Thoughts on new Klipsch speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-01-2012, 08:52 AM - Thread Starter
avdoc's Avatar
Quoted: 173 Post(s)
Liked: 108
Just wanted to share my thoughts on my new Klipsch system. I am an audiophile and had previously used Magnepan speakers in a dedicated theater/music listening room. However, I don't listen to music as much as I used to and plan to move the system to the living room. The size constraints and need for a large external amplifier for the Maggies led me to look for a system I could drive with the internal amps of my Receiver/Processor (Denon 4310). I hadn't purchased speakers in 10 years and was disappointed to find that few local hi-end dealers still existed and none had loaner speakers I could take home and listen to. My options came down to Best Buy and HiFi Buys (Nashville). Upon hearing Klipsch at HiFi Buys, I was sure it was the brand for me. I liked the hyper-realism and clarity of sounds for movies. You can hear all the small details very clearly. The problem was the "chestiness" of voices. Since the Maggies are a boxless design, I am very sensitive to boxy colorations of voices. I found that the only center channel that didn't have excessive boxiness was the top-of-the-line RC-64-II, presumably because it's a sealed design. I also liked that the 64 gave a much wider soundstage than the smaller speakers which were much more localizable. If I was forced to chose a smaller center from the reference line, I would have gone with the RC-52II because the chesty coloration was much less than with the RC-62II. For the mains, I wanted front-ported bookshelves due to size and placement constraints. I chose the RB-61II since the chestiness was much less than with the RB-81II and the 61's had similar bass extension (44 vs 45 Hz for the 81s vs 61s). For surrounds, I went with the RS-42II because I didn't hear a difference between them and the RS-52IIs.
On a whim, I went to Best Buy and listened to the Klipsch Icon KB-15 bookshelves. I was amazed at the price/performance ratio of these ($200 per pair). They sound very close to the RB-61IIs, just a little smaller soundstage and a little more "veiled". However, they are very closely voice matched to the reference line. I am using a pair of the KB-15's for width speakers and have another pair I plan to use for rear fill speakers once I hang them from the ceiling.
I am happy with the new system and recommend anyone considering a new system look at Klipsch.
avdoc is offline
post #2 of 3 Old 07-01-2012, 10:15 AM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1574
Thanks for the info. I'm sure it will help out others.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3 of 3 Old 07-01-2012, 10:42 AM
GiTcHaSuM's Avatar
Quoted: 12 Post(s)
About a year ago, I was looking to upgrade my speakers as well. I was coming from a HTIB (it was a quick fix due to my previous system going out...long story) and I wanted some real speakers. After months of researching, I knew I wanted some towers up front but thought they were just a little too much (in both price and practical usage...I have a small room). I finally decided to pull the trigger on a Klipsch set at best buy: 1 pair of KB-15s for L and R channels, 1 KC-25 Center, 1 pair of KS-14 Surrounds and 1 SW450 sub...I think that was the sub. After a few days I was a little underwhelmed, but a few days later I ended up being quite impressed with this set up because it wasn't anything too grand in scale or price but the sound was excellent, especially from the KB-15s.
I must point out that a week later I learned that the Best Buy Magnolia locations sold Energy speakers (I wanted Energy towers at the start) and I listened to them. I found that at the time they were having a sale on Energy systems and I could get what I originally wanted, a 5.1 system with towers, for less than I paid for the Klipsch set. I decided to return the Klipsch set for the Energy tower set and I had those until about a month ago. I now have a 7.1 set up of the Energy RC line (with some towers of course smile.gif) with a Hsu subwoofer. Even though I only had the Klipsch set for about a week, that doesn't mean the sound was not good...the system sounded great, I just found a system that I originally wanted for a little less.
Even now, when someone asks me about speaker brands and what are some good speakers, I still recommend that same Klipsch set for those not able to or do not want towers. I remember that the Klipsch 5.1 set was a tremendous upgrade to what I had previously. Well, there is my story...I hope I didn't bore anyone to much.
GiTcHaSuM is offline
Reply Speakers
