Center Channel Placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-17-2012, 08:50 PM - Thread Starter
Anhydro's Avatar
I'm looking at a piece of furniture with a space for a larger, upgraded speaker, but am wondering if the speaker will be too low. The furniture is 22 inches high, which places the center channel somewhere between 13 and 21 inches off of the floor. I can tilt it up, but wasn't sure if this would be sufficient. (My current center channel is only 5 inches high and sits on top of a 25 inch piece of furniture, which works just fine with my 65 inch display on a stand.) Ideally, I woould like the display sitting a bit lower than it is now, but didn't really think through the audio and visual trade-offs. I know this isn't a new "problem," just one I haven't experienced before. I would appreciate any solutions or opinions, since the upgraded center channel and furniture will set me back a few bucks. Thanks!
Anhydro is offline
post #2 of 4 Old 06-18-2012, 03:37 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
Whether this would work for you is a personal matter, but I think that 21" is high enough, and I'd recommend that you tilt the center up until it points at the average ear level at your viewing distance (shouldn't take much).
Robert Cook is offline
post #3 of 4 Old 06-18-2012, 06:15 PM - Thread Starter
Anhydro's Avatar
Thanks for the advice.
Anhydro is offline
post #4 of 4 Old 06-19-2012, 11:26 AM
chikoo's Avatar
tilt would work just fine.
Or if you can, make the center stand vertically on the floor. I did that and enjoy it more than tilting it.
chikoo is offline
Reply Speakers
