5.1 vs 7.1 - AVS Forum | Home Theater Discussions And Reviews
Old 06-23-2012, 10:16 PM - Thread Starter
MannyE's Avatar
Quoted: 16 Post(s)
7 speakers...
Just thinking ab out it makes me imagine a mansion with a huge custom HT designed by top engineers and architects. A room decorated with an authentic pair of ruby slippers a working light saber and one of the real Harryhausen King Kongs sitting in a glass case.
I say that because after 17 yeas of enjoying a great 5.1 (well... 5.2 really because of the DefTech BP 2002 towers) I still see no way I can accomodate two more speakers in my 25x17 room... or is there?
It just seems to me that my room would have to be at least 10 feet longer to really take advantae of adding two side speakers to the rears.
And now that I'm upgrading after so long... moving up to a Mythos Supertower front end... I'm thinking about those two extra outlets in the pre and a stereo amp that would be prefect for powering those two extra channels... is it worth the effort? How much better can it get?
Truck? What truck?
MannyE is offline
Old 06-24-2012, 05:33 AM
lefthandluke's Avatar
Quoted: 137 Post(s)
Liked: 266
i recently sold my back surrounds, leaving me temporarily with 5.1...i will tell you that i mss 'em. you have a nice size room... mine is similar at 24x14. depending on layout you should have ample space behind. if music is your priority, 5.1 will be fine...and don't get me wrong, 5.1 is usually outstanding for movies. but a true 7.1 title, like "super 8" makes a good argument for a 7.1 setup...
at the zenith of his nadir...
lefthandluke is offline
Old 06-24-2012, 07:17 AM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3550
If my dedicated room was the size of yours, I would definitely have a 7.1 system. In my family room set up (larger room) I do have a 7.1 setup.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 06-24-2012, 11:36 AM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2902
Originally Posted by MannyE View Post
7 speakers...
Adding just 2 speakers to your current set-up makes you imagine all that?
My first 7.1 set-up was in a 11x13.5 spare bedroom. My futon was 8 feet from the front wall, giving me at least 5 feet of separation between the side and rear speakers.
That was 21 years ago (4 years before any discrete multi-channel material was released on laserdisc). Due to that, I've never associated 7 speakers with a huge custom HT, let alone a mansion. Just thought it was an easy way (adding 2 speakers) to get wrap-around envelopment and stable rear-vs-side imaging in the surround field.
...is it worth the effort? How much better can it get?
Depends on several factors, including seating location, speaker placement and your hearing. If you can tell the difference between sounds coming from your sides vs sounds coming from behind you, then you'll be able to appreciate what a 7-speaker layout adds to the experience.
Sanjay
sdurani is online now
Old 06-24-2012, 01:26 PM
C0rk's Avatar
Quoted: 34 Post(s)
Liked: 25
It just seems to me that my room would have to be at least 10 feet longer to really take advantage of adding two side speakers to the rears.
In a 5.1 system, the surround speakers go on the sides. So what would be really worthwhile is moving those rear speakers over to the side where they should be.
As for 7.1, it's really more of whether you have room behind your listening area, not so much room size.
C0rk is offline
