Do Good Wireless Surround Systems Exist? Also Recommendations Please? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-09-2012, 11:39 AM - Thread Starter
ImThat1Guy's Avatar
Hi everyone, I'm bad at making short thread titles.
As a few of you who have browsed the Home Theater Computers section may know, I'm planning on building an HTPC. And I may well overhaul the audio systems too. We've got a crappy Sony setup that we actually haven't used in several years because of the poor quality and the large, annoying cables.
So, I've begun a bit of research on home audio systems. I'd like 5.1 or, better yet, 7.1 surround. Having a cableless system isn't that important, but if I could get similar quality for no more than $50-100 more, I'd definitely do it.
I also plan running it off audio directly from my motherboard. Sorry audiophiles. A sound card will likely come later, and I'm really not a fan of external solutions, so yeah. Unless you guys convince me that I need one.
The budget is probably around $300, with, as I said, $50-100 more if it's really worth it and/or (preferably and) it's wireless.
Thanks all!
ImThat1Guy is offline
post #2 of 4 Old 06-09-2012, 12:56 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
There really won't be any good setups that are wireless in your price range. Honestly, I'd up your budget for a wired setup as well. $300 won't offer you much.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
post #3 of 4 Old 06-09-2012, 01:11 PM - Thread Starter
ImThat1Guy's Avatar
I've heard Onkyo is pretty alright. This 7.1 setup is $400, and this 5.1 one is $250.
I dunno what I'd do with the DVD player, though. Would I need that?
Also, here seems to be a good amount of nice speaker systems, none of which are wireless but I don't actually care that much.
Or would it be better to get individual speakers, which hopefully you guys could recommend?
post #4 of 4 Old 06-10-2012, 05:33 PM - Thread Starter
ImThat1Guy's Avatar
It's been over a day. Any other input?
Reply Speakers
