Speakers for Denon AVR3312CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 113 Old 06-20-2012, 06:28 PM - Thread Starter
m0squito's Avatar
Hi,
I'm not a very demanding audio user, I was looking into buying the Yamaha YHT-597 5.1, but it hasn't been released yet. Last week I changed my mind and got the Denon AVR3312CI through Amazon's gold box for $550 (I was lured by the price cut and the brand name..). Now I'm completely clueless as to what speakers would be a good match for it. I don't have much money to spend, perhaps $300, tops $400. I'm okay with buying only 2.1 now and expanding in the future (does it make sense?). Can anyone advise me on the speakers for this AVR? Also, are there wireless options for the surround speakers? I don't really have a convenient/clean way to run wires in the room where the AVR is located.
Any advice would be greatly appreciated, I'm completely lost..
m0squito is offline
post #2 of 113 Old 06-20-2012, 07:02 PM
zieglj01's Avatar
Quoted: 1714 Post(s)
Liked: 1632
This can get you going
The Boston A25
http://www.onecall.com/product/Boston-Acoustics/A25WH-White-Ea/Speaker/_/R-115576
And, Energy sub
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #3 of 113 Old 06-20-2012, 07:26 PM - Thread Starter
m0squito's Avatar
Thanks for the prompt reply! Too bad the speaker is white, the black is twice expensive. Do you have any other recommendation in similar price range? In any case, could you tell me what wires I should buy to hook the subwoofer and the speakers to the AVR?
m0squito is offline
post #4 of 113 Old 06-20-2012, 07:47 PM
zieglj01's Avatar
Liked: 1632
HTD Level Two
http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers
Infinity Primus 163
http://www.crutchfield.com/p_108P163BK/Infinity-Primus-P163.html
Wire guage table
http://www.roger-russell.com/wire/wire.htm#wiretable
Go to www.monoprice.com
speaker cable
http://www.monoprice.com/products/search.asp?keyword=speaker+wire
subwoofer cable
http://www.monoprice.com/products/search.asp?keyword=subwoofer+cable
Who AM I
zieglj01 is offline
post #5 of 113 Old 06-20-2012, 08:37 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I would get 2 Infinity Primus P162 for $68 each.
http://www.crutchfield.com/shopsearch/infinity_primus.html
Here are the measurements.
Here is the review.
And I would get one Dayton 12" subwoofer for $129 + $15 shipping.
Add another P162 for 3.1. Or add the Infinity PC250 for $100.
AcuDefTechGuy is offline
post #6 of 113 Old 06-21-2012, 06:05 AM - Thread Starter
m0squito's Avatar
Thank you so much for the response and advice. I have one last question: the Dayton subwoofer has L and R input for the subwoofer - does it matter which one I should use when connecting it to the AVR? Should I use both with some Y connector?
Also, should I get the banana pins for the speaker wires?
m0squito is offline
post #7 of 113 Old 06-21-2012, 07:29 AM
Quoted: 175 Post(s)
Liked: 262
L/R RCA Sub Input: doesn't matter. Using a Y-cable (1Female-2Male) will increase the sub volume be 3dB. So no big deal. Just use either the L or the R input.
Bananas are for 100% convenience. You don't need them. Most of us get them to make connection easier.
post #8 of 113 Old 06-21-2012, 07:42 AM
Quoted: 175 Post(s)
Liked: 262
I also want to say the Infinity P362/ 363 are kind of "legendary".
You can get them for $160 each.
They have been reviewed and measured in Stereophile and just recently on Audioholics:
http://www.audioholics.com/reviews/speakers/floorstanding/primus-p363
In Harman's own famous double-blinded studies, many people preferred the P360/ 362/ 363 over other speakers costing many times more.
For example, the P360/362/363 has been well-known & documented (black & white facts) to have better on-axis and off-axis frequency responses than the B&W 800D, Wilson Audio, Vienna Acoustics speakers that cost $30K - $50K. Now whether they sound better or not is purely subjective and can be argued. But the facts are there and cannot be argued.
I've auditioned the B&W 800D twice. At moderate volume 85-90dB, I'm not sure many people can even tell which sounds better 100% of the time in a double-blinded test. biggrin.gif
post #9 of 113 Old 06-21-2012, 09:26 AM - Thread Starter
m0squito's Avatar
Thank you so much for your help. I decided to get two P162 and the Dayton subwoofer for now. I might get the P362/363's in the future and use the P162 as surround speakers. For now, this is what I can afford.
THANK YOU
m0squito is offline
post #10 of 113 Old 06-21-2012, 11:58 AM
10credi's Avatar
I would also like to know if there is any other decent setup for under $800 including subwoofer and 5 speakers for the same Denon AVR3312CI receiver please.
