My front towers are not at ear level since I'm on a bed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-06-2012, 05:44 AM - Thread Starter
HelloHelloHello's Avatar
What do you think I should do?
I would say the top of the speaker tower is right where the top of my bed is so I sit on the bed and my ears are probably 2.5-3 feet above the highest point on the speaker. Should I raise them?
HelloHelloHello is offline
post #2 of 9 Old 07-06-2012, 05:55 AM
wlcohen's Avatar
so all the sound is aimed directly at the mattress?
I would think you would actually benefit by going with smaller speakers that you can mount higher up on the wall.
wlcohen is offline
post #3 of 9 Old 07-06-2012, 06:04 AM
ClarkeBar's Avatar
Quoted: 25 Post(s)
Liked: 25
You could always buy speaker stands depending on your tower size. But I would try something simpler first. Do your towers have tweeters as the topmost driver? If so, put spikes with dimpled bases only under the front edge of the cabinet and give a slight tilt to the drivers. This should help the soundstage elevate in-room.
ClarkeBar is offline
post #4 of 9 Old 07-06-2012, 06:04 AM - Thread Starter
They're aimed at the bed but I can see them
post #5 of 9 Old 07-06-2012, 06:19 AM
Bill Fitzmaurice's Avatar
Liked: 4647
Yes.
Bill Fitzmaurice is online now
post #6 of 9 Old 07-06-2012, 07:43 AM
Kach22's Avatar
You can find speaker stands designed for floorstanding speakers, but it would probably be a lot cheaper to build your own. Just make sure whatever you use is weighted down enough (50+ lbs) to provide a solid base for your speakers.
Kach22 is offline
post #7 of 9 Old 07-07-2012, 12:52 PM
mtrot's Avatar
Quoted: 198 Post(s)
Liked: 65
I have the same situation in my bedroom system, with my Monitor Silver 9i towers. These have adjustable spikes on the bottom, so I was able to angle them up toward bed level. But even if your speakers don't have any adjustments, you could, as previously suggested raise them a couple feet on some sort of solid stand. Actually, this thread has got me thinking of raising mine about a foot.
FAMILY ROOM SYSTEM--Legacy Signature II tower speakers, PSB Image 5T tower speakers, Denon AVR-X5200W, Krell FPB 400cx, Oppo BDP-83 universal disc player, RCA HD-DVD player, Samsung HL67A 750A TV
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Yamaha RX-V1800 receiver, Sherbourn 5/1500A 5-channel amp, Oppo DV 980H DVD player, Panasonic DMP DT210 Blu-ray player, Panasonic 60-ST60 plasma TV.
mtrot is offline
post #8 of 9 Old 07-08-2012, 03:34 PM - Thread Starter
Ya I'm going to build some box stands for them. Not sure how high though. Should tweeters be at ear level, above, below? What angle?
post #9 of 9 Old 07-08-2012, 06:30 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
I had towers in a bedroom set up. I made stands to raise them up and then lifted the backs to angle them forward. My center was mounted above the TV and angled down. All three tweeters were aimed at the pillow, or listening position.
A guy can get pretty handy if he needs to. I had a 7.1 with Monitors 70, 40, 30 and CS2 with an Epik Empire. The room was only 14.5 x 10.5. Had 50" plasma as well.
Went to Lowes and got a garage storage rack that had adjustable shelving with thin wood shelves. Painted everything black. Placed in the corner, the bottom shelf housed the sub, above that was amp, above that was AVR. The blu player had it's own shelf. The L main sat on top of the sub, wait, I think I have a pic somewhere.......
Nope, all I could find was the rig I had before I put together the storage rack. I had placed a 2 x 2 block of wood in front of the rear speaker feet to angle it forward.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Reply Speakers
