Floorstanding Speaker Buying help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-20-2012, 12:52 PM - Thread Starter
forsaleforall's Avatar
I have an option to buy JBL ES80BK or Infinity Primus P363BK. Frys electronics sells these pretty cheap compared to other stores (about $200-280 for pair).
I will be using these without sub or central in an apt to start with - which of these you guru's suggest I should get?
Thanks for your help
forsaleforall is offline
post #2 of 5 Old 06-20-2012, 03:54 PM
commsysman's Avatar
Quoted: 966 Post(s)
Liked: 522
I would think that the JBL ES80BK is the better speaker; JBL lists them at $399 EACH!!
Are you sure about the price?
commsysman is online now
post #3 of 5 Old 06-20-2012, 10:07 PM - Thread Starter
Thank you - frys listed this as a two day sale on their website. http://www.frys.com/ads/page29
They had the infinity for sale last sunday, and the manager told they will have it again this weekend. So $277 for a pair of jbl vs $200 for a pair of infinity primus... not sure what they have in plans for july 4th weekend ....
post #4 of 5 Old 06-21-2012, 08:40 AM
Kach22's Avatar
After looking at each, I second the choice for the JBLs. The Infinity design just doesn't look great; only 4 screws each to mount the drivers and they "overlap" and touch in some areas and the tweeter is below the mid-driver, which doesn't seem ideal.
Kach22 is offline
post #5 of 5 Old 07-11-2012, 08:20 AM
seriousjack85's Avatar
Quoted: 17 Post(s)
INFINITY PRIMUS P363 BK Listed for $99 each. Looks like Excellent Deal to me.
seriousjack85 is offline
Reply Speakers
