Need help with setting up crossover frequency for my yamaha NS-AP2600 5.1 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-07-2012, 09:42 PM - Thread Starter
kenkraly2004's Avatar
I need some help with setting up crossover frequency for my yamaha speakers 5.1. I have a Onkyo TXSR-308 Home theater receiver and Yamaha 5.1 Speakers model number NS-AP2600. What is the correct cross over frequency I set the onkyo to for the speakers? Any help on this would be great. Thanks.
kenkraly2004 is offline
post #2 of 2 Old 07-07-2012, 10:14 PM
Brocken_5110's Avatar
120Hz would be a good starting point - I think those satellites only go down to 120Hz. Since your receiver doesn't have mic-based auto-setup, you'll have to listen and do it manually.
You could try playing back a series of test tones and listening for how low the satellites can go.
Brocken_5110 is offline
Reply Speakers
Yamaha Ns Ap2600bl Home Theater 5 0 Speaker System
