Question Tv mounted on wall fireplace below - AVS Forum | Home Theater Discussions And Reviews
Old 06-18-2012, 10:31 AM - Thread Starter
SBD240's Avatar
I now own the Polk Center cs20 the problem is the space between the tv and the fireplace is limited. I am hoping there is someone out-there who has had a similar issue. I have not purchased a mantle as of yet i am awaiting till i figure this out!
The wife is getting impatient and is telling me to go smaller for a speaker in the center. I feel if I do that I will lose the sound I am looking for. If there is any advice out there i would really appreciate the help!!640
SBD240 is offline
Old 06-18-2012, 11:47 AM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
I have a very limited space between my mantle and my screen, just under 7" high, 8 1/2 " deep. Was using a Vienna Waltz grand, just ordered a custom sized CC from Salk.
saeyedoc is offline
Old 06-18-2012, 12:38 PM
jjlee138's Avatar
I had the same problem when looking for a center and ended up going with a Klipsch WC-24 due to it's shallow depth. I've been very happy with it. It fits perfectly on my shallow mantle.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780086
jjlee138 is offline
Old 06-18-2012, 01:25 PM
Geoff_L's Avatar
I had a similar challenge many years ago. Below are a couple of old photos from 10 years ago. Since then we've upgraded to the Definitive Technology Pro Monitor 1000's (LR), 2000 (center) and 800 (surrounds) with a SuperCube III. It has worked very well for us. If you need more pictures or have any questions let me know.
I found some more recent pictures of my Definitive Technology setup in case that helps at all.
Center (PM 2000) and front left (PM 1000)
Center and front right (decent view of the mounts)
Geoff_L is offline
