Making my first jump to surround sound - 5.1 system on a budget? (Already have a receiver) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 07-09-2012, 12:16 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Some speakers allow you to use banana plugs, but you don't need them. It's more for the convenience of plugging and unplugging them frequently. You would also need to verify what kind of connector the Pioneers need. Might as well stick to just plain speaker wire since there is no sonic benefit to the banana plugs and the plain speaker wire works fine. 16 gauge should be fine for runs 36 feet or less; otherwise, go with 14 or 12 gauge.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #32 of 37 Old 07-09-2012, 02:15 PM - Thread Starter
Irishdoom's Avatar
Quoted: 18 Post(s)
Does the brand of speaker wire matter much? I have Amazon prime, so if I can get it through there I can save on shipping. They have 100' of Pyramid 12 awg for $15, which is cheaper than on Monoprice.
Irishdoom is offline
post #33 of 37 Old 07-09-2012, 02:39 PM - Thread Starter
Irishdoom's Avatar
Quoted: 18 Post(s)
Ok, ignore that last post. I read through the rest of that speaker wire article with the chart, and see that as long as the gauge is right it's probably fine for speaker wire. I ordered 100' of 12 gauge pyramid and a 15" media bridge subwoofer cable from Amazon for $25 shipped.
post #34 of 37 Old 07-09-2012, 02:43 PM
cel4145's Avatar
Liked: 2991
Shoot. I almost suggested Tartan Cables for a sub cable to you because they are available via Amazon Prime. Would be better quality than the Mediabridge for the same/not much more.
post #35 of 37 Old 07-09-2012, 02:46 PM - Thread Starter
Irishdoom's Avatar
Quoted: 18 Post(s)
I just made an attempt to cancel the Mediabridge sub cable part of the order. If that works out, is this what you're talking about?
http://www.amazon.com/foot-Subwoofer-Cable-Tartan-brand/dp/B0038T54OM/
post #36 of 37 Old 07-09-2012, 03:23 PM
LanceX's Avatar
Quoted: 84 Post(s)
Liked: 30
I guarantee you will love the pioneers and energy sub.
I just bought that setup except i use fs51 as fronts and sides amd bs21 as rear for 7.1
The fs51 is amazing and the sub is powerful!! I have the fs51 on tables and one on ky sub. You dont haved to have them on floor.
I have a high sectional so they have to be off the floor or the rightt sidr would be coverrd by couh
LanceX is offline
post #37 of 37 Old 07-09-2012, 03:33 PM
cel4145's Avatar
Liked: 2991
Yep. The Tartan Cables are very good quality for the price, comparable to the Monoprice that everyone here recommends. I've had Mediabridge cables. Sometimes they work well, but generally they not the same heavy duty quality.
Reply Speakers