TIA.
I am looking at
Polk CS2 - Center Speaker (please suggest if any other ideas)
Polk Monitor (not sure 50 or 70) - Front R and L (please suggest if any other ideas)
Subwoofer - don't know but leaning towards Rhytmik FV 12 (maybe for later) (please suggest if any other cheaper ideas)
Surround (don't know)
10credi is offline
post #11 of 113 Old 06-21-2012, 12:15 PM
zieglj01's Avatar
Liked: 1632
TIA.
800 dollar budgets do bring limitations - however, Newegg has a E-Blast
insider deal going on for Pioneer speakers - I would skip their sub.
http://promotions.newegg.com/NEemail/June-0-2012/AllStars21/index-landing.html?nm_mc=EMC-IGNEFL062112&cm_mmc=EMC-IGNEFL062112-_-EMC-062112-Index-_-E0-_-Electronics#Electronics
Their bookshelf speakers
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=pioneer+speakers&x=0&y=0
I would also look at the Energy sub S10.3 - I would prefer this over cheaper
boomy subs, that struggle to hit 30hz. Energy does not have cheap boomy
bass.
Energy measurements.
http://www.soundandvisionmag.com/article/energy-take-series-home-theater-speaker-system?page=0,2
"Bass limits for the S10.3 subwoofer were measured with it set to maximum bandwidth and placed in the optimal corner of a 7,500-cubic-foot room. In a smaller room, you can expect 2 to 3 Hz deeper extension and up to 3 dB higher sound-pressure level (SPL). The S10.3 had above average dynamic capability, and the acoustical crossover points matched the dial markings closely"
If you can find a Rythmik sub and able to afford it > then I would much prefer that.
Also, do not under estimate HTD > their stuff is good - also, I would skip
their subs.
If you can save up, a good thing is to build you set up in sections, and aim for
higher quality speakers.
10credi likes this.
Who AM I
zieglj01 is offline
post #12 of 113 Old 06-21-2012, 12:25 PM
10credi's Avatar
Thank you zieglj01 for your prompt response.
So you are talking about
Pioneer SP-FS51-LR Floorstanding Speakers Pair - $199 but $130 right now
Pioneer SP-C21 Center Channel Speaker Each - $100 but $50 right now
Which sub for the above?
OR
Energy Take 5.0 setup for $250
S10.3 subwoofer - $250
OR
HTD
Center Channel Speaker - $130
Front Tower Speakers - $400
What about subwoofer here?
Also, just curious what if i raise the budget to $1000, does it help or you still think I should split up and buy one thing at a time? What if I could spend $400 every 6 months for 4 times (like $1600)?
10credi is offline
post #13 of 113 Old 06-21-2012, 12:37 PM
10credi's Avatar
Is this the right one I am looking at?
http://rythmikaudio.com/FV12.html
It is available right now and at $566 shipped
10credi is offline
post #14 of 113 Old 06-21-2012, 12:52 PM
zieglj01's Avatar
Liked: 1632
The word is that they found a few - you may want to Email them.
Who AM I
zieglj01 is offline
post #15 of 113 Old 06-21-2012, 12:56 PM
zieglj01's Avatar
Liked: 1632
OR
OR
HTD
I would not consider the Take 5.0
I favor the HTD over the Pioneer and Infinity speakers, I would use the Rythmik
or the Energy sub.
Also, HSU sub
http://www.hsuresearch.com/products/vtf-2mk4.html
Who AM I
zieglj01 is offline
post #16 of 113 Old 06-21-2012, 01:13 PM
zieglj01's Avatar
Liked: 1632
You can have a good decent system now, out of the choices listed above - a lot
of people can be happy and live with these systems. $1600 over 24 months, will
not get you much more - no guarantees what will happen over the next 24 months.
You can save and see what comes up - you can always sell your system in the future.
Your option, choice and decision.
Who AM I
zieglj01 is offline
post #17 of 113 Old 06-21-2012, 01:27 PM
10credi's Avatar
or the Energy sub.
Also, HSU sub
So more confusion added for the SUB with HSU which is coming out $610.
So finally according to you
Level TWO Tower Speakers from HTD - $400
Level TWO Center Channel Speaker - $129
Level TWO Bookshelf Speakers - $200
Energy S10.3 - $253
$982 total
Is there anything that can be changed or improved for a very small price?
