Need DIY for 18" sub box(s) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-29-2012, 10:09 AM - Thread Starter
Denon_Kid's Avatar
i am wanting to build two 18" ported subs for outdoor use. i only want to spend ~$100 for each woofer, should be able to handle ~500w rms. i plan to use std -3db choke coil around 100-150hz.
the box needs to be "portable". i will build it from 3/4" ply.
anyone have any DIY's or can suggest woofer along with box/port size?
thnx.
Denon_Kid is offline
post #2 of 3 Old 06-29-2012, 02:59 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
try in the diy section
ifor is offline
post #3 of 3 Old 06-30-2012, 05:43 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
Ratman is offline
Reply Speakers
