Important of matching rear speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-08-2012, 05:11 AM - Thread Starter
BBCheese's Avatar
Recently the tweeter on my 10 yr old Onkyo left speaker stopped working. As well as getting a new receiver, figured it was a good time to upgrade my speakers.
Since money is a bit tight, I was wondering how important matching rear speakers are.
My current speakers are from the Onkyo 520 HTiB. And my replacement fronts would be the Polk Series 2 CS2 center and the Monitor50s.
BBCheese is offline
post #2 of 9 Old 06-08-2012, 06:34 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
I would suggest that you get the CS20 center speaker; it is the best center speaker for using with the Monitor 50s.
While the rear speakers do not tend to be super-critical, I would suggest that you get a set of Monitor 40s when the money becomes available; they are very good for their price.
commsysman is offline
post #3 of 9 Old 06-08-2012, 06:48 AM - Thread Starter
BBCheese's Avatar
Is the CS20 that much of a critical upgrade? It is currently twice as much as the CS2. Is it better to get CS20 and less expensive LR speakers or my original upgrade setup?
BBCheese is offline
post #4 of 9 Old 06-08-2012, 02:18 PM
fookoo_2010's Avatar
Quoted: 245 Post(s)
Liked: 84
Cost is always a concern. It must have been over 3 years ago, I bought Polk R50's that seem to be the same as the speakers that you are thinking of purchasing. It is highly preferable to match the center speaker to the same drivers as are in the fronts. I would not suggest buying something because it is cheaper, unless you are willing to ditch that center down the line when you have more funds. My R50's ran $70 each. In a home theater system, the most dominate speaker is the center speaker and you will not know the difference until you change it out to something better. I would hold off on buying a center speaker and just use the center from the Onkyo HTIB until the time that you have more funds.
Another possibility for your fronts would be Infinity P363s which are now on sale at Fry's for < $200 for a pair of them. That's $100 each+tax. You will need an AVR which puts out a real 100 watts/channel. Add to your system as you can afford it with the Infinity center PC350 or PC351 and the Infinity bookshelves P153s or P163s as your surrounds, sometimes onsale on Amazon or elsewhere, like @$49.
For its price, the R50s were more than worthwhile at the time, but I have ditched all of them at least two+ years ago - and I bought six of them. Don't forget the sub. Just put your system together in pieces - I know that it is hard, but the reward makes it worthwhile, unfortunately users want it now. Or you can go with the upgrade path overtime and spend more money. I started with an Onkyo HTIB system and all of it is long gone through a series of upgrades. So I am giving you practical advice based upon direct experience.
fookoo_2010 is offline
post #5 of 9 Old 06-08-2012, 04:31 PM - Thread Starter
BBCheese's Avatar
Thanks for the help. With that in mind I guess I'll just upgrade piece by piece. Hope the sounds aren't too strange moving from speaker to speaker.
Is this
http://www.amazon.com/Polk-Audio-Center-Channel-Speaker/dp/tech-data/B0018QNYSU/ref=de_a_smtd
the same as
http://www.crutchfield.com/p_107CS20B/Polk-Audio-TSi-CS20-Black.html ?
May seem like a dumb question but just making sure as one will save my 30 dollars.
BBCheese is offline
post #6 of 9 Old 06-08-2012, 05:32 PM
Quoted: 245 Post(s)
Liked: 84
Looks the same.
post #7 of 9 Old 06-08-2012, 07:08 PM
Acuramusic42's Avatar
For time being may I suggest: http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
along with: http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
With these in the rear: http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
You could upgrade later and sell this.
Just a thought.
Onkyo TX-NR5009, Emotiva XPA-2 & XPA-5, Oppo 103D Blu-Ray Player, Marantz 6004 CD, Teac V 670 Cassette Player, Pioneer CLD-D704 Laser Player, JVC HM-DH3000U VCR, Technics SL1200MK2 Turntable, Belkin PF 60 Power Conditioner, Comcast Infinity X-1, XBOX 360, 2 PSA XV-15se Subs, Chane A5rxc Main , Chane A2.4 Center Spk, Chane A 1.4 Side Spk, JBL Studio 220 Rear Spk, BIC DV 62si Height Spk, Sony 43X830C TV. Harmony Elite Remote.
Acuramusic42 is offline
post #8 of 9 Old 06-09-2012, 05:47 AM - Thread Starter
BBCheese's Avatar
Just a thought.
Think the first two you linked are LR speakers.
BBCheese is offline
post #9 of 9 Old 06-09-2012, 06:35 AM - Thread Starter
BBCheese's Avatar
I think I've decided to go with the Monitor40s and the CS1 (or 2, not sure yet). Think it fits my situation better. Tight budget, living in an apartment, already have stand for my current fronts and whatever money I save/don't use I can use to upgrade my woofer and rears down the line. Or replace the LR fronts and use the 40s for rears.
Don't know much about receiver wattage but my Denon 1612 and the CS2 is well over that.
BBCheese is offline
Reply Speakers
