Speaker wall mounts for radio shack Optimus pro 77s? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-06-2012, 02:19 PM - Thread Starter
dunan's Avatar
Quoted: 62 Post(s)
I'm looking for mounts that I can tilt and rotate that will in the future hold some paradigm mini monitors or atoms but for the moment will hold a pair of RS Optimus pro 77s.
The problem right off the bat is the Optimus's have nothing but a small screw hook at the top of the speaker on the back next to a tiny port. Maybe something that can clamp, or screw also, that would be ideal.
I looked at stands and mounts.com but can't see the capabilities of the mounts very well from my phone at the moment. Any help would be greatly appreciated!
Oh and something that won't break the bank, hopefully not much more than 50$ if possible.
dunan is offline
post #2 of 6 Old 06-06-2012, 02:37 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Take a look at the Pinpoint AM-40 clamp mount.
http://www.amazon.com/Pinpoint-AM-40B-Clamping-Bookshelf-Speaker/dp/B002UV03MW/ref=sr_1_1?ie=UTF8&qid=1339018597&sr=8-1
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #3 of 6 Old 06-06-2012, 02:55 PM - Thread Starter
dunan's Avatar
Quoted: 62 Post(s)
Thanks, Pete HSU recommended those before but I couldn't find the link. Do they rotate/tilt up & down/side to side?
The goal is to mount all my components also so if you know of any wall mounted 'shelves' that would hold a paradigm cc-290 center, an AVR, and some DVD players that would be great also biggrin.gif
dunan is offline
post #4 of 6 Old 06-06-2012, 07:42 PM - Thread Starter
dunan's Avatar
Quoted: 62 Post(s)
Nothing else I could use?
dunan is offline
post #5 of 6 Old 06-06-2012, 10:19 PM
wlhungdude's Avatar
Quoted: 189 Post(s)
Liked: 237
hi Dunan,
Those Pinpoint mounts fit your needs perfectly. I use a pair for my rear speakers. Shop around, including cash back sites, to get the best final price.
Buy the right tool once. Or buy a cheap tool, then it's replacement, then the one you should've bought the first time.
Joseph
mods, can we have a 'dislike' button ?
wlhungdude is online now
post #6 of 6 Old 06-07-2012, 02:44 PM - Thread Starter
dunan's Avatar
Quoted: 62 Post(s)
Awesome, thanks.
I found these for my titans also:
Rocelco B-Tech Rocelco BT77
Do they make a wall mountable center channel 'shelf' that I can mount my cc-290 center on?
dunan is offline
Reply Speakers
