definitive promonitor 1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-12-2012, 02:45 AM - Thread Starter
Ganesh Easwer's Avatar
Hi, I recently bought 4 definitive promonitor 1000 speakers to set up a 5.1 system. I have also taken definitive CS-8040 for the centre speakers. All bought from Best Buy. Will the system blend well? These are hooked to Yamaha RX-671.
Ganesh Easwer is offline
post #2 of 9 Old 06-12-2012, 04:35 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
I can't imagine it wouldn't. Promonitors are great speakers.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #3 of 9 Old 06-12-2012, 10:14 AM
flint350's Avatar
Liked: 45
I recently added a pair of Pro Monitor 1000's as the Wide speakers in my 9.1 setup.  My original 7.1 speakers are Def Tech towers (BP7002, CLR 3000, BPVX and SVS Sub).  Needing a pair of direct radiators now, the Pro Monitor 1000 seemed to be the best bet to blend in with the others.  So far, initial testing is very positive.  I notice no timbre matching issues and the wide soundfield is incredible.  If I ever add the last 2 Height channels, I will likely stick with these.
Ray
"You cannot reason a person out of a position he did not reason himself into in the first place." -Jonathan Swift
flint350 is offline
post #4 of 9 Old 06-12-2012, 09:17 PM - Thread Starter
Thankyou. So, the promonitor 1000 and the CS-8040 centre speakers will work fine for my 5.1 or 7.1 (i might add 2 more speakers if required)
post #5 of 9 Old 06-12-2012, 09:27 PM
zieglj01's Avatar
Quoted: 1422 Post(s)
Liked: 1261
You were not interested in the Definitive SM45 speakers?
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Harman Kardon Ten > Boston VS240 -- Receiver > Integra 50.2
zieglj01 is online now
post #6 of 9 Old 09-25-2012, 11:12 AM
hugh newman's Avatar
I have the CS-8080 on the way and need to decide on front speakers and surrounds. I do have a subwoofer as well.
I am considering either Four x promonitor 1000's.
Also considering SM55 for the front speakers, and two 1000's as the surrounds.
Would I be better off with SM55 up front rather than 1000's? Doing a lot of research and having a tough time deciding which the fronts should be.
hugh newman is offline
post #7 of 9 Old 09-25-2012, 11:25 AM
yaomizzle's Avatar
Liked: 27
8080st fronts :-D
Sent from my GT-P7510 using Tapatalk 2
yaomizzle is offline
post #8 of 9 Old 09-25-2012, 11:30 AM
I wish! I am going to have to go out and save some babies from some burning buildings to deserve 8080st fronts!!
my budget is pretty blown at this point haha - promonitor or studio monitor price range...
Pioneer vsx-42 is my amp, and small room by the way.
thanks for your help!
post #9 of 9 Old 09-25-2012, 08:41 PM
yaomizzle's Avatar
Liked: 27
Saving babies could be arranged o.O the studio monitors are freaking sweet I'd +1 em
Reply Speakers
