What do I add next? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-03-2012, 05:44 PM - Thread Starter
PaulH55's Avatar
Right now I have a 2.0 system with Paradigm Studio 10s with the eventual goal of going 5.1. My question is what is the next logical step to take, do I add a center, a sub, or surrounds first? Does it matter or is it just personal preference? Any help?
PaulH55 is offline
post #2 of 14 Old 07-03-2012, 07:33 PM
afrogt's Avatar
Quoted: 1363 Post(s)
Liked: 946
Personal preference. I'd add a subwoofer first, then the center speaker.
Surrounds would definitely be last.
Afro GT
afrogt is online now
post #3 of 14 Old 07-03-2012, 07:49 PM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
Plus 1. I have Paradigm Monitor 9's and I just bought a Rythmik FV15. Awesome sub and works great with the Paradigms.
Jeff
pronghorn/az is offline
post #4 of 14 Old 07-03-2012, 08:29 PM
HelloHelloHello's Avatar
Well I think you should add the surrounds first.
Your fronts can probably do good bass and create a phantom center easily, but only the surrounds will give that extra dimension.
HelloHelloHello is offline
post #5 of 14 Old 07-03-2012, 08:35 PM
afrogt's Avatar
Liked: 946
Frequency response of Studio 10's is 62hz - 22khz. I wouldn't call that good bass. Decent at best.
Afro GT
post #6 of 14 Old 07-03-2012, 08:59 PM
zieglj01's Avatar
Quoted: 1555 Post(s)
Liked: 1402
I would aim for a sub
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #7 of 14 Old 07-04-2012, 02:57 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
With small front speakers like the Studio 10, your system is definitely bass-shy!
I would want to get a decent subwoofer ASAP!
I suggest either the NHT B12D or the Rythmic FV12.
commsysman is offline
post #8 of 14 Old 07-04-2012, 06:56 AM
Mike Garrett's Avatar
Quoted: 6699 Post(s)
Liked: 4381
If you are in your own home, not renting an apartment, then I would get a sub next.
mjgarrett100@gmail.com
Mike Garrett is online now
post #9 of 14 Old 07-04-2012, 07:08 AM
JackDiesel14's Avatar
Quoted: 12 Post(s)
Liked: 31
Add the Studio 60s or 100s and use the 10s as surrounds. Gives you bass and surrounds killing 2 birds with 1 stone.
JackDiesel14 is offline
post #10 of 14 Old 07-04-2012, 07:41 AM
shelly40's Avatar
Quoted: 148 Post(s)
Liked: 53
I agree with most above....
I would definitely add the sub next as your fronts are pretty small.....
Then, if your fronts create a decent phantom center, I would add surrounds as the second upgrade....
If they don't, I would go center channel second on the list to upgrade....
Thats just the way I would do it.....
Shelly
shelly40 is offline
post #11 of 14 Old 07-04-2012, 04:08 PM
I take it back, I wasn't thinking. I agree with your speakers you should go with a subwoofer first. That's what enticed me to get home theater in the first place.
You can get some surrounds pretty cheap too.
post #12 of 14 Old 07-05-2012, 07:51 AM - Thread Starter
PaulH55's Avatar
OK, that's what I was thinking but wanted to see if I was on track. Thanks to all.
PaulH55 is offline
post #13 of 14 Old 07-05-2012, 07:56 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Be sure to research and ask questions in the AVS subwoofer forum. There are some good values in subwoofers out there--and many more that are way overpriced for what you get.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #14 of 14 Old 07-05-2012, 08:09 AM
LanceX's Avatar
Quoted: 109 Post(s)
Liked: 35
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026&Tpk=energy%20s10.3
I got it for 180$ on sale. its 219$ right now but this bad boy beats subs well above its price. Its very very strong. 200 W continuous and 800 Dynamic peak
LanceX is offline
Reply Speakers
