Paradigm Atom v6 and NAD 2400 THX - AVS Forum | Home Theater Discussions And Reviews
Old 06-26-2012, 02:17 PM - Thread Starter
AUGTO's Avatar
Is this to much power for these speakers?
Paradigm Atom v6 Suitable Amplifier Power Range - 15 - 80 watts
NAD 2400 thx 100 Watts/Channel
Will this damages the speakers?
AUGTO is offline
Old 06-26-2012, 03:17 PM
commsysman's Avatar
Quoted: 974 Post(s)
Liked: 525
To damage those speakers, you would have to play them at levels where the volume and distortion would be unpleasant in the extreme.
They have 90db/watt sensitivity, so applying 100 watts to them would give you an SPL in the room of around 110 dbA, which no one in their right mind could stand for 2 seconds.
Play them at levels that are not deafening and you will have no problems.
commsysman is offline
Old 06-27-2012, 09:20 AM - Thread Starter
AUGTO's Avatar
AUGTO is offline
