Wires for Klipsch RF 82 - II speaker system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-04-2012, 06:26 AM - Thread Starter
vmanju123's Avatar
After much haggling i have decided to buy RF 82-II speaker system along with Marantz SR 6006/6007 with Panasonic PT AE 7000u projector
RF 82 - II will contain pair of RF 82 towers
RC 62 - II center
RS - 52 II surrounds
I need guidance how to connect all these
I am looking at 35ft HDMI cable for Projector to Reciever, link below
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024002&p_id=2805&seq=1&format=2
My RF 82s will be no more than 10 to 12 ft from recievers, Center would be arround 6 to 7 ft but surrounds could be around 15ft each direction from reciever
I was thinking to get the below and use them to wire all
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023903&p_id=4041&seq=1&format=2
could you please help suggest wiring
thanks
Manjunath
vmanju123 is offline
post #2 of 5 Old 07-04-2012, 07:01 AM
AJinFLA's Avatar
Liked: 24
Those wires will work fine, although there is no need for 4 conductor speaker wires, unless you wanted a single run from front to back of room for both surrounds. For single runs to any CH you only need 2 conductor.
cheers,
AJ
AJinFLA is offline
post #3 of 5 Old 07-04-2012, 07:24 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
psgcdn is offline
post #4 of 5 Old 07-04-2012, 07:19 PM - Thread Starter
vmanju123's Avatar
Would i need any banana plugs on either sides or just connection with wires directly would do ?
post #5 of 5 Old 07-06-2012, 09:22 AM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
Direct connection works fine.
Label the wires at the receiver, if you have to disconnect it will make it easier to reconnect correctly.
Charlie
chashint is offline
Reply Speakers
Klipsch Reference Series Rf 82
