Just Bought Atlantic Technology 2400LR - AVS Forum
post #1 of 9 Old 06-18-2012, 09:25 AM - Thread Starter
junoonis's Avatar
Hello, My first post in the audio section. Hopefully I am posting in the right section. I just bought Atlantic Technology 2400LR for only $169, I thought that was an amazing deal. Just received the shipment and I must say the built quality is amazing. Hookup was pretty simple with my old Denon AVR2700 receiver. Put on my favorite CD and sound is pretty good but I was expecting to be blown away which did not happen. The sound seems very thin and not fully filled. I don't have a Sub yet, could that be a reason for the average sound? Will adding a sub will completely change the way they sound? or is it really my amp that needs to be upgraded? I really like the deal and don't want to return these speakers. I need some expert opinions.
junoonis is offline
post #2 of 9 Old 06-18-2012, 09:51 AM
zieglj01's Avatar
Quoted: 99 Post(s)
Liked: 370
They were made to work with a subwoofer - once you get a sub, the sound
will be more full and balanced - the speakers are good.
__________________________________________
Who and Where - is the Way, the Truth and the Life?
Speakers > MB Quart VS05, Boston VS260, Snell K7
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PA-R200, Pioneer VSX-30
zieglj01 is offline
post #3 of 9 Old 06-18-2012, 10:25 AM
pokekevin's Avatar
Liked: 101
+1
pokekevin is offline
post #4 of 9 Old 06-18-2012, 11:17 AM - Thread Starter
junoonis's Avatar
Thanks guys, Any recommendation for the sub? I have a fairly small room and the only place I can put the sub is behind the TV. these speakers will be also close to the TV. I was looking at
Mirage S8
http://www.amazon.com/Mirage-Omni-S8-8-Inch-High-Performance-Subwoofer/dp/B000F97FRM/ref=sr_1_1?ie=UTF8&qid=1340043334&sr=8-1&keywords=mirage+8
or how about a wireless Sub woofer from Polk over at sellout.woot
http://sellout.woot.com/
junoonis is offline
post #5 of 9 Old 06-18-2012, 11:22 AM
pokekevin's Avatar
Liked: 101
budget and howmuch spacedo you have?
post #6 of 9 Old 06-18-2012, 11:48 AM
zieglj01's Avatar
Quoted: 99 Post(s)
Liked: 370
Mirage S8
I would skip the Polk sub.
The Mirage will fill in the bass, to balance the bookshelf - the Energy will have more authority
and go deeper > if you can work it out.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
zieglj01 is offline
post #7 of 9 Old 06-18-2012, 04:00 PM
JimWilson's Avatar
Quoted: 52 Post(s)
Liked: 313
+1
You bought nice speakers, so getting a crummy sub would be a bad idea. The Energy S10.3 is regarded quite highly, so it should compliment your AT speakers.
BTW; where did you get those 2400's for $169? That's like half price.
If you take yourself too seriously expect me to do the exact opposite
JimWilson is offline
post #8 of 9 Old 06-18-2012, 08:45 PM
Geoff_L's Avatar
You can get the Atlantic Technology 2400LR for $169 through Accoustic Sound Design using code "ATLR" - http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=1965&sc=32
Here are their specials: http://slickdeals.net/permadeal/75222/acoustic-sound-design-atlantic-technology-system-2200-home-5.0-speaker-system-329-2400-lr-speakers-pair-169-system-2200c-center-speaker-89-2200-lr-bookshelf-speakers-pair.
Good luck with the subwoofer purchase/placement and enjoy the system.
Geoff_L is offline
post #9 of 9 Old 07-05-2012, 03:33 PM
SCSI's Avatar
They are back on sale! Thinking about getting the 2400LR and pairing it with my Energy S10.3. I'm looking for 2.0 speakers that don't really need a sub though.
Frank
SCSI is offline
Reply Speakers
User Tag List
