On-Wall Center Channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-20-2012, 09:22 PM - Thread Starter
Superfluous's Avatar
I'm looking for a wall mounted below the TV center channel upgrade but only if it is a big enough upgrade to justify it.
Under $1000
Currently:
Center Channel: Atlantic Technology FS3200C
Fronts: Polkaudio rti10
Subwoofer: Epik Legend
Rears: In Wall Boston Acoustics
Receiver: Denon 2112
I'd like the depth to be under 4 inches, and around 8 inches tall. It can probably be as wide as it needs to be since it will be below a 65 inch TV.
I've found recommendations of:
Definitive Technology Mythos Ten
Totem Tribe (Which model? How much are they? Can they be bought online?)
Revel C10 (How much? Can it be bought online?)
What else? Any info on these?
Superfluous is offline
post #2 of 16 Old 06-22-2012, 05:58 PM - Thread Starter
Bump
post #3 of 16 Old 06-23-2012, 08:41 PM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1567
With Polk fronts you should probably consider getting a center from them as well. That way, the voicing will be similar.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #4 of 16 Old 06-23-2012, 09:13 PM - Thread Starter
I looked into polk but didn't find anything that fit the bill really.
post #5 of 16 Old 06-23-2012, 10:56 PM
donutfan's Avatar
Quoted: 18 Post(s)
Comes in black and cherry finishes:
JBL LC2 - a 4-way with dual 6" woofers so should have no problem with just about any soundtrack.
Also, JBLs generally seem to sound a bit bright to many people, so they have a decent chance of matching up pretty well with your Polks.
donutfan is offline
post #6 of 16 Old 06-24-2012, 01:09 AM - Thread Starter
That center looks good but it won't work dimension wise.
post #7 of 16 Old 06-24-2012, 06:52 AM
Mantis10's Avatar
VM20 from polk audio will match closer then any of your choices. The Mythos 10 is a great center channel but better paired with Mythos series fronts and surround speakers.
The center channel is the worse speaker to mis match in a system. You can get away with it on surround channel speakers if they are close in timbre.
Mantis10 is offline
post #8 of 16 Old 06-24-2012, 09:14 AM - Thread Starter
I was thinking of getting a third RTI10 and putting it vertical in the middle, but my girlfriend doesn't like the idea.
post #9 of 16 Old 06-24-2012, 05:52 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
ifor is offline
post #10 of 16 Old 06-24-2012, 08:18 PM - Thread Starter
Originally Posted by ifor View Post
Triad on-wall Bronze LCR
http://www.triadspeakers.com/products/owblcr.html#tab3
I looked at Triad, but it says it's 10 inches wide. That seems very wide (tall) and I think it's too tall for my space.
post #11 of 16 Old 06-24-2012, 08:33 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Leon Profile 505 or 606 then.
http://www.leonspeakers.com/pr.html
ifor is offline
post #12 of 16 Old 06-24-2012, 08:58 PM - Thread Starter
These look very interesting, thanks for the suggestion.
Do you know prices?
post #13 of 16 Old 06-25-2012, 12:24 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
I don't sell that line, so I don't know the pricing. But you can contact them to find a dealer.
http://www.leonspeakers.com/find_a_dealer.html
ifor is offline
post #14 of 16 Old 06-25-2012, 03:36 PM
rileychris's Avatar
Curious. What don't you like about the FS-3200?
rileychris is offline
post #15 of 16 Old 06-26-2012, 06:34 AM - Thread Starter
Not sure acoustically, but I'd like a speaker that's less deep and a bit wider to look better with a 65 inch above it. However, I don't want to downgrade in sound quality.
post #16 of 16 Old 03-27-2013, 05:33 AM
ga243's Avatar
I have the same issue. Did you ever find a good solution?
ga243 is offline
Reply Speakers
