AVR for 7.1 Set -up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-24-2012, 09:10 PM - Thread Starter
Chica17's Avatar
Hi,
Room size 12X15.
I am planning to purchase,
Dayton SUB & Polk RTi A1. To start with 2.1 set up. And i have plan to expand it to 7.1. I need your valuable feed suggestion to choose the AVR. I am not planning to upgrade my AVR for next 5 years at least. Now I can spend around $500. After lot of reviews I shortlisted Yamaha or Denon (No Onkyo & Pioneer)
I am looking for features
1. Networking
2. Video up scaling - Is it required ??
3. Love wifi feature to get rid of wires all around.
Please suggest me which is the best one for my requirement and budget.
I have noticed Yamaha RxV-673 & 773 suites my requirement. and also Denon AVR2112Ci. I am not sure whats the difference and which is good.
Chica
Chica17 is offline
post #2 of 7 Old 06-24-2012, 10:08 PM
HomeTheater1010's Avatar
Wifi is not going to get rid of wires to the speakers ! What kind of speakers are you getting ? You need to get the right reciever for the speakers you get !
HomeTheater1010 is offline
post #3 of 7 Old 06-24-2012, 11:07 PM - Thread Starter
Chica17's Avatar
Yes, you are right. However it can reduce one Ethernet cable. I am not sure its the good option or not.
Please suggest what you think.
I tried getting answer from receiver forum, no luck.
I am getting these speakers.
Chica17 is offline
post #4 of 7 Old 06-25-2012, 12:54 PM
joshua.jones's Avatar
Wireless is good but, if you can get away with it, the ethernet cable is best.
Whenever you need to update the firmware on your AVR, a wireless dropout could really hurt you.
I can't count the number of times that my TV has stopped steaming because of wireless dropouts.
Question: Why not Onkyo?
joshua.jones is offline
post #5 of 7 Old 06-25-2012, 08:43 PM - Thread Starter
Chica17's Avatar
Thank you Joshua for your comments on Wireless.
As of now nothing is fixed. So rather making it more complex by adding features and brands. I decided to cut short as much as possible, when I read lot of reviews, I understand Onkyo has reliability problems. I will be going back to India in next 6 months. So I really do not want to take any chance on my receiver. If anything happens, no one can repair. I know Yamaha have there service shops and even Denon has some authorized shops in India. So I decided to stick with these 2 brands.
I am not worried much about features like wireless or video up scaling etc. I need a decent quality sound.
So need your help in finalizing my receiver.
Regards
Chica
Chica17 is offline
post #6 of 7 Old 07-03-2012, 05:19 AM - Thread Starter
Chica17's Avatar
Can anyone help me???
Chica17 is offline
post #7 of 7 Old 07-03-2012, 07:35 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
people have been getting the Denon 2312 for just under $500. Have you looked at that one too?
Can you really get the Yamaha 773 under $500?
Afro GT
afrogt is offline
Reply Speakers
