The Pyles Speakers Any Good? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-17-2012, 05:46 PM - Thread Starter
Denon_Kid's Avatar
need some advice on these
just wondering if these provide good bass without being overly bright from the horn? i plan to use them for my weekly tailgating outing at local park, playing music from iPod/XM and for watching DVD movies. a PA is usually good for the vocal range, but i am wanting something that is full range and can give some oooomf down low for music and movies, etc.
http://www.provantage.com/pyle-pphp1593~7PYLE0A1.htm
Denon_Kid is offline
post #2 of 9 Old 06-17-2012, 05:53 PM
gregzoll's Avatar
Liked: 33
You must be planning on getting to know the local PD. 500 watts is a lot of power. Especially for "tailgating". Hope you plan on having some way to power the amp that you will need to power them.
gregzoll is offline
post #3 of 9 Old 06-17-2012, 06:29 PM
Bill Fitzmaurice's Avatar
Liked: 5624
No. Pyle is cheap junk. A decent speaker of this type will cost at least twice what these do.
Bill Fitzmaurice is offline
post #4 of 9 Old 06-17-2012, 06:35 PM - Thread Starter
Denon_Kid's Avatar
i am buying Pyle multi-featured amp PWMA3003T
power will come from one of two sources, either the park allows me to use extension cord to an outlet, or, i have part #'s of what i need to build battery powered setup (4 marine batteries for 48vdc, and a 48vdc to 220vac 3000watt continuous pure sine wave inverter).
i dont plan to use max volume all the time.
Bill, its hard to get good info on these Pyle speakers. many reviews online that are good reviews, then i see posts like yours. yes, at just $92 per unit it does seem cheap, but would they serve the purpose?
what about this Behringer EUROLIVE B215XL??
http://www.amazon.com/Behringer-EUROLIVE-B215XL-1000-Watt-Compression/dp/B0023C6H64/ref=sr_1_5?s=musical-instruments&ie=UTF8&qid=1339983567&sr=1-5&keywords=berhinger+speakers
post #5 of 9 Old 06-18-2012, 02:40 AM
keyboardcat's Avatar
if you don;t like them return it. I had a friend whos dad owned a car audio store. He had pyle subs in his room in a speaker box with the mid range and tweeter for a little bit. For a cheap speaker it sounded good to me for rap. A lot of people say that the pyle amps are junk and catch on fire. The speaker sounded fine to me. I never heard a pyle dj speaker though. it should be fine.
keyboardcat is offline
post #6 of 9 Old 06-18-2012, 04:53 AM
Liked: 5624
You're looking at what's mainly used by DJs. You can get opinions about DJ gear here:
http://www.djforums.com/forums/forumdisplay.php?60-Amps-Speakers
post #7 of 9 Old 06-18-2012, 05:30 AM
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
When Pyle makes a good speaker it will be the first!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #8 of 9 Old 06-18-2012, 07:31 AM
Liked: 5624
Pyle doesn't 'make' anything. Once upon a time they had a factory, made drivers, but for many years they've only been a marketing operation, sourcing everything. And they pretty much source it all from the lowest bidder, so the quality factor is non-existent.
post #9 of 9 Old 06-18-2012, 04:37 PM
Dave1027's Avatar
Quoted: 12 Post(s)
"Steaming Pyle" comes to mind
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
Reply Speakers
