car audio as well.
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
post #18 of 20 Old 06-06-2012, 01:04 PM - Thread Starter
LowTech1's Avatar
Liked: 269
klipsch horn speakers are pretty bright and can be shrill. What kind of music are those things good for?
LowTech1 is offline
post #19 of 20 Old 01-26-2013, 04:05 AM
Liked: 37
Rumor...we listen all day as the Klipschs are setup in the Living Room. Best speakers I have owned excellent for music and home theatre
post #20 of 20 Old 01-26-2013, 07:54 AM
Paraneer's Avatar
Quoted: 23 Post(s)
Liked: 73
In addition to all mentioned above and the ID companies too, here are ten more speakers manufacturers that use silk or soft dome tweeters too...
Vienna Acoustics
Dynaudio
Sonus Faber
Wharfedale
Quad L series
Spendor
Harbeth
Epos
Joseph Audio
Cambridge Audio
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
Reply Speakers
