Same Speakers for Surround AND Whole-House Audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-10-2012, 02:29 PM - Thread Starter
lahatte's Avatar
I would like to be able to use two of my home theater speakers with the whole-house-audio system. Basically, they could serve double duty in this regard. In other words, if the theater system isn't being used, the speakers could play sound from the whole-house-audio system. Otherwise, I would need 'additional' speaker mounted in the room just for the whole-house-audio.
I am having difficulty coming up with a good way to do this, while keeping the signal sources isolated from each other. I don't want the signal from the theater amp, for example, feeding to the whole house amp via the speaker connection.
Any thoughts on this are appreciated.
lahatte is offline
post #2 of 6 Old 06-11-2012, 02:13 PM - Thread Starter
lahatte's Avatar
No one has any knowledge about this issue? Surely this is a common thing to need?
lahatte is offline
post #3 of 6 Old 06-12-2012, 09:48 AM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
Robert Cook is offline
post #4 of 6 Old 06-12-2012, 12:05 PM - Thread Starter
lahatte's Avatar
Thanks. The last one looks like a weiner (winner). I'll have to investigate it.
I have also considered using a dual voice coil speaker, with one coil to each source (would use two of these for stereo).
Clay
lahatte is offline
post #5 of 6 Old 06-12-2012, 12:06 PM - Thread Starter
lahatte's Avatar
I suppose the related question is, how do other people typically get whole-house-audio into the theater room? Do they just add more speakers specifically for the WHA?
lahatte is offline
post #6 of 6 Old 06-13-2012, 07:35 AM
Quoted: 34 Post(s)
Liked: 55
There must be a great variety of configurations out there, but if I had to guess about the general case, I'd suppose that most people wouldn't have a separate WHA system, basing theirs instead on their HT system. They may, for example, add speakers to other rooms with the Zone 2 speaker outputs, or feed their pre-amp outputs into separate amps to power speakers throughout the rest of the house, while the HT speakers provide audio for the HT room.
Reply Speakers