10credi is offline
post #18 of 113 Old 06-21-2012, 01:32 PM
Quoted: 175 Post(s)
Liked: 262
THANK YOU
For the money you won't find better measured & reviewed speakers for sure. There are so many budget speakers around. Some will say this one sounds better than that one. But they are all pure subjective opinions. Going with something that has been measured and reviewed and liked by so many people like the Infinity P362 & P162 is a wise choice.
post #19 of 113 Old 06-21-2012, 01:47 PM
ahatteberg's Avatar
I also just bought the Denon 3312 and am looking for speakers but have a bit more to spend. I currently have Snell bookshelf speakers, surrounds and center (which I've not been completely happy with a far as movie/TV dialogue) and am going to move those into my bedroom and replace the entire system in my den. It's a big room with high ceilings, wood floors and floor-to-ceiling windows (no curtains) on one wall. I'm pretty sure I want to stick with bookshelves because I have a lot of well-placed bookshelves and don't want speakers standing on the floors (this is not a dedicated home theater). I know I need to go audition some speakers, but here's what's been recommended so far and I'd like opinions of these various speakers with that receiver and in a room of that sort from anyone who would care to opine:
Martin Logan Motion LX-16 Front speakers, ElectroMotion FX2 Rears/brackets, Motion SLM Center, Dynamo 300 compact subwoofer
Wharfedale Jade 3 Front speakers, Jade SR Rears/brackets, Jade C2 Center, and Velodyne Chrysalis 6.5" 180WATT 8" small subwoofer 10"X 10"X 12"
I've also looked at the Klipsch RB-81 II Bookshelf Speakers with a G28 center, RS-52 II Surround Speakers, and SW-311 Subwoofer. I really like how those look (yes, I'm a girl), but didn't get much interest in those when I mentioned them to the only installer I've gotten a bid from so far.
I don't know much about speakers, and would like to learn more, but don't have enough time to really research the entire subject the way I'd like. So, any opinions would be much appreciated.
ahatteberg is offline
post #20 of 113 Old 06-21-2012, 02:27 PM
10credi's Avatar
Energy S10.3 - $253
$982 total
Any suggetions, anybody? For around $800 to $1000 budget, any ideas?
10credi is offline
post #21 of 113 Old 06-21-2012, 02:33 PM
Quoted: 175 Post(s)
Liked: 262
TIA.
I am looking at
Well, the Rythmik FV12 is already $550 plus another $50 shipping. So that leaves you $200 for 5 speakers?
post #22 of 113 Old 06-21-2012, 02:36 PM
10credi's Avatar
Yes that is true, so thinking I can push subwoofer for a little later but buy a good remaining setup for around $400.
10credi is offline
post #23 of 113 Old 06-21-2012, 03:13 PM
zieglj01's Avatar
Liked: 1632
Energy S10.3 - $253
$982 total
NO, I do not work for HTD - if you follow my name and posts, you will find
that I reccomend all types of speakers.
I have owned Polk, Infinity, Pioneer and HTD - and my favorite from them
is HTD. You can start with this system and save for a better sub later >>
however, the Energy is no wimp. You can sell the Energy sub later.
Good Luck!
10credi likes this.
Who AM I
zieglj01 is offline
post #24 of 113 Old 06-21-2012, 03:28 PM
10credi's Avatar
Good Luck!
Thank you again and did not mean to offend you but thank you again.
I have now started looking for deals for HTD setup as above and Energy S10.3.
10credi is offline
post #25 of 113 Old 06-21-2012, 03:42 PM
zieglj01's Avatar
Liked: 1632
No offense taken - that statement was also made for others, who may think that I work for them.smile.gif
A discontinued HTD Level Two deal - here.
http://www.htd.com/Products/Discontinued/Level-THREE-Bookshelf-LIGHT-CHERRY-discontinued_2
You can always start with the towers and sub - or, start with the bookshelves, center and sub.
Have Fun!
Who AM I
zieglj01 is offline
post #26 of 113 Old 06-21-2012, 03:52 PM
10credi's Avatar
Have Fun!
Sound reproduction wise what would be the difference between Surround and Bookshelf speakers?
10credi is offline
post #27 of 113 Old 06-21-2012, 03:59 PM
10credi's Avatar
Have Fun!
Not fan of Light cherry since it will not match with other speakers
Also, I am getting Energy S10.3 for $214.49 OTD. Do you think I can get it lower than this?
10credi is offline
post #28 of 113 Old 06-21-2012, 04:55 PM
zieglj01's Avatar
Liked: 1632
Just keep an eye on Newegg pricing > $189 and $199 is average on-sale pricing.
Who AM I
zieglj01 is offline
post #29 of 113 Old 06-21-2012, 05:08 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
I wouldn't spend to much on good speakers, since the under powered denon amps will clip when pushed and burn-out the tweeters.
joehonest is offline
post #30 of 113 Old 06-21-2012, 05:18 PM
10credi's Avatar
the 3312 says 125 W per channel and at .05 THD. Am I missing anything here? Then what power speakers would be recommended and which ones?
10credi is offline
Reply Speakers
